1 | // Chip Select für externen Speicher
2 | #define S25FL256S_ChipSelect() GPIO_ResetBits(S25FL_PORT, S25FL_CS_PIN)
3 | // Chip Deselect für externen Speicher
4 | #define S25FL256S_ChipDeselect() GPIO_SetBits(S25FL_PORT, S25FL_CS_PIN)
5 |
6 | void S25FL_Configuration()
7 | {
8 |
9 | GPIO_InitTypeDef GPIO_InitStructure;
10 | SPI_InitTypeDef SPI_InitStructure;
11 |
12 | // RCC Konfiguration
13 | //------------------------------------------------------------------------------------
14 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_SPI1, ENABLE);
15 |
16 | // Konfiguriert den Not CS Pin als Ausgang
17 | //------------------------------------------------------------------------------------
18 | GPIO_InitStructure.GPIO_Pin = S25FL_CS_PIN;
19 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
20 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
21 | GPIO_Init(S25FL_PORT, &GPIO_InitStructure);
22 |
23 | // Konfiguriert die SPI Pins
24 | //------------------------------------------------------------------------------------
25 | GPIO_InitStructure.GPIO_Pin = S25FL_SCK_PIN | S25FL_SO_PIN | S25FL_SI_PIN;
26 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
27 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
28 | GPIO_Init(S25FL_PORT, &GPIO_InitStructure);
29 |
30 | // SPI Master Konfiguration
31 | //------------------------------------------------------------------------------------
32 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
33 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
34 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
35 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; // SPI_CPOL_High, SPI_CPOL_Low
36 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; // SPI_CPHA_1Edge, SPI_CPHA_2Edge
37 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; // SPI_NSS_Soft, SPI_NSS_Hard
38 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;//SPI_BaudRatePrescaler_128;//SPI_BaudRatePrescaler_16;// 72M / 64 = 1.125M
39 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
40 | SPI_InitStructure.SPI_CRCPolynomial = 7;
41 |
42 | SPI_I2S_DeInit(S25FL_SPI);
43 | SPI_Init(S25FL_SPI, &SPI_InitStructure);
44 |
45 | // Enable SPI_MASTER
46 | SPI_Cmd(S25FL_SPI, ENABLE);
47 | SPI_CalculateCRC(S25FL_SPI, DISABLE);
48 | }
49 |
50 |
51 | u8 S25FL256S_FlashRead(u8 command, u32 address, u8* buffer, int number_Of_Read_Bytes)
52 | {
53 | u8 status = TRUE;
54 | int data_cycle;
55 |
56 | // Sendet den Befehl
57 | while(SPI_I2S_GetFlagStatus(S25FL_SPI, SPI_I2S_FLAG_TXE) == RESET); // Wartet bis der TX-Puffer leer ist.
58 | SPI_I2S_SendData(S25FL_SPI, command); // Sendet das Byte.
59 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
60 |
61 | // Sendet die Adresse
62 | if(address != ADDRESS_NOT_USED)
63 | {
64 | while(SPI_I2S_GetFlagStatus(S25FL_SPI, SPI_I2S_FLAG_TXE) == RESET); // Wartet bis der TX-Puffer leer ist.
65 | SPI_I2S_SendData(S25FL_SPI, (u8)((address >> 16) & 0x000000FF)); // Sendet das Byte.
66 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
67 |
68 | while(SPI_I2S_GetFlagStatus(S25FL_SPI, SPI_I2S_FLAG_TXE) == RESET); // Wartet bis der TX-Puffer leer ist.
69 | SPI_I2S_SendData(S25FL_SPI, (u8)((address >> 8) & 0x000000FF)); // Sendet das Byte.
70 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
71 |
72 | while(SPI_I2S_GetFlagStatus(S25FL_SPI, SPI_I2S_FLAG_TXE) == RESET); // Wartet bis der TX-Puffer leer ist.
73 | SPI_I2S_SendData(S25FL_SPI, (u8)(address & 0x000000FF)); // Sendet das Byte.
74 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
75 | }
76 |
77 | if(number_Of_Read_Bytes != 0)
78 | {
79 | for(data_cycle = 0; data_cycle < number_Of_Read_Bytes; data_cycle++)
80 | {
81 | while( (S25FL_SPI->SR & SPI_I2S_FLAG_TXE) == RESET); // Wartet bis der TX-Puffer leer ist.
82 | SPI_I2S_SendData(S25FL_SPI, 0);
83 |
84 | while(SPI_I2S_GetFlagStatus(S25FL_SPI, SPI_I2S_FLAG_RXNE) == RESET);
85 | *(buffer + data_cycle) = (u8)SPI_I2S_ReceiveData(S25FL_SPI);
86 | }
87 | }
88 |
89 | return status;
90 | }
91 |
92 | void S25FL256S_Wait(u32 ticks)
93 | {
94 | while(ticks)
95 | {
96 | ticks--;
97 | __NOP();
98 | }
99 | }
100 |
101 | u16 S25FL256S_ReadID(void)
102 | {
103 | u32 returnValue;
104 |
105 | S25FL256S_ChipSelect();
106 |
107 | // Wenn ich hier vier Bytes lade, liefert ist returnValue 0 x 01 18 18 FF
108 | // die zuletzt gelesenen Bytes 01 18 haben die richtigen Werte.
109 | // S25FL256S_FlashRead(S25FL256S_CMD_READ_ID, 0x000000, (u8*)&returnValue, 4);
110 |
111 | // Read Identification - REMS (Read_ID or REMS 90h)
112 | S25FL256S_FlashRead(S25FL256S_CMD_READ_ID, 0x000000, (u8*)&returnValue, 2); // Soll 0x 01 18 liefert
113 |
114 | S25FL256S_Wait(0x0F);
115 | while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
116 | S25FL256S_ChipDeselect();
117 |
118 | return (u16)(returnValue & 0x0000ffff);
119 | }
120 |
121 | u16 S25FL256S_ReadStatusReg1(void)
122 | {
123 | u16 returnValue;
124 |
125 | S25FL256S_ChipSelect();
126 | S25FL256S_Wait(0x0F);
127 |
128 | S25FL256S_FlashRead(S25FL256S_CMD_READ_STATUS_REG1, ADDRESS_NOT_USED, (u8*)&returnValue, 2);
129 |
130 | S25FL256S_Wait(0x0F);
131 | while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); // Warten bis Byte vollständig gesendet ist
132 | S25FL256S_ChipDeselect();
133 |
134 | return returnValue;
135 | }
136 |
137 | // ---------------------------------------
138 |
139 | int main(void)
140 | {
141 | u16 a, b;
142 |
143 | InitializeProgram();
144 | S25FL_Configuration();
145 |
146 | while(1)
147 | {
148 | a = S25FL256S_ReadID();
149 | b = S25FL256S_ReadStatusReg1();
150 |
151 | S25FL256S_Wait(0xffff);
152 | }
153 | }
