Hallo!
Ich verwende den STM32F103VDT6 und das uVision von Keil.
Ich möchte den Tempsensor verwenden.
Ich erhalte leider immer eine Temperatur von -379944°C.
Meine Init: Ausschnitt!
1  | typedef struct{
2  |                 TADCinval AN_MotI;        // AN_IN
3  |                 TADCinval AN_IN1;
4  |                 TADCinval AN_TmpSens;
5  |               }
6  |         TADCin;
1  | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(ADC1->DR);
2  |   DMA_InitStructure.DMA_MemoryBaseAddr      = (uint32_t)&ADCin;     // ADC In Variable
3  |
4  |   DMA_InitStructure.DMA_DIR                 = DMA_DIR_PeripheralSRC;
5  |   DMA_InitStructure.DMA_BufferSize          = sizeof(TADCin)/ sizeof(TADCinval);
6  |
7  | // ADC1 configuration ------------------------------------------------------
8  |   ADC_InitStructure.ADC_Mode                = ADC_Mode_Independent;
9  |   ADC_InitStructure.ADC_ScanConvMode        = ENABLE;
10  |   ADC_InitStructure.ADC_ContinuousConvMode  = ENABLE;
11  |   ADC_InitStructure.ADC_ExternalTrigConv    = ADC_ExternalTrigConv_None;
12  |   ADC_InitStructure.ADC_DataAlign           = ADC_DataAlign_Right;
13  |   ADC_InitStructure.ADC_NbrOfChannel        = 3;
14  |   ADC_Init(ADC1, &ADC_InitStructure);
15  |
16  |
17  |   // ADC1 regular channel11 configuration
18  |   ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_71Cycles5); // AN_IN   12.5 + 71.5 = 84 cycles --> 7us
19  |   ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 2, ADC_SampleTime_71Cycles5); // VNFGND  12.5 + 71.5 = 84 cycles --> 7us
20  |   ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 3, ADC_SampleTime_71Cycles5); // Pot R43 12.5 + 71.5 = 84 cycles --> 7us
21  |   ADC_RegularChannelConfig(ADC1, ADC_Channel_17,  4, ADC_SampleTime_71Cycles5); // Pot R56 12.5 + 71.5 = 84 cycles --> 7us
22  |
23  | // Enable ADC1 DMA
24  |   ADC_DMACmd(ADC1, ENABLE);
25  |
26  |   // Enable ADC1
27  |   ADC_Cmd(ADC1, ENABLE);
28  |
29  |   // Enable ADC1 reset calibration register
30  |   ADC_ResetCalibration(ADC1);
31  |   // Check the end of ADC1 reset calibration register
32  |   while(ADC_GetResetCalibrationStatus(ADC1));
33  |
34  |   // Start ADC1 calibration
35  |   ADC_StartCalibration(ADC1);
36  |   // Check the end of ADC1 calibration
37  |   while(ADC_GetCalibrationStatus(ADC1));
38  |
39  |   ADC_TempSensorVrefintCmd(ENABLE);
40  |
41  |   // Start ADC1 Software Conversion
42  |   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
Ich füre noch 2 andere Messungen durch, die funktionieren.
ADC_Channel_16 und _17 sind für den TempSens.
1  | #define V25       1.43
2  | #define AVGSLOPE  0.0043
3  |
4  | int   ADC_Device_Mes  = 0;
5  | int   ADC_DevValue    = 0;
6  | float TempSens_C      = 0.0;
7  |
8  |
9  | int DevTemperatur_Measure(void)               //ToDo//
10  | {
11  |   ADC_Device_Mes =  ADCin.AN_TmpSens;         // get the measured ADC value
12  |   TempSens_C = ((V25 - ADC_Device_Mes)/AVGSLOPE) + 25;
13  |   return(TempSens_C);
14  | }
ADC_Device_Mes in Digits, dies ist ja korrekt, damit die Formel am
Schluss °C ergibt.
1  | ADC_InitStructure.ADC_NbrOfChannel        = 3;
Habe ich auch mit 4 probiert, dann lief nichts mehr
Sieht jemand einen Fehler?
