Hi, In meinem CAN-Buch steht For CAN networks obviously a DC path of 120 Ohm // 120 Ohm = 60 Ohm for dominant signals must be provided. The location of the terminating resistors should not matter at the moment. These line terminations are valid only for the differential mode signal, since the common mode signal is not properly terminated. Kann mir jemand erklären, was der Autor damit meint? Differential mode = dominant bit? Common mode = recessive bit? Danke im Vorraus Sommer
