ich will für den PIC16F1823 den ADC ausporgrammieren, doch er
funkioniert einfach nicht! :(
Versuche schon verzweifelt den Fehler zu finden, doch ich weis nicht was
ich falsch gemacht habe.
Die Read-Funktion gibt mir immer den Wert 0 zurück... egal was ich für
eine Spannung an dem AD-Pin anlege..
Bitte kann mir jemand helfen. Danke schon mal im Voraus.
Hier ist mein Quellcode:
1 |
2 | void init_ADC();
3 | unsigned int read_ADC(unsigned char channel);
4 |
5 |
6 | void init_ADC()
7 | {
8 | //Select ADC conversion clock, Frc (from a intern Oscillator) 1us - 6us
9 | ADCON1.ADCS0 = 1;
10 | ADCON1.ADCS1 = 1;
11 | ADCON1.ADCS2 = 1;
12 |
13 | //select interne Vref
14 | ADCON1.ADPREF0 = 1;
15 | ADCON1.ADPREF1 = 1;
16 |
17 | //select Vref = 2.048V
18 | FVRCON.ADFVR0 = 0;
19 | FVRCON.ADFVR1 = 1;
20 |
21 | //adc result format selection --> right justified
22 | ADCON1.ADFM = 1;
23 | }
24 |
25 | unsigned int read_ADC(unsigned char channel)
26 | {
27 | unsigned int adc_result; //variable for adc-result
28 | unsigned int temp;
29 |
30 | ADCON0=0x00;
31 |
32 | /*channel selection*/
33 | switch(channel)
34 | {
35 | case 0:
36 | ADCON0.CHS0 = 0;
37 | ADCON0.CHS1 = 0;
38 | ADCON0.CHS2 = 0;
39 | ADCON0.CHS3 = 0;
40 | break;
41 | case 1:
42 | ADCON0.CHS0 = 1;
43 | ADCON0.CHS1 = 0;
44 | ADCON0.CHS2 = 0;
45 | ADCON0.CHS3 = 0;
46 | break;
47 | }
48 |
49 | /*enable ADC-Module*/
50 | ADCON0.ADON = 1;
51 |
52 | /*start of ad-convertion*/
53 | ADCON0.GO = 1;
54 |
55 | /*wait until finish of ad-convertion*/
56 | while(ADCON0.GO);
57 |
58 | /*write adc restult in adc_result*/
59 | temp = ADRESH <<8;
60 | adc_result = temp || ADRESL;
61 |
62 | /*disable ADC-Module*/
63 | ADCON0.ADON = 0;
64 |
65 | return adc_result;
66 | }
67 |
68 | void main()
69 | {
70 | unsigned int voltage = 0;
71 |
72 | TRISC = 0x00;
73 | PORTC = 0b000000;
74 |
75 | TRISA = 0xFF;
76 | ANSELA = 0xFF;
77 |
78 | init_ADC();
79 |
80 | while(1){
81 | voltage = read_ADC(0);
82 |
83 | if(voltage == 0)
84 | PORTC = 0b000101;
85 | else if(voltage > 349 && voltage < 700)
86 | {
87 | PORTC = 0b000001;
88 | }
89 | else if(voltage > 699 && voltage < 1000)
90 | {
91 | PORTC = 0b000011;
92 | }
93 | else if(voltage > 999)
94 | {
95 | PORTC = 0b000111;
96 | }
97 | else{
98 | PORTC = 0b000000;
99 | }
100 | }
101 | }
