Hallo, ich habe mir den mySmartUSB light Programmer gekauft und will damit nun einen Attiny13 unter Linux mit avrdude programmieren (ISP 6 Pin). Ich habe zum Test mal folgendes eingegeben: avrdude -v -p t13 -c stk500v2 -P /dev/ttyUSB0 -U flash:r:flash.hex:i Leider bekomme ich die folgende Fehlermeldung: avrdude: Version 5.11, compiled on Dec 1 2012 at 18:15:52 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "/usr/local/etc/avrdude.conf" User configuration file is "/root/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/ttyUSB0 Using Programmer : stk500v2 AVR Part : ATtiny13 Chip Erase delay : 4000 us PAGEL : P00 BS2 : P00 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Programmer Type : STK500V2 Description : Atmel STK500 Version 2.x firmware Programmer Model: STK500 Hardware Version: 3 Firmware Version Master : 2.10 Topcard : Unknown Vtarget : 0.0 V SCK period : 3.3 us Varef : 0.0 V Oscillator : Off avrdude: stk500v2_ReceiveMessage(): timeout avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.98s avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. avrdude done. Thank you. --------------------------------------------- Der Attiny13 sitzt auf einem Breadboard und alle Pins sind angeschlossen (Pinbelegung nach Dokumentation). Kann mir jemand einen Tip geben, was ich hier falsch mache? Ist der Programmer-Typ der richtige(So ist er in der Dokumentation angegeben)? Ich habe folgende Dokumentationen angeschaut bzgl der Pin-Belegung: attiny13: http://www.atmel.com/Images/doc2535.pdf mySmartUSBLight: http://www.myavr.info/download/produkte/mysmartusb_light/techb_mySmartUSB-light_de_en.pdf Kann mir jemand einen Tip geben, was ich hier falsch mache? Ist der Programmer-Typ der richtige(So ist er in der Dokumentation angegeben)? Ich habe das Ganze auch mal mit einem Pullup (10k) für den Reset Pin probiert. Leider bringt das aber auch nichts :-(
Hallo Bubba, es sieht ganz so aus, als wenn dein Controller nicht korrekt mit dem Programmer verbunden ist. An deiner Stelle würde ich noch einmal alle Verbindungen überprüfen.
