1 | //------HEADER-----------------
2 | #include <stdio.h>
3 | #include <stdlib.h>
4 | #include <p18cxxx.h>
5 | #include <delays.h>
6 |
7 | //------CPU SETTINGS-------------
8 | #pragma config MCLRE = OFF //RE3 input pin enabled; MCLR disabled
9 | #pragma config XINST = OFF
10 | //#pragma config FOSC = INTIO1 //Internal oscillator block, CLKOUT function on RA6, port function on RA7
11 | #pragma config FOSC = INTIO2 //Internal oscillator block, port function on RA6 and RA7
12 | #pragma config INTOSCSEL = LOW //LF-INTOSC in Low-power mode during Sleep
13 | #pragma config RETEN = OFF //Ultra low-power regulator is Disabled (Controlled by REGSLP bit)
14 | #pragma config WDTEN = OFF //WDT is controlled by SWDTEN bit of the WDTCON register
15 | #pragma config WDTPS = 2048 //Watchdog Timer Postscale Select bits 4ms*2048
16 | #pragma config FCMEN = OFF //Fail-Safe Clock Monitor disabled
17 | #pragma config IESO = OFF //Oscillator Switchover mode disabled
18 | #pragma config PWRTEN = ON //enable Power-up Timer
19 | #pragma config BOREN = OFF //Brown-out Reset disabled in hardware and software
20 | #pragma config SOSCSEL = DIG //Digital (SCLKI) mode; I/O port functionality of RC0 and RC1 is enabled
21 |
22 | //-----FORWARD------------------------------------------------------------------------------
23 | void main (void);
24 | void InterruptHandlerHigh (void); //Interrupt
25 |
26 | //-------main-------------------------------------------------------------------------------
27 | void main(void)
28 | {
29 | //init pins
30 | TRISA=0x00;
31 | TRISB=0xff;
32 | TRISC=0x00;
33 |
34 | PORTA=0xff;
35 | PORTC=0xff;
36 |
37 | INTCONbits.GIE=0; //disable all interrupts
38 | //init Debug Messages
39 | OSCCON=0b01100000; //8MHz
40 | OSCTUNEbits.PLLEN=0; //x4 off
41 | // OSCCON=0b00110000; //1MHz
42 | // OSCTUNEbits.PLLEN=0; //x4 off
43 |
44 | //activate all interrupts
45 |
46 | INTCON3bits.INT1IE=1; //Enables the INT1 external interrupt
47 | // INTCON3bits.INT2IE=1; //Enables the INT2 external interrupt
48 | INTCONbits.GIE=1;
49 |
50 | while(1) //endless loop
51 | {
52 | PORTC=0xff;
53 | Delay10KTCYx(1000);
54 | PORTC=0x00;
55 | Delay10KTCYx(1000);
56 | }//end while
57 |
58 | }//end main
59 |
60 | //===========================================================================================
61 | //-------------------------------------------------------------------------------------------
62 | // High priority interrupt vector
63 | #pragma code InterruptVectorHigh = 0x08
64 | void InterruptVectorHigh (void)
65 | {
66 | _asm
67 | goto InterruptHandlerHigh //jump to interrupt routine
68 | _endasm
69 | }
70 | //-------------------------------------------------------------------------------------------
71 | // High priority interrupt routine
72 | #pragma code
73 | #pragma interrupt InterruptHandlerHigh
74 | void InterruptHandlerHigh ()
75 | {
76 | /*
77 | //extern interrtupt INT2
78 | if (INTCON3bits.INT2IF)
79 | {//check for INT2
80 | INTCON3bits.INT2IF = 0; //clear ext interrupt flag
81 |
82 |
83 | }
84 | */
85 | //extern interrtupt INT1
86 | if (INTCON3bits.INT1IF)
87 | {//check for INT1
88 | INTCON3bits.INT1IF = 0; //clear ext interrupt flag
89 | PORTA=0x00;
90 | Delay10KTCYx(100);
91 | PORTA=0xFF;
92 | }
93 | }
