Hallo, ich versuche gerade ein Projekt von Atollic True Studio auf die CoIDE umzubauen bzw. zu portieren. Bis jetzt scheint es auch alles zu klappen, bis auf das ich in Atollic die Funktion sqrt(..) nutzen konnte und in CooCox nicht bzw. funktioniert diese nur, wenn ich Softfloats verwende. Bei Hardfloats gibts folgende Fehlermeldung/en : [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(bpabi.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(bpabi.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(unwind-arm.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(unwind-arm.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(pr-support.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(pr-support.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(_divdi3.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(_divdi3.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(_udivdi3.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/armv7e-m\ libgcc.a(_udivdi3.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-abort.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-abort.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-memcpy.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-memcpy.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-signal.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-signal.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-signalr.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-signalr.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-impure.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-impure.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-mallocr.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-mallocr.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-mlock.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-mlock.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-reent.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-reent.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-sbrkr.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-sbrkr.o) [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: error: Test_CoIDE_Ingo.elf uses VFP register arguments, c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-freer.o) does not [cc] c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/program files (x86)/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../ ../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-freer.o) [cc] C:\Users\Ingo Lührig\Desktop\CoIDE Test/Funktionen.c:229: undefined reference to `sqrt' Das undefined reference zu sqrt macht mich stutzig, da sie Funktion vorhanden ist und mit der Math.h auch eingebunden ist. Schalte ich um auf SoftFloats geht es, warum auch immer. Kann mir jemand helfen? Ingo
