while{1} bei MSP430F2013
Gast #3001207
Wenn ich den Interrupt für den 16-Bit-ADU setze wird der Code der in der
while-Schleife steht nicht mehr ausgeführt. Kennt jemand dafür die
Ursache?
//using the MSP430F2013 as ADU
//December 2012
//data transfer works with blocks of 16 16-Bit-Words (INT16)
#include "msp430x20x3.h"
unsigned int numtotransfer = 16;
unsigned int values[32];   //space for 32 values
unsigned int counter = 0;
unsigned int i=0;         //for-next-counter
unsigned int j=0;         //upper or lower 16 values
unsigned int dataready = 0;   //indicates if a packages of 16 values is
ready
int main( void )
  WDTCTL = WDTPW + WDTHOLD;     //Stop watchdog timer to prevent time
out reset
  //prepare for using an external oscillator
  _BIS_SR(SCG0);                //switch of DCO
  __bic_SR_register(OSCOFF);    //switch of internal oscillator LFXT1
  BCSCTL3 &= ~BIT2;             //minimize crystal capacity
  BCSCTL3 &= ~BIT3;             //minimize crystal capacity
  BCSCTL3 |= BIT4;              //switch XIN for external clock
  BCSCTL3 |= BIT5;              //switch XIN for external clock
  BCSCTL2 &= ~BIT1;             //divider for SMCLK = 1
  BCSCTL2 &= ~BIT2;             //divider for SMCLK = 1
  BCSCTL2 |= BIT3;              //select SMCLK = LFXT1CLK or VLOCLK
  BCSCTL2 &= ~BIT4;             //divider for MCLK = 1
  BCSCTL2 &= ~BIT5;             //divider for MCLK = 1
  BCSCTL2 |= BIT6;              //select MCLK = LFXT1CLK or VLOCLK
  BCSCTL2 |= BIT7;              //select MCLK = LFXT1CLK or VLOCLK
  //init Ports
  P1DIR = BIT4;                         //P1.4 to output direction
  P1SEL = BIT4;                         //SMCLK to P1.4
  P1DIR |= BIT2;                        //P1.2 to output direction (a
set of 16-Bit-Words is ready)
  P1DIR |= BIT3;                        //P1.3 to output direction
  P1SEL |= BIT3;                        //Uref to P1.3
  P2SEL &= ~BIT7;                       //P2.7 for normal input/output
use
  P2DIR |= BIT7;                        //P2.7 to output direction
(handshake signal DRDY)
  P1OUT |= BIT7;                        //P2.7 default to high
(DRDY=high)
  //init USI-SPI
  USICTL0 &= ~USISWRST;                 //USI released for operation
  USICTL1 &= ~USII2C;                   //clear the I²C-Bit to switch
USI to SPI-Mode
  USICTL0 &= ~USIMST;                   //reset Masterbit to be
SPI-Slave
  USICTL0 |= USIPE5;                    //SPI-clock via P1.5 (from
Warrior56)
  USICTL0 |= USIPE6;                    //SDO-Port enabled; Pin8, P1.6
  USICTL0 |= USIPE7;                    //SDI-Port enabled; Pin9, P1.7
  USICTL0 &= ~USILSB;                   //MSB first
  USICKCTL &= ~USICKPL;                 //clock is low when idle
  USICTL1 &= ~USICKPH;                  //get data on the first edge
  USICTL0 |= USIOE;                     //activate output (data goes
from MSP to Warrior56)
  USICNT |= USI16B;                     //SPI-Register USISR for
16-Bit-data
  //init ADC SD16
  SD16CTL = SD16REFON;                  //activate reference 1,2V
  SD16CTL |= SD16SSEL_1;                //clock for ADU is SMCLK
  SD16CTL |= SD16XDIV_2;                //divider through 16
  SD16CTL |= SD16DIV_2;                 //divider through 4; both
divider results for 250kHz for the ADU
  SD16INCTL0 = SD16INCH_4;              //input via A4, P1.1, Pin3
  SD16CCTL0 = SD16UNI;                  //16-Bit unsigned
  SD16CCTL0 |= SD16IE;                  //interrupt enabled for ADU
  SD16CCTL0 &= ~SD16XOSR;
  SD16CCTL0 |= SD16OSR_512;             //parameter of the
low-pass-filter 250kHz/512=488Hz Samplerate
  SD16CCTL0 |= SD16SC;                  //start conversion
  _BIS_SR(GIE);     //enable all interrupts
  while(1)
    P2OUT |= BIT7;    //stop data transfer via handshake
    if (dataready > 0)
      P2OUT &= ~BIT7;   //handshake: data can be shift
      for(i=0; i < numtotransfer; i++)
        USISR=values[i+j];       //write current value into the
SPI-Register
        USICNT |= 16;            //load counter and start transmission
with 16 Bit-Word
        while(!(USIIFG & USICTL1));  //wait until data are transfered
      P2OUT |= BIT7;   //handshake: stop datashift
      dataready=0;
#pragma vector = SD16_VECTOR
  __interrupt void SD16ISR(void)
    values[counter] = SD16MEM0;
    counter++;
    P2OUT |= BIT7; //no data transfer allowed: handshake is high
    if (counter == numtotransfer)
      P1OUT &= ~BIT2;   //P1.2 to low if the lower set of 16-Bit-Words
is ready
      j=0;
      dataready = 1;
    if (counter == (numtotransfer * 2))
      counter = 0;
      P1OUT |= BIT2;    //P1.2 to high if the upper set of 16-Bit-Words
is ready
      j = numtotransfer;
      dataready = 1;
