Sehr geehrtes Forum, ich habe eine Software in Assembler geschrieben, die ein Lauflicht mit 10 LEDs steuern soll, doch leider geschehen seltsame Fehler. Erstmal der Code : ----------------------------------------------------- .include "M48PAdef.inc" ; Stackpointerinitialisierung LDI R16, LOW(RAMEND) ;Stackpointer initialisieren OUT SPL, R16 LDI R16, HIGH(RAMEND) ;Stackpointer initialisieren OUT SPH, R16 ; Portoutputinitialisierung LDI r20,0b11111111 OUT DDRB,r20 OUT DDRD,r20 ; Variables Declaration LDI r20,0b10000000 LDI r25,0b00000000 /////////////////////////////////////////////////// //////////////////////Hauptprogramm//////////////// /////////////////////////////////////////////////// MAIN : OUT PORTD, r25 LDI r21,0b00000001 LDI r22,10 LDI r23,19 ROT : OUT PORTB,r21 ROL r21 RCALL Wait100MS INC r22 CPSE r22,r23 BRNE ROT LDI r21,0b00000010 OUT PORTB, r25 OUT PORTD,r21 ROR r21 RCALL Wait100MS OUT PORTD,r21 ROR r21 RCALL Wait100MS RJMP MAIN ; //////////////////////////////////////////////////////////////////////// ////////// ; /////////////////////////// WAIT FUNCTIONS /////////////////////////// ; //////////////////////////////////////////////////////////////////////// ////////// Wait1MS : ; r17 used LDI r16,255 LDI r17,56 WaitXX1ms : NOP INC r17 CPSE r17,r16 BRNE WaitXX1ms RET Wait10MS : ; r18 used [r17 used] LDI r16,255 LDI r18,246 WaitXX10ms : RCALL Wait1MS INC r18 CPSE r18,r16 BRNE WaitXX10ms LDI r18,0b00000000 ; 9075 LDI r16,255 LDI r17,23 ; 9077 WaitXX10ms2 : INC r17 CPSE r17,r16 BRNE WaitXX10ms2 RET Wait100MS : ; r19 used [r18 used [r17 used]] LDI r16,255 LDI r19,246 WaitXX100ms : RCALL Wait10MS INC r19 CPSE r19,r16 BRNE WaitXX100ms LDI r16,255 LDI r19,246 WaitXX100ms2 : RCALL Wait1MS INC r19 CPSE r19,r16 BRNE WaitXX100ms2 LDI r16,255 ; 99121 LDI r19,34 WaitXX10ms3 : INC r19 CPSE r19,r16 BRNE WaitXX10ms3 RET Wait1000MS : RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RCALL WAIT100MS RET ----------------------------------------------------- Das Problem : 1. Es leuchten beim zweiten Durchlauf mehrere LEDs gleichzeitig auf, obwohl ja eigentlich immer nur eine an sein dürfte. 2. Beim ersten Durchlauf gibt es eine Pause von 100MS bevor eine LED von PORTD leuchtet, aber im weiteren Verlauf gibt es diese Pause nicht. Hat jemand ne Idee, wie das sein kann? m.f.G. Developer_X
Hi, also wenn ich es richtig verstehe, sollen die LEDs von links nach rechts laufen und dann wieder zurück? Mit der vorhandenen Programmlogik funktioniert das so nicht. Ansonsten zu Deinen Problemen: zu 1: Du machst ein ROR ohne vorher einen definierten Zustand des Carry-Flags zu haben, beim ROR wird das MSB (Bit 7) mit dem aktuellen Wert aus dem Carry-Flag gefüttert. Evtl. ist dann LSR das was Du machen möchtest. Für ROL gilt analog, das der Wert vom Carry-Flag im Bit 0 landet. Alternativ gibt es hier LSL welches das Bit immer auf 0 setzt. zu 2: Du hast R25 auf 0 gesetzt, machst dann die Ausgabe und den Wait, bevor Du in R25 irgendwas reinschreibst. Wenn Du ein Bit über 10 LEDs (also zwei Register) schieben möchtes, nimm' eine Kombination aus LSL/ROL bzw. LSR/ROR. Angenommen Du nimmst R20 und R21 für die beiden Ports, dann machst Du LSL R20 ROL R21 bzw. LSR R21 ROR R20 Der Effekt ist, wenn das 1-Bit aus dem ersten Register rausgeschoben wird, landet es über das ROL bzw. ROR dann im anderen Register. Allgemein solltest Du versuchen, Deinen Code etwas übersichtlicher zu gestalten :-) - Einrücken von allem was kein Label ist - Klare Beschreibung welche Register eine Funktion verwendet (IN, OUT, SCRATCH) - Eine klare Taktik, welche Register eine Funktion grundsätzlich verändern darf (z.B. r0/r1 und r28/r29), alles andere mit push/pop retten falls es in der Funktion benötigt wird. Grüße Markus
Nein, es soll folgendes leisten : Die Leiste soll von links (PortB 1) nach rechts (PORTD 2) durchlaufen, es sind 10 LEDS, deshalb müssen zwei Ports verwendet werden, danach soll das ganze wieder bei Port B1 beginnen. So meinte ich das, kannst du mir im Anbetracht dessen weiterhelfen? Danke, m.f.G. Developer_X
Ungefähr so (Initialisierung spare ich mir mal):
1 | MyLoop2: |
2 | ldi r20, 0x01 ; Startwert PORTB |
3 | ldi r21, 0x00 ; Startwert PORTD |
4 | |
5 | MyLoop: |
6 | OUT PORTB, r20 ; Ausgabe PORTB |
7 | OUT PORTD, r21 ; Ausgabe PORTD |
8 | |
9 | (Hier Wait-Funktion einfuegen) |
10 | |
11 | lsl r20 ; Bits PORTB schieben |
12 | rol r21 ; Bits PORTD schieben |
13 | |
14 | cpi r21, 0b100 ; Überlauf erreicht? |
15 | brne MyLoop ; Noe! |
16 | |
17 | rjmp MyLoop2 ; Ja -> Neu anfangen |
Grüße Markus
