1 | /****************************************************************************
2 | * $Id:: tmrtest.c 6098 2011-01-08 02:26:20Z nxp12832 $
3 | * Project: NXP LPC17xx Timer example
4 | *
5 | * Description:
6 | * This file contains Timer test modules, main entry, to test Timer APIs.
7 | *
8 | ****************************************************************************
9 | * Software that is described herein is for illustrative purposes only
10 | * which provides customers with programming information regarding the
11 | * products. This software is supplied "AS IS" without any warranties.
12 | * NXP Semiconductors assumes no responsibility or liability for the
13 | * use of the software, conveys no license or title under any patent,
14 | * copyright, or mask work right to the product. NXP Semiconductors
15 | * reserves the right to make changes in the software without
16 | * notification. NXP Semiconductors also make no representation or
17 | * warranty that such application will be suitable for the specified
18 | * use without further testing or modification.
19 | ****************************************************************************/
20 | #include <cr_section_macros.h>
21 | #include <NXP/crp.h>
22 |
23 | __CRP const unsigned int CRP_WORD = CRP_NO_CRP ;
24 |
25 | #include "lpc17xx.h"
26 | #include "type.h"
27 | #include "timer.h"
28 |
29 | #define BLINK_INTERVAL 20
30 |
31 | extern uint32_t timer0_m0_counter, timer1_m0_counter;
32 | extern uint32_t timer0_m1_counter, timer1_m1_counter;
33 |
34 | /*****************************************************************************
35 | ** Main Function main()
36 | *****************************************************************************/
37 | int main (void)
38 | {
39 | uint32_t i;
40 |
41 | /* SystemClockUpdate() updates the SystemFrequency variable */
42 | SystemClockUpdate();
43 |
44 | LPC_GPIO2->FIODIR = 0x000000FF; /* P2.0..7 defined as Outputs */ //Geändert aufP2.0...5
45 | LPC_GPIO2->FIOCLR = 0x000000FF; /* turn off all the LEDs */
46 |
47 | for ( i = 0; i < 2; i++ )
48 | {
49 | init_timer( i , TIME_INTERVAL );
50 | enable_timer( i );
51 | }
52 |
53 | /* Loop forever */
54 | while (1)
55 | { /* Loop forever */
56 | if ( (timer0_m0_counter > 0) && (timer0_m0_counter <= BLINK_INTERVAL) )
57 | {
58 | LPC_GPIO2->FIOSET = 1 << 2;
59 | }
60 | if ( (timer0_m0_counter > BLINK_INTERVAL) && (timer0_m0_counter <= (BLINK_INTERVAL * 2)) )
61 | {
62 | LPC_GPIO2->FIOCLR = 1 << 2;
63 | }
64 | else if ( timer0_m0_counter > (BLINK_INTERVAL * 2) )
65 | {
66 | timer0_m0_counter = 0;
67 | }
68 | /* Timer 1 blinky LED 1 */
69 | if ( (timer1_m0_counter > 0) && (timer1_m0_counter <= BLINK_INTERVAL) )
70 | {
71 | LPC_GPIO2->FIOSET = 1 << 3;
72 | }
73 | if ( (timer1_m0_counter > BLINK_INTERVAL) && (timer1_m0_counter <= (BLINK_INTERVAL * 2)) )
74 | {
75 | LPC_GPIO2->FIOCLR = 1 << 3;
76 | }
77 | else if ( timer1_m0_counter > (BLINK_INTERVAL * 2) )
78 | {
79 | timer1_m0_counter = 0;
80 | }
81 | }
82 | }
83 |
84 | /*****************************************************************************
85 | ** End Of File
86 | ******************************************************************************/
