1 | #include <asf.h>
2 | #include <stdio.h>
3 | #define F_CPU 32000000UL
4 | #include <util/delay.h>
5 |
6 | #define LED_ORANGE IOPORT_CREATE_PIN(PORTD, 0)
7 |
8 | int main (void)
9 | {
10 | system_clocks_init();
11 | ioport_configure_pin(LED_ORANGE, IOPORT_DIR_OUTPUT | IOPORT_INIT_HIGH);
12 |
13 | while(1) {
14 | ioport_set_pin_low(LED_ORANGE);
15 | _delay_ms(1000);
16 | ioport_set_pin_high(LED_ORANGE);
17 | }
18 | // Insert application code here, after the board has been initialized.
19 | }
20 |
21 | void system_clocks_init(void)
22 | {
23 | unsigned char n,s;
24 |
25 | // Optimize for speed
26 | #pragma optsize-
27 | // Save interrupts enabled/disabled state
28 | s=SREG;
29 | // Disable interrupts
30 | #asm("cli")
31 |
32 | // Internal 32 kHz RC oscillator initialization
33 | // Enable the internal 32 kHz RC oscillator
34 | OSC.CTRL|=OSC_RC32KEN_bm;
35 | // Wait for the internal 32 kHz RC oscillator to stabilize
36 | while ((OSC.STATUS & OSC_RC32KRDY_bm)==0);
37 |
38 | // Internal 32 MHz RC oscillator initialization
39 | // Enable the internal 32 MHz RC oscillator
40 | OSC.CTRL|=OSC_RC32MEN_bm;
41 |
42 | // System Clock prescaler A division factor: 1
43 | // System Clock prescalers B & C division factors: B:1, C:1
44 | // ClkPer4: 32000,000 kHz
45 | // ClkPer2: 32000,000 kHz
46 | // ClkPer: 32000,000 kHz
47 | // ClkCPU: 32000,000 kHz
48 | n=(CLK.PSCTRL & (~(CLK_PSADIV_gm | CLK_PSBCDIV1_bm | CLK_PSBCDIV0_bm))) |
49 | CLK_PSADIV_1_gc | CLK_PSBCDIV_1_1_gc;
50 | CCP=CCP_IOREG_gc;
51 | CLK.PSCTRL=n;
52 |
53 | // Internal 32 MHz RC osc. calibration reference clock source: 32.768 kHz Internal Osc.
54 | OSC.DFLLCTRL&= ~(OSC_RC32MCREF_bm | OSC_RC2MCREF_bm);
55 | // Enable the autocalibration of the internal 32 MHz RC oscillator
56 | DFLLRC32M.CTRL|=DFLL_ENABLE_bm;
57 |
58 | // Wait for the internal 32 MHz RC oscillator to stabilize
59 | while ((OSC.STATUS & OSC_RC32MRDY_bm)==0);
60 |
61 | // Select the system clock source: 32 MHz Internal RC Osc.
62 | n=(CLK.CTRL & (~CLK_SCLKSEL_gm)) | CLK_SCLKSEL_RC32M_gc;
63 | CCP=CCP_IOREG_gc;
64 | CLK.CTRL=n;
65 |
66 | // Disable the unused oscillators: 2 MHz, external clock/crystal oscillator, PLL
67 | OSC.CTRL&= ~(OSC_RC2MEN_bm | OSC_XOSCEN_bm | OSC_PLLEN_bm);
68 |
69 | // Lock the CLK.CTRL and CLK.PSCTRL registers
70 | n=CLK.LOCK | CLK_LOCK_bm;
71 | CCP=CCP_IOREG_gc;
72 | CLK.LOCK=n;
73 |
74 | // ClkPer output: Disabled bit 7
75 | PORTCFG.CLKEVOUT=(PORTCFG.CLKEVOUT & (~PORTCFG_CLKOUT_gm)) | PORTCFG_CLKOUT_OFF_gc;
76 |
77 | // Restore interrupts enabled/disabled state
78 | SREG=s;
79 | // Restore optimization for size if needed
80 | #pragma optsize_default
81 | }
