1 | int main(void)
2 | {
3 | /*!< At this stage the microcontroller clock setting is already configured,
4 | this is done through SystemInit() function which is called from startup
5 | file (startup_stm32f30x.s) before to branch to application main.
6 | To reconfigure the default setting of SystemInit() function, refer to
7 | system_stm32f30x.c file
8 | */
9 |
10 | LED_Init();
11 |
12 | LED_Write(0x01);
13 |
14 | /* Configure the ADC clock */
15 | RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div2);
16 |
17 | /* Enable ADC1 clock */
18 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12, ENABLE);
19 |
20 | /* ADC Channel configuration */
21 | /* GPIOC Periph clock enable */
22 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
23 |
24 | /* Configure ADC Channel7 as analog input */
25 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 ;
26 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
27 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
28 | GPIO_Init(GPIOC, &GPIO_InitStructure);
29 |
30 | ADC_StructInit(&ADC_InitStructure);
31 |
32 | /* Calibration procedure */
33 | ADC_VoltageRegulatorCmd(ADC2, ENABLE);
34 |
35 | for(i = 0; i < 100000; i++);
36 |
37 | ADC_SelectCalibrationMode(ADC2, ADC_CalibrationMode_Single);
38 | ADC_StartCalibration(ADC2);
39 |
40 | while(ADC_GetCalibrationStatus(ADC2) != RESET );
41 | calibration_value = ADC_GetCalibrationValue(ADC2);
42 |
43 | ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
44 | ADC_CommonInitStructure.ADC_Clock = ADC_Clock_AsynClkMode;
45 | ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
46 | ADC_CommonInitStructure.ADC_DMAMode = ADC_DMAMode_OneShot;
47 | ADC_CommonInitStructure.ADC_TwoSamplingDelay = 0;
48 | ADC_CommonInit(ADC2, &ADC_CommonInitStructure);
49 |
50 | ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Enable;
51 | ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
52 | ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_0;
53 | ADC_InitStructure.ADC_ExternalTrigEventEdge = ADC_ExternalTrigEventEdge_None;
54 | ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
55 | ADC_InitStructure.ADC_OverrunMode = ADC_OverrunMode_Disable;
56 | ADC_InitStructure.ADC_AutoInjMode = ADC_AutoInjec_Disable;
57 | ADC_InitStructure.ADC_NbrOfRegChannel = 1;
58 | ADC_Init(ADC2, &ADC_InitStructure);
59 |
60 | /* ADC1 regular channel7 configuration */
61 | ADC_RegularChannelConfig(ADC2, ADC_Channel_7, 1, ADC_SampleTime_7Cycles5);
62 |
63 | /* Enable ADC1 */
64 | ADC_Cmd(ADC2, ENABLE);
65 |
66 | /* wait for ADRDY */
67 | while(!ADC_GetFlagStatus(ADC2, ADC_FLAG_RDY));
68 |
69 | /* Start ADC1 Software Conversion */
70 | ADC_StartConversion(ADC2);
71 |
72 | /* Infinite loop */
73 | while (1)
74 | {
75 | /* Test EOC flag */
76 | while(ADC_GetFlagStatus(ADC2, ADC_FLAG_EOC) == RESET);
77 |
78 | /* Get ADC1 converted data */
79 | ADC1ConvertedValue = ADC_GetConversionValue(ADC2);
80 |
81 | LED_Write(ADC1ConvertedValue);
82 |
83 | /* Compute the voltage */
84 | ADC1ConvertedVoltage = (ADC1ConvertedValue *3300)/0xFFF;
85 |
86 | }
87 | }
