Hello everybody, i'm interested to program a canbus interface on MB96340 Series controller with id filtering. The problem that i found is on a sample that i found by Fujitsu website. The code of main.c has something different (for my understanding) as describe in readme data. in the readme data, is told: CAN-Buffer 1 receives IDs #1 CAN-Buffer 2 receives IDs with with MSB (ID28) set CAN-Buffer 4 receives all other IDs And in the code we see: CAN0_SetRxBuffer( 1, 0x0001, 1, 0x1FFFFFFF); // Full CAN CAN0_SetRxBuffer( 2, 0x07FF, 1, 0x10000000); // Select messages with MSB set CAN0_SetRxBuffer( 4, 0x0000, 1, 0x00000000); // Receive all messages 1) How does it work if i want this ip filtering on MSB (ID28)? for me is obvious that id should the full one 0x11111111111 (11bits). but mask here seems to be for the MSB of an extended ID with 29bits... 2) Why on line 1 mask is 0x1FFFFFFF and line 3 mask is 0x00000000 for all other ids? 3) how does it works if i want a filtering on frame with the mask on the to two last id-bits Thanks in advanced for interest and help. Cemoi71
Hello Cemoi71, could you already solve your problem? Please let me know, if you still need some help ... I am working with Fujitsu 16FX , too, and maybe I can help you. Best regards, Mic Roller
