Hallo liebe Programmierfreunde Ich und mein Freund müssen für ein Projekt in der Schule eine Wave Datei (.wav) auslesen und bearbeiten. Jedoch haben wir bisher noch nichts mit diesem Thema zu tun gehabt. Mene Frage: Könnte hier jemand vll. einen Code zum einfachen aus- bzw. einlesen von .wav Dateien hereinstellen ? Mfg Weixi
Man muss erst einen Header einlesen, wo die wichtigsten Parameter drinstehen. Mehr-Byte größen sind im little endian Format gespeichert
1 | 0 4 ChunkID Contains the letters "RIFF" in ASCII form |
2 | (0x52494646 big-endian form). |
3 | 4 4 ChunkSize 36 + SubChunk2Size, or more precisely: |
4 | 4 + (8 + SubChunk1Size) + (8 + SubChunk2Size) |
5 | This is the size of the rest of the chunk |
6 | following this number. This is the size of the |
7 | entire file in bytes minus 8 bytes for the |
8 | two fields not included in this count: |
9 | ChunkID and ChunkSize. |
10 | 8 4 Format Contains the letters "WAVE" |
11 | (0x57415645 big-endian form). |
12 | |
13 | The "WAVE" format consists of two subchunks: "fmt " and "data": |
14 | The "fmt " subchunk describes the sound data's format: |
15 | |
16 | 12 4 Subchunk1ID Contains the letters "fmt " |
17 | (0x666d7420 big-endian form). |
18 | 16 4 Subchunk1Size 16 for PCM. This is the size of the |
19 | rest of the Subchunk which follows this number. |
20 | 20 2 AudioFormat PCM = 1 (i.e. Linear quantization) |
21 | Values other than 1 indicate some |
22 | form of compression. |
23 | 22 2 NumChannels Mono = 1, Stereo = 2, etc. |
24 | 24 4 SampleRate 8000, 44100, etc. |
25 | 28 4 ByteRate == SampleRate * NumChannels * BitsPerSample/8 |
26 | 32 2 BlockAlign == NumChannels * BitsPerSample/8 |
27 | The number of bytes for one sample including |
28 | all channels. I wonder what happens when |
29 | this number isn't an integer? |
30 | 34 2 BitsPerSample 8 bits = 8, 16 bits = 16, etc. |
31 | 2 ExtraParamSize if PCM, then doesn't exist |
32 | X ExtraParams space for extra parameters |
33 | |
34 | The "data" subchunk contains the size of the data and the actual sound: |
35 | |
36 | 36 4 Subchunk2ID Contains the letters "data" |
37 | (0x64617461 big-endian form). |
38 | 40 4 Subchunk2Size == NumSamples * NumChannels * BitsPerSample/8 |
39 | This is the number of bytes in the data. |
40 | You can also think of this as the size |
41 | of the read of the subchunk following this |
42 | number. |
43 | 44 * Data The actual sound data. |
44 | |
45 | |
46 | 44 <block align> der erste Abtastwert |
47 | <block align> der zweite Abtastwert |
