1 | #define DMA_SPI2_RX_STREAM DMA1_Stream3
2 | #define DMA_SPI2_TX_STREAM DMA1_Stream4
3 |
4 | void stm32_dma_transfer(
5 | UINT receive, /* FALSE for buff->SPI, TRUE for SPI->buff */
6 | const BYTE *buff, /* receive TRUE : 512 byte data block to be transmitted
7 | receive FALSE : Data buffer to store received data */
8 | UINT btr /* receive TRUE : Byte count (must be multiple of 2)
9 | receive FALSE : Byte count (must be 512) */
10 | )
11 | {
12 | DMA_InitTypeDef DMA_InitStructure;
13 | WORD rw_workbyte[] = { 0xffff };
14 |
15 | //enable clock
16 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
17 |
18 | //start with a blank DMA configuration
19 | DMA_DeInit(DMA_SPI2_RX_STREAM); //SPI-RX
20 | DMA_DeInit(DMA_SPI2_TX_STREAM); //SPI-TX
21 |
22 | //only these parameters differ from default values
23 | DMA_InitStructure.DMA_Channel = DMA_Channel_0;
24 | DMA_InitStructure.DMA_PeripheralBaseAddr = (DWORD) & (SPI2->DR);
25 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
26 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
27 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
28 | DMA_InitStructure.DMA_BufferSize = btr;
29 | DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
30 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
31 |
32 | if (receive){
33 | // DMA1-Channel0-Stream3 configured as SPI2-RX
34 | DMA_InitStructure.DMA_Memory0BaseAddr = (DWORD)buff;
35 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
36 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
37 | DMA_Init(DMA_SPI2_RX_STREAM, &DMA_InitStructure);
38 |
39 | // DMA1-Channel0-Stream4 configured as SPI2-TX
40 | DMA_InitStructure.DMA_Memory0BaseAddr = (DWORD)rw_workbyte;
41 | DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
42 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
43 | DMA_Init(DMA_SPI2_TX_STREAM, &DMA_InitStructure);
44 | }
45 | else {
46 | // DMA1-Channel0-Stream3 configured as SPI2-RX
47 | DMA_InitStructure.DMA_Memory0BaseAddr = (DWORD)rw_workbyte;
48 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
49 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
50 | DMA_Init(DMA_SPI2_RX_STREAM, &DMA_InitStructure);
51 |
52 | // DMA1-Channel0-Stream4 configured as SPI2-TX
53 | DMA_InitStructure.DMA_Memory0BaseAddr = (DWORD)buff;
54 | DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
55 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
56 | DMA_Init(DMA_SPI2_TX_STREAM, &DMA_InitStructure);
57 | }
58 |
59 | //Enable DMA RX/TX
60 | DMA_Cmd(DMA_SPI2_RX_STREAM, ENABLE); //SPI-RX
61 | DMA_Cmd(DMA_SPI2_TX_STREAM, ENABLE); //SPI-TX
62 |
63 | /* Enable SPI TX/RX request */
64 | SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx | SPI_I2S_DMAReq_Tx, ENABLE);
65 |
66 | /* Wait until DMA1_Channel 2 Receive Complete */
67 | //while (DMA_GetFlagStatus(DMA_SPI2_RX_STREAM, DMA_FLAG_TCIF4) == RESET) { ; }
68 |
69 | //Disable DMA RX/TX
70 | DMA_Cmd(DMA_SPI2_RX_STREAM, DISABLE); //SPI-RX
71 | DMA_Cmd(DMA_SPI2_TX_STREAM, DISABLE); //SPI-TX
72 |
73 | /* Disable SPI RX/TX request */
74 | SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx | SPI_I2S_DMAReq_Tx, DISABLE);
75 | }
