Ich habe den Timer im PWM Modus initialisiert und das Signal zappelt wie erwartet am PINA_0. Ich möchte aber noch gerne parallel das Signal an PINA_1 zappeln lassen. Geht das irgendwie? Wenn ich beide Pins initialisiere, sehe ich was nur an PINA0. [c] void InitPWM (void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; // Enable GPIOA and GPIOB clock // GPIO_PinRemapConfig(GPIO_FullRemap_TIM2, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE); // GPIOA Configuration: Channel 1 GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0 | GPIO_Pin_1); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); // Enable TIM1 clock RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); // TIM1 Peripheral Configuration //TIM_DeInit(); // Time Base configuration TIM_TimeBaseStructure.TIM_Prescaler = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = 320; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); // Channel 1 Configuration in PWM mode TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; TIM_OCInitStructure.TIM_Pulse = 160; TIM_OC1Init(TIM2, &TIM_OCInitStructure); // Automatic Output enable, Break, dead time and lock configuration TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable; TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1; TIM_BDTRInitStructure.TIM_DeadTime = 0x05; TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High; TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable; TIM_BDTRConfig(TIM2, &TIM_BDTRInitStructure); // TIM1 counter enable TIM_Cmd(TIM2, ENABLE); // Main Output Enable TIM_CtrlPWMOutputs(TIM2, ENABLE); } [c/]
Ach Mist, habe die Erklärung gerade auf http://www.diller-technologies.de/stm32.html gefunden. So geht das:
1 | TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; |
2 | TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; |
3 | TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; |
4 | TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; |
5 | TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; |
6 | TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; |
7 | TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; |
8 | TIM_OCInitStructure.TIM_Pulse = 160; |
9 | TIM_OC1Init(TIM2, &TIM_OCInitStructure); |
10 | |
11 | TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; |
12 | TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; |
13 | TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; |
14 | TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; |
15 | TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; |
16 | TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; |
17 | TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; |
18 | TIM_OCInitStructure.TIM_Pulse = 160; |
19 | TIM_OC2Init(TIM2, &TIM_OCInitStructure); |
