1 | #define ADC1_DR_ADDRESS ((uint32_t)0x4001204C)
2 |
3 | __IO uint16_t ADC1ConvertedValue;
4 |
5 | void Hardware_AD_Init(void)
6 | {
7 | ADC_InitTypeDef ADC_InitStructure;
8 | ADC_CommonInitTypeDef ADC_CommonInitStructure;
9 | DMA_InitTypeDef DMA_InitStructure;
10 | GPIO_InitTypeDef GPIO_InitStructure;
11 |
12 | /* Enable ADC1, DMA2 and GPIO clocks ****************************************/
13 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
14 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
15 |
16 | /* DMA2 Stream0 channel0 configuration **************************************/
17 | DMA_InitStructure.DMA_Channel = DMA_Channel_0;
18 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
19 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
20 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
21 | DMA_InitStructure.DMA_BufferSize = 1;
22 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
23 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
24 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
25 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
26 | DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
27 | DMA_InitStructure.DMA_Priority = DMA_Priority_High;
28 | DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
29 | DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
30 | DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
31 | DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
32 | DMA_Init(DMA2_Stream0, &DMA_InitStructure);
33 | DMA_Cmd(DMA2_Stream0, ENABLE);
34 |
35 | /* Configure ADC1 as analog input
36 | *********************************************************/
37 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
38 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
39 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
40 | GPIO_Init(GPIOA, &GPIO_InitStructure);
41 |
42 | /* ADC Common Init **********************************************************/
43 | ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
44 | ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
45 | ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
46 | ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
47 | ADC_CommonInit(&ADC_CommonInitStructure);
48 |
49 | /* ADC1 Init ****************************************************************/
50 | ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
51 | ADC_InitStructure.ADC_ScanConvMode = DISABLE;
52 | ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
53 | ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
54 | ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
55 | ADC_InitStructure.ADC_NbrOfConversion = 1;
56 | ADC_Init(ADC1, &ADC_InitStructure);
57 |
58 | /* ADC1 regular channel1 configuration *************************************/
59 | ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
60 |
61 | /* Enable DMA request after last transfer (Single-ADC mode) */
62 | ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
63 |
64 | /* Enable ADC1 DMA */
65 | ADC_DMACmd(ADC1, ENABLE);
66 |
67 | /* Enable ADC1 */
68 | ADC_Cmd(ADC1, ENABLE);
69 | }
70 |
71 | void StartConversion(void)
72 | {
73 | ADC_SoftwareStartConv(ADC1); // A/D convert start
74 | }
75 |
76 | UINT16 ui16_Read_ADC1_ConvertedValue(void)
77 | {
78 | return ADC1ConvertedValue; // Read and return conversion result
79 | }
