Habe gestern MPLAB X installiert das die Netbeans-IDE verwendet. Alleine:
1 | char * teststring; |
produziert:
1 | make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf |
2 | make[1]: Entering directory `C:/Test/Test4/CAN_1.X' |
3 | make -f nbproject/Makefile-default.mk dist/default/production/CAN_1.X.production.hex |
4 | make[2]: Entering directory `C:/Test/Test4/CAN_1.X' |
5 | "C:\Program Files\Microchip\mplabc18\v3.37.01\bin\mcc18.exe" -p18F458 -I "C:\Program Files\Microchip\mplabc18\v3.37.01\bin"\\..\\h -fo build/default/production/main.o main.c |
6 | MPLAB C18 v3.37.01 (feature limited) |
7 | Copyright 2000-2010 Microchip Technology Inc. |
8 | This version of MPLAB C18 does not support the extended mode |
9 | and will not perform all optimizations. To purchase a full |
10 | copy of MPLAB C18, please contact your local distributor or |
11 | visit buy.microchip.com. |
12 | |
13 | WARNING: This version of MPLAB C18 does not support procedural abstraction. Procedural abstraction will not be run. |
14 | |
15 | C:\Test\Test4\CAN_1.X\main.c:74:Error: syntax error |
16 | make[2]: Leaving directory `C:/Test/Test4/CAN_1.X' |
17 | make[2]: *** [build/default/production/main.o] Error 3 |
18 | make[1]: Leaving directory `C:/Test/Test4/CAN_1.X' |
19 | make[1]: *** [.build-conf] Error 2 |
20 | make: *** [.build-impl] Error 2 |
21 | |
22 | BUILD FAILED (exit value 2, total time: 910ms) |
Warum?
