ich habe folgendes Setup:
1. Timer2 triggered ADC, gleichzeitig lasse ich mir dessen Takt
ausgeben. Hier der Code
1 | int iTIMPeriod = 48;
2 |
3 | /* Time base configuration */
4 | TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
5 | TIM_TimeBaseStructure.TIM_Prescaler = 0;
6 | TIM_TimeBaseStructure.TIM_Period = iTIMPeriod;
7 | TIM_TimeBaseStructure.TIM_ClockDivision = 0;
8 | TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
9 | TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
10 |
11 | //TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
12 |
13 | TIM_OCStructInit(&TIM_OCInitStructure);
14 | TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
15 | TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
16 | TIM_OCInitStructure.TIM_Pulse = iTIMPeriod;
17 | TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
18 | TIM_OC2Init(TIM2, &TIM_OCInitStructure);
19 |
20 |
21 | TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_OC2Ref); /* Send the OC2REF signal to the TRGO output */
22 |
23 | TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);
24 | TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
2. Der ADC (14MHz HSI) triggered den DMA im Circular Mode, auch hier der
Code
1 | ADC_InitStruct.ADC_Resolution = ADC_Resolution_12b;
2 | ADC_InitStruct.ADC_ContinuousConvMode = DISABLE;
3 | ADC_InitStruct.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_RisingFalling;
4 | ADC_InitStruct.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO;
5 | ADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;
6 |
7 | ADC_Init(ADC1, &ADC_InitStruct);
8 |
9 | ADC_ChannelConfig(ADC1, ADC_Channel_6, ADC_SampleTime_1_5Cycles);
10 |
11 | ADC_OverrunModeCmd(ADC1, ENABLE);
12 | ADC_DMACmd(ADC1, ENABLE);
13 | ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
14 |
15 | //ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
16 |
17 | ADC_Cmd(ADC1, ENABLE);
18 | while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));
3. Der DMA speichert 32 Werte und stoppt dann im Interrupt den Timer2
1 | DMA_InitStruct.DMA_PeripheralBaseAddr = DMA_ADC1_PERIPHERAL_ADRESS; /* destination peripheral adress: ADC */
2 | DMA_InitStruct.DMA_MemoryBaseAddr = Sensor_GetADC1MemoryAdress(); /* source memory adress */
3 | DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralSRC; /* direction source -> destination */
4 | DMA_InitStruct.DMA_BufferSize = Sensor_DMA_ADC1_MEMORY_BUFFERSIZE; /* amount of samples */
5 | DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable; /* increment peripheral adress yes/no? */
6 | DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable; /* increment memory adress yes/no? */
7 | DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; /* data size to transfer to peripheral */
8 | DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; /* data size to transfer from memory */
9 | DMA_InitStruct.DMA_Mode = DMA_Mode_Circular; /* normal (one shot) or circular */
10 | DMA_InitStruct.DMA_Priority = DMA_Priority_High; /* priority: very high, high, normal, low */
11 | DMA_InitStruct.DMA_M2M = DMA_M2M_Disable; /* data transfer from memory to memory? */
12 |
13 | DMA_Init(DMA1_Channel1, &DMA_InitStruct); /* DMA1_Channel1 + DMA1_Channel2 belong to ADC1 */
14 | DMA_ITConfig(DMA1_Channel1, DMA1_IT_TC1 | DMA1_IT_HT1 , ENABLE); //| DMA1_IT_TE1| DMA1_IT_HT1
15 |
16 | DMA_Cmd(DMA1_Channel1, ENABLE);
Jetzt meine Probleme. So wie ich die Konfiguration Timer, ADC, DMA
gemacht habe funktioniert alles, bis auf die Samplezeit des ADC.
Laut Datenblatt müssten maximal 1MHz (1000ns, siehe Referenz Manual
S.188) drin sein.
Wie oben ersichtlich Lade ich das Auto-Reload-Register auf 48, bei einem
Takt von 48MHz ergibt das 500kHz (Toggle-Mode, abstand 2er positiver
Flanken also 2x 48).
Da ich den ADC auf rising + falling edge eingestellt habe, müsste ich
doch vielleicht mit etwas Jitter nahe an die 1000ns für den ADC kommen.
Zum füllen des Buffers benötige ich aber die doppelte Zeit und kann
diese auch nicht durch Verkleinerung der Auflöung verbessern.
Kann mir jemand helfen, oder wurde der Fehler gar schon entdeckt?
Besten Gruß
public
