1 | #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
2 |
3 | struct __FILE { int handle; };
4 | FILE __stdout;
5 | FILE __stdin;
6 |
7 | void usart1_init (unsigned long baudrate) {
8 | NVIC->ISER[1] |= 0x00000020; //enable USART1 Interrupt (Nested Vector Interrupt Controller)
9 |
10 | RCC->APB2ENR |= RCC_APB2ENR_IOPAEN; //enable GPIOA clock
11 |
12 | GPIOA->CRH &= ~(0x00F0); //clear PA.9 configuration-bit
13 | GPIOA->CRH |= (0x0BUL << 4); //Tx (PA9) - alt. out push-pull
14 |
15 | GPIOA->CRH &= ~(0x0F00); //clear PA.10 configuration-bit
16 | GPIOA->CRH |= (0x04UL << 8); //Rx (PA10) - floating
17 | RCC->APB2ENR |= RCC_APB2ENR_USART1EN; //enable USART1 clock
18 |
19 | USART1->BRR = 8000000L/baudrate; //set baudrate
20 |
21 | USART1->CR1 |= (USART_CR1_RE | USART_CR1_TE); //set RX, TX
22 | USART1->CR1 |= USART_CR1_RXNEIE; //enable USART IRQ
23 | USART1->CR1 |= USART_CR1_UE; //enable USART
24 | }
25 |
26 | void usart2_init (unsigned long baudrate) {
27 | RCC->APB2ENR |= RCC_APB2ENR_IOPAEN; //enable GPIOA clock
28 |
29 | AFIO->MAPR &= ~(AFIO_MAPR_USART2_REMAP); //no remap of RX & TX
30 |
31 | GPIOA->CRL &= ~(0x0F00); //clear PA.2 configuration-bits
32 | GPIOA->CRL |= (0x0BUL << 8); //Tx (PA.2) - alt. out push-pull
33 |
34 | GPIOA->CRL &= ~(0xF000); //clear PA.3 configuration-bits
35 | GPIOA->CRL |= (0x04UL << 12); //Rx (PA.3) - floating
36 | RCC->APB1ENR |= RCC_APB1ENR_USART2EN; //enable USART2 clock
37 |
38 | USART2->BRR = 8000000L/baudrate; //set baudrate
39 |
40 | USART2->CR1 |= (USART_CR1_RE | USART_CR1_TE); //enable RX, TX
41 | USART2->CR1 |= USART_CR1_UE; //enable USART
42 | }
43 |
44 | void usart3_init (unsigned long baudrate) {
45 | NVIC->ISER[1] |= 0x00000080; //enable USART1 Interrupt (Nested Vector Interrupt Controller)
46 | RCC->APB2ENR |= RCC_APB2ENR_IOPBEN; //enable GPIOB clock
47 |
48 | AFIO->MAPR &= ~(AFIO_MAPR_USART3_REMAP); //no remap of RX & TX
49 |
50 | GPIOB->CRH = GPIOB->CRH & ~(0x00000F00) | (0x00000B00); //PB10 = Tx
51 | //GPIOA->CRL |= (0x0BUL << 8); //Tx (PA.2) - alt. out push-pull
52 | GPIOB->CRH = GPIOB->CRH & ~(0x0000F000) | (0x00004000); //PB11 = Rx
53 | //GPIOA->CRL &= ~(0xF000); //PB11 = Rx
54 | //GPIOA->CRL |= (0x04UL << 12); //Rx (PA.3) - floating
55 | RCC->APB1ENR |= RCC_APB1ENR_USART3EN; //enable USART3 clock
56 |
57 | USART3->BRR = 8000000L/baudrate; //set baudrate
58 |
59 | USART3->CR1 |= (USART_CR1_RE | USART_CR1_TE); //enable RX, TX
60 | USART3->CR1 |= USART_CR1_RXNEIE; //enable USART IRQ
61 | USART3->CR1 |= USART_CR1_UE; //enable USART
62 | }
63 |
64 | int send_char (char ch) {
65 | while (!(USART2->SR & USART_SR_TXE)); //data transmit register empty?
66 | USART2->DR = (ch & 0xFF); //write bytewise
67 | return (ch);
68 | }
69 |
70 | /*let send_char point to printf*/
71 | PUTCHAR_PROTOTYPE
72 | {
73 | send_char((char) ch);
74 | return ch;
75 | }
76 |
77 |
78 |
79 | /*Put the received characters in a ringbuffer*/
80 | void USART1_IRQHandler (void){
81 | if((USART1->SR & USART_SR_RXNE)){
82 | fifo_write(&fifo[0], USART1->DR);
83 | }
84 | }
85 |
86 | /*Put the received characters in a ringbuffer*/
87 | void USART3_IRQHandler (void){
88 | if((USART3->SR & USART_SR_RXNE)){
89 | fifo_write(&fifo[1], USART3->DR);
90 | }
91 | }
92 |
93 | int main(void)
94 | {
95 |
96 | uint8_t data[2] = {0,0};
97 | uint8_t ret[2] = {0,0};
98 |
99 | //initialize ringbuffer
100 | fifo_init(&fifo[0]);
101 | fifo_init(&fifo[1]);
102 |
103 |
104 | usart1_init(9600); //USART1 used for sending data
105 | usart2_init(9600); //USART2 used for receiving data
106 | usart3_init(9600); //USART3 used for receiving data
107 |
108 | for(;;){
109 | __disable_irq(); //translate to CPSID i
110 | //try to read from ringbuffer and put read char in 'data'
111 | ret[0] = fifo_read(&fifo[0], &data[0]);
112 | ret[1] = fifo_read(&fifo[1], &data[1]);
113 | __enable_irq(); //translate to CPSIE i
114 |
115 | if(ret[0] == SUCCESS){ //if there was new char in ringbuffer
116 | printf("%d", manipulate_data(data[0])); //manipulate data and write it out
117 | }
118 | if(ret[1] == SUCCESS){ //new character in buffer?
119 | printf("%d", manipulate_data(data[0])); //manipulate data and write it out
120 | }
121 |
122 | }
123 | }
