1 | #include "16F877A.h"
2 | #device adc=10
3 | #use delay(clock=20000000)
4 | #include <init_display.c>
5 | #include <display.c>
6 | #include <adc.c>
7 | #include <button.c>
8 |
9 |
10 | #fuses HS,NOWDT,NOPROTECT,NOLVP
11 |
12 |
13 | #define RESET_BUTTON PIN_D0
14 | #define STATE 0
15 | #define STATE_1 5
16 | #define STATE_2 10
17 | #define STATE_3 15
18 |
19 | #byte T1CON = 0x10
20 | #byte PIR1 = 0x0C
21 | #byte PIE1 = 0x8C
22 | #byte TMR1H = 0x0F
23 | #byte TMR1L = 0x0E
24 | #byte TMR1H = 0x0F
25 | #byte ITCON = 0x0B
26 | //
27 | ////BIT
28 | #bit TMR1ON = T1CON.0
29 | #bit TMR1CS = T1CON.1
30 | #bit TMR1PS0 = T1CON.5
31 | #bit TMR1PS1 = T1CON.4
32 | #bit TMR1IF = PIR1.0
33 | #bit TMR1IE = PIE1.0
34 | #bit GIE = ITCON.7
35 | #bit PEIE = ITCON.6
36 | int8 z_hoch=0,z_runter=0, t=0, wandler=0;
37 |
38 | #int_ext
39 | void isr()
40 | {
41 |
42 | clear_interrupt(INT_EXT);
43 |
44 | wandler++;
45 |
46 | }
47 |
48 |
49 |
50 | #int_TIMER1
51 | void TIMER1_isr()
52 | {
53 | TMR1IF=0;
54 | TMR1L=0;
55 | TMR1H=0x80; //Timer vorladen(65536-32768)
56 |
57 | t++;
58 |
59 |
60 | }
61 |
62 | void main() {
63 | set_tris_b(0x01);
64 | input(PIN_A0);
65 | //Variable
66 | int32 ampere=0,bat_volt=0,g_wert=0;
67 | boolean change=0;
68 | //Timer1
69 | TMR1L=0;
70 | TMR1H=0x80; //Timer vorladen(65536-32768)
71 | TMR1IF=0; //clear Timer flag
72 | TMR1ON=1; //Enable Timer1
73 | TMR1CS=1; //Use external osc
74 | TMR1PS0=0; //Prescale 1:1
75 | TMR1PS1=0;
76 | TMR1IE=1; //Enable Interrupt Timer overflow
77 | GIE = 1; //Enable Global Interrupt
78 | PEIE= 1; //Enable all unsmasked peripheral interrupts
79 |
80 | //Initalisieren LCD und ADC
81 | lcd_init();
82 | setup_adc_ports(RA0_ANALOG);
83 | setup_adc(ADC_CLOCK_INTERNAL);
84 | set_adc_channel(0);
85 |
86 | //Init interrupt
87 | ext_int_edge (H_TO_L);
88 | clear_interrupt(INT_EXT);
89 | enable_interrupts(INT_EXT);
90 |
91 |
92 |
93 |
94 | //Display
95 | while (TRUE) {
96 | //
97 | input(PIN_A0);
98 | input(PIN_E2);
99 | g_wert=grenz_abfrage();
100 | ampere=adc();
101 | // display(ampere);
102 | display_a(ampere);
103 | display_status(z_runter,z_hoch);
104 | delay_ms(200);
105 | bat_volt=adc1();
106 | display_b(bat_volt);
107 | if(ampere>g_wert) //Wenn Strom größer 3 A inventiere Strom ansonsten fahr weiter
108 | {
109 | change=!change;
110 | }
111 | if(change==0)
112 | {
113 | output_low(PIN_B3); //B1=T1,B2=T2,B3=T3,B4=T4
114 | output_low(PIN_B2);
115 | output_high(PIN_B1);
116 | output_high(PIN_B4);
117 |
118 | delay_ms(200);
119 | ampere=adc();
120 | if(ampere>g_wert)
121 | {
122 | output_low(PIN_B3); //B1=T1,B2=T2,B3=T3,B4=T4
123 | output_low(PIN_B2);
124 | output_low(PIN_B1);
125 | output_low(PIN_B4);
126 | }
127 | }
128 | else
129 | {
130 | output_low(PIN_B1);
131 | output_low(PIN_B4);
132 | output_high(PIN_B2);
133 | output_high(PIN_B3);
134 |
135 | delay_ms(200);
136 | ampere=adc();
137 | if(ampere>g_wert)
138 | {
139 | output_low(PIN_B3); //B1=T1,B2=T2,B3=T3,B4=T4
140 | output_low(PIN_B2);
141 | output_low(PIN_B1);
142 | output_low(PIN_B4);
143 | }
144 | }
145 |
146 |
147 | delay_ms(50);
148 | }
149 | }
