1 | int main(void)
2 | {
3 | /* Chip errata */
4 | CHIP_Init();
5 |
6 | /* Enable clocks required */
7 | CMU_ClockEnable(cmuClock_HFPER, true);
8 |
9 |
10 | /* Enabling clock to the I2C */
11 | CMU_ClockEnable(cmuClock_I2C0, true);
12 | CMU_ClockEnable(cmuClock_GPIO, true);
13 | CMU_ClockEnable(cmuClock_CORELE, true); //??
14 |
15 |
16 | /* Starting LFXO and waiting until it is stable */
17 | CMU_OscillatorEnable(cmuOsc_LFXO, true, true);
18 |
19 | /* Routing the LFXO clock to the RTC */
20 | CMU_ClockSelectSet(cmuClock_LFA,cmuSelect_LFXO);
21 | CMU_ClockEnable(cmuClock_RTC, true);
22 |
23 |
24 | /* Setup SysTick Timer for 1 msec interrupts */
25 | if (SysTick_Config(CMU_ClockFreqGet(cmuClock_CORE) / 1000)) while (1) ;
26 |
27 | /* Enable LCD without voltage boost */
28 | SegmentLCD_Init(false);
29 |
30 | setupI2C();
31 |
32 | Read_I2C_Data();
33 |
34 | ...
35 | }
36 |
37 | /**************************************************************************//**
38 | * @brief Setup I2C
39 | *****************************************************************************/
40 | void setupI2C(void)
41 | {
42 | // Using default settings
43 | I2C_Init_TypeDef i2cInit = I2C_INIT_DEFAULT;
44 |
45 | /* Using PD6 (SDA) and PD7 (SCL) */
46 | GPIO_PinModeSet(gpioPortD, 7, gpioModeWiredAndPullUpFilter, 1);
47 | GPIO_PinModeSet(gpioPortD, 6, gpioModeWiredAndPullUpFilter, 1);
48 |
49 |
50 | /* Enable pins at location 1 */
51 | I2C0->ROUTE = I2C_ROUTE_SDAPEN |
52 | I2C_ROUTE_SCLPEN |
53 | (1 << _I2C_ROUTE_LOCATION_SHIFT);
54 |
55 | /* Initializing the I2C */
56 | I2C_Init(I2C0, &i2cInit);
57 |
58 | I2C_Enable(I2C0, 1);
59 | }
60 |
61 | void Read_I2C_Data(){
62 | I2C_TransferReturn_TypeDef I2C_Status;
63 | uint8_t write_value[1];
64 | write_value[1]=128;
65 | I2C_TransferSeq_TypeDef seq;
66 | seq.addr = 0x58;
67 | seq.flags = I2C_FLAG_WRITE_WRITE;
68 | seq.buf[0].len = 1;
69 | seq.buf[0].data = 0;
70 | seq.buf[1].len = 1;
71 | seq.buf[1].data = write_value;
72 |
73 | I2C_Status = I2C_TransferInit(I2C0, &seq);
74 |
75 | while(I2C_Status == i2cTransferInProgress){
76 | I2C_Status=I2C_Transfer(I2C0);
77 | }
78 |
79 | int i=0;
80 | i++;
81 |
82 | }
