1 | // GPIO Init-Structure
2 | GPIO_InitTypeDef gpioInitStruct;
3 |
4 | // Enable GPIO D and E clocks
5 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE, ENABLE);
6 |
7 | //Create GPIO D InitStructure for used pins
8 | gpioInitStruct.GPIO_Mode = GPIO_Mode_AF;
9 | gpioInitStruct.GPIO_Speed = GPIO_Speed_100MHz;
10 | gpioInitStruct.GPIO_OType = GPIO_OType_PP;
11 | gpioInitStruct.GPIO_PuPd = GPIO_PuPd_UP;
12 | gpioInitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
13 | // Initialize Pins
14 | GPIO_Init(GPIOD, &gpioInitStruct);
15 |
16 | // Configure GPIO D pins as FSMC alternate functions
17 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
18 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
19 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
20 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
21 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC);
22 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
23 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
24 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
25 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
26 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
27 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
28 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
29 | GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
30 |
31 |
32 | // Create GPIO E InitStructure for used pins
33 | gpioInitStruct.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
34 | // Initialize pins
35 | GPIO_Init(GPIOE, &gpioInitStruct);
36 |
37 | //Configure GPIO E pins as FSMC alternate function
38 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource3, GPIO_AF_FSMC);
39 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource4, GPIO_AF_FSMC);
40 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource5, GPIO_AF_FSMC);
41 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource6, GPIO_AF_FSMC);
42 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource7, GPIO_AF_FSMC);
43 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource8, GPIO_AF_FSMC);
44 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_FSMC);
45 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource10, GPIO_AF_FSMC);
46 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource11, GPIO_AF_FSMC);
47 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_FSMC);
48 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_FSMC);
49 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource14, GPIO_AF_FSMC);
50 | GPIO_PinAFConfig(GPIOE, GPIO_PinSource15, GPIO_AF_FSMC);
51 |
52 | FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
53 | FSMC_NORSRAMTimingInitTypeDef FSMC_NORSRAMTimingInitStructureRead;
54 | FSMC_NORSRAMTimingInitTypeDef FSMC_NORSRAMTimingInitStructureWrite;
55 |
56 | // Enable FSMC Clock
57 | RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
58 |
59 | // Define Read timing parameters
60 | FSMC_NORSRAMTimingInitStructureRead.FSMC_AddressSetupTime = 0;
61 | FSMC_NORSRAMTimingInitStructureRead.FSMC_AddressHoldTime = 7;
62 | FSMC_NORSRAMTimingInitStructureRead.FSMC_DataSetupTime = 4;
63 | FSMC_NORSRAMTimingInitStructureRead.FSMC_BusTurnAroundDuration = 3;
64 | FSMC_NORSRAMTimingInitStructureRead.FSMC_CLKDivision = 2;
65 | FSMC_NORSRAMTimingInitStructureRead.FSMC_DataLatency = 1;
66 | FSMC_NORSRAMTimingInitStructureRead.FSMC_AccessMode = FSMC_AccessMode_A;
67 |
68 | // Define Write timing parameters
69 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_AddressSetupTime = 0;
70 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_AddressHoldTime = 6;
71 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_DataSetupTime = 1;
72 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_BusTurnAroundDuration = 3;
73 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_CLKDivision = 2;
74 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_DataLatency = 2;
75 | FSMC_NORSRAMTimingInitStructureWrite.FSMC_AccessMode = FSMC_AccessMode_A;
76 |
77 | // Define protocol type
78 | FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
79 | FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
80 | FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
81 | FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
82 | FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
83 | FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
84 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_High; // Don't care
85 | FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
86 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; // Don't care
87 | FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
88 | FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
89 | FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable;
90 | FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
91 | FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &FSMC_NORSRAMTimingInitStructureRead;
92 | FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &FSMC_NORSRAMTimingInitStructureWrite;
93 |
94 | // Initialize FSMC for read and write
95 | FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
96 |
97 | // Enable FSMC
98 | FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
