1 | /*
2 | Web client
3 |
4 | This sketch connects to a website (http://www.google.com)
5 | using an Arduino Wiznet Ethernet shield.
6 |
7 | Circuit:
8 | * Ethernet shield attached to pins 10, 11, 12, 13
9 |
10 | created 18 Dec 2009
11 | by David A. Mellis
12 | modified 9 Apr 2012
13 | by Tom Igoe, based on work by Adrian McEwen
14 |
15 | */
16 |
17 | #include <SPI.h>
18 | #include <Ethernet.h>
19 |
20 | // Enter a MAC address for your controller below.
21 | // Newer Ethernet shields have a MAC address printed on a sticker on the shield
22 | byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
23 | byte gateway[] = { 192,168,1,254};
24 | // the subnet:
25 | byte subnet[] = { 255, 255, 255, 0 };
26 | String str="";
27 |
28 | // if you don't want to use DNS (and reduce your sketch size)
29 | // use the numeric IP instead of the name for the server:
30 | IPAddress server(192,168,1,212);
31 |
32 | // numeric IP for Google (no DNS)
33 | //char server[] = "www.google.com"; // name address for Google (using DNS)
34 | //char server[] = "www.augilabs.de"; // name address for Google (using DNS)
35 |
36 |
37 | // Set the static IP address to use if the DHCP fails to assign
38 | IPAddress ip(192,168,1,177);
39 |
40 | // Initialize the Ethernet client library
41 | // with the IP address and port of the server
42 | // that you want to connect to (port 80 is default for HTTP):
43 | EthernetClient client;
44 |
45 | void setup() {
46 | // Open serial communications and wait for port to open:
47 | Serial.begin(9600);
48 | // while (!Serial) {
49 | // ; // wait for serial port to connect. Needed for Leonardo only
50 | // }
51 |
52 | // start the Ethernet connection:
53 | /*
54 | if (Ethernet.begin(mac) == 0) {
55 | Serial.println("Failed to configure Ethernet using DHCP");
56 | // no point in carrying on, so do nothing forevermore:
57 | // try to congifure using IP address instead of DHCP:
58 | Ethernet.begin(mac, ip);
59 | }
60 | */
61 | // initialize the ethernet device
62 | Ethernet.begin(mac, ip, gateway, subnet);
63 | // Ethernet.begin(mac, ip);
64 |
65 | // give the Ethernet shield a second to initialize:
66 | delay(1000);
67 | Serial.println("connecting...");
68 |
69 | // if you get a connection, report back via serial:
70 |
71 | if (client.connect(server, 80)) {
72 | Serial.print("connected to");
73 | Serial.println(server);
74 |
75 | // Make a HTTP request:
76 | /*
77 | client.print("GET /tgi/control.tgi?login");
78 | client.print("=");
79 | client.print("p:admin:admin");
80 | client.print("&port=list");
81 | client.println(" HTTP/1.1");
82 | client.println("User-Agent: Arduino");
83 | client.println("Accept: text/html,application/xhtml+xml,application/xml;q=0.9;q=0.8");
84 | client.println();
85 | client.stop();
86 | */
87 | client.println("GET /tgi/control.tgi?login=p:admin:admin&port=0110 HTTP/1.1 ");
88 |
89 | }
90 | else {
91 | // kf you didn't get a connection to the server:
92 | Serial.println("connection failed");
93 | }
94 |
95 | }
96 |
97 | void loop()
98 | {
99 | // Serial.println("Ich bin im LOOP");
100 |
101 | // if there are incoming bytes available
102 | // from the server, read them and print them:
103 | if (client.available()) {
104 | char c = client.read();
105 | Serial.print(c);
106 | }
107 |
108 | // if the server's disconnected, stop the client:
109 | if (!client.connected()) {
110 | Serial.println();
111 | Serial.println("disconnecting.");
112 | client.stop();
113 |
114 | // do nothing forevermore:
115 | while(true);
116 | }
117 | }
