1 | [c]#include <avr/io.h>
2 | #include <avr/interrupt.h>
3 | #include "rc5.h"
4 |
5 | #define F_CPU 16000000UL
6 |
7 | #ifndef RC5_INT
8 | #define RC5_INT RC5_INT0
9 | #endif /* RC5_INT */
10 |
11 | #ifndef RC5_PRESCALE
12 | #define RC5_PRESCALE 1024
13 | #endif /* RC5_PRESCALE */
14 |
15 | /* ******************************************************************************** */
16 |
17 | rc5_t rc5;
18 |
19 | /* ******************************************************************************** */
20 |
21 | #ifndef F_CPU
22 | #error Please define F_CPU
23 | #endif /* !F_CPU */
24 |
25 | /* µs for a whole bit of RC5 (first & second part) */
26 | #define RC5_BIT_US (64*27)
27 |
28 | #define RC5_TICKS \
29 | ((uint8_t) ((uint32_t) (F_CPU / 1000 * RC5_BIT_US / 1000 / RC5_PRESCALE)))
30 |
31 | #define RC5_DELTA \
32 | (RC5_TICKS / 6)
33 |
34 | typedef union
35 | {
36 | uint16_t w;
37 | uint8_t b[2];
38 | } code_t;
39 |
40 | static code_t code;
41 | static uint8_t rc5_addr;
42 |
43 | /* Number of Bits received so far */
44 | /* Number of Interrupts occured so far */
45 | static uint8_t nbits;
46 | static uint8_t nint;
47 |
48 | /* ******************************************************************************** */
49 |
50 | void rc5_init (uint8_t addr)
51 | {
52 | nint = 0;
53 | nbits = 0;
54 | rc5.flip = -1;
55 |
56 | rc5_addr = addr;
57 |
58 | #if (RC5_PRESCALE==1024)
59 | TCCR0 = (1 << CS02) | (1 << CS00);
60 | #elif (RC5_PRESCALE==256)
61 | TCCR0 = (1 << CS02);
62 | #elif (RC5_PRESCALE==64)
63 | TCCR0 = (1 << CS01) | (1 << CS00);
64 | #else
65 | #error This RC5_PRESCALE is not supported
66 | #endif /* RC5_PRESCALE */
67 |
68 | /* INTx on falling edge */
69 | /* clear pending INTx */
70 | /* enable INTx interrupt */
71 | #if (RC5_INT == RC5_INT0)
72 | MCUCR = (MCUCR | (1 << ISC01)) & ~ (1 << ISC00);
73 | GIFR = (1 << INTF0);
74 | GICR |= (1 << INT0);
75 | #elif (RC5_INT == RC5_INT1)
76 | MCUCR = (MCUCR | (1 << ISC11)) & ~ (1 << ISC10);
77 | GIFR = (1 << INTF1);
78 | GICR |= (1 << INT1);
79 | #else
80 | #error please define RC5_INT
81 | #endif /* RC5_INT */
82 | }
83 |
84 | /* ******************************************************************************** */
85 |
86 | ISR(TIMER0_OVF_vect)
87 | {
88 | TIMSK &= ~(1 << TOIE0);
89 |
90 | uint8_t _nbits = nbits;
91 | code_t _code = code;
92 |
93 | if (26 == _nbits)
94 | {
95 | _nbits++;
96 | _code.w <<= 1;
97 | }
98 |
99 | if (27 == _nbits
100 | && _code.b[1] >= 0x30 /* AGC == 3 */
101 | && 0 > rc5.flip)
102 | {
103 | uint8_t _rc5_code;
104 | uint8_t _rc5_addr;
105 | /* we do the bit manipulation stuff by hand, because of code size */
106 | _rc5_code = _code.b[0] & 0x3f; /* 0b00111111 : #0..#5 */
107 | _code.w <<= 2;
108 | _rc5_addr = _code.b[1] & 0x1f; /* 0b00011111 : #6..#10 */
109 |
110 | if (rc5_addr & 0x80
111 | || rc5_addr == _rc5_addr)
112 | {
113 | rc5.code = _rc5_code;
114 | rc5.addr = _rc5_addr;
115 | signed char flip = 0;
116 | if (_code.b[1] & 0x20) /* 0b00100000 : #11 */
117 | flip = 1;
118 | rc5.flip = flip;
119 | }
120 | }
121 |
122 | nint = 0;
123 | nbits = 0;
124 |
125 | /* INTx on falling edge */
126 | /* clear pending INTx */
127 | /* enable INTx interrupt */
128 | #if (RC5_INT == RC5_INT0)
129 | MCUCR = (MCUCR | (1 << ISC01)) & ~ (1 << ISC00);
130 | GIFR = (1 << INTF0);
131 | GICR |= (1 << INT0);
132 | #elif (RC5_INT == RC5_INT1)
133 | MCUCR = (MCUCR | (1 << ISC11)) & ~ (1 << ISC10);
134 | GIFR = (1 << INTF1);
135 | GICR |= (1 << INT1);
136 | #endif
137 | }
138 |
139 | /* ******************************************************************************** */
140 |
141 | #if (RC5_INT == RC5_INT0)
142 | ISR(INT0_vect)
143 | #elif (RC5_INT == RC5_INT1)
144 | ISR(INT1_vect)
145 | #endif /* RC5_INT */
146 | {
147 | code_t _code = code;
148 | uint8_t _nint = nint;
149 |
150 | uint8_t tcnt0 = TCNT0;
151 | TCNT0 = 0;
152 |
153 | if (0 == _nint)
154 | {
155 | /* INTx on both edges */
156 | #if (RC5_INT == RC5_INT0)
157 | MCUCR = (MCUCR | (1 << ISC00)) & ~ (1 << ISC01);
158 | #elif (RC5_INT == RC5_INT1)
159 | MCUCR = (MCUCR | (1 << ISC10)) & ~ (1 << ISC11);
160 | #endif /* RC5_INT */
161 |
162 | TIFR = (1 << TOV0);
163 | TIMSK |= (1 << TOIE0);
164 | _code.w = 0;
165 | }
166 | else
167 | {
168 | /* Number of bits of the just elapsed period */
169 | uint8_t n = 1;
170 |
171 | /* Bits received so far */
172 | uint8_t _nbits = nbits;
173 |
174 | /* is TCNT0 close to RC5_TICKS or RC5_TICKS/2 ? */
175 | if (tcnt0 > RC5_TICKS + RC5_DELTA)
176 | goto invalid;
177 | else if (tcnt0 < RC5_TICKS/2 - RC5_DELTA)
178 | goto invalid;
179 | else if (tcnt0 > RC5_TICKS - RC5_DELTA)
180 | n = 2;
181 | else if (tcnt0 > RC5_TICKS/2 + RC5_DELTA)
182 | goto invalid;
183 |
184 | /* store the just received 1 or 2 bits */
185 | do
186 | {
187 | _nbits++;
188 | if (_nbits & 1)
189 | {
190 | _code.w <<= 1;
191 | _code.b[0] |= _nint & 1;
192 | }
193 | }
194 | while (--n);
195 |
196 | if (0)
197 | {
198 | invalid:
199 |
200 | /* disable INTx, run into Overflow0 */
201 | #if (RC5_INT == RC5_INT0)
202 | GICR &= ~(1 << INT0);
203 | #elif (RC5_INT == RC5_INT1)
204 | GICR &= ~(1 << INT1);
205 | #endif /* RC5_INT */
206 |
207 | _nbits = 0;
208 | }
209 |
210 | nbits = _nbits;
211 | }
212 |
213 | code = _code;
214 | nint = 1+_nint;
215 | }
