1 | 0.00003182 putty.exe IRP_MJ_CREATE vSerial6 SUCCESS Options: Open
2 | 0.00002122 putty.exe IOCTL_SERIAL_GET_BAUD_RATE vSerial6 SUCCESS
3 | 0.00001369 putty.exe IOCTL_SERIAL_GET_LINE_CONTROL vSerial6 SUCCESS
4 | 0.00001061 putty.exe IOCTL_SERIAL_GET_CHARS vSerial6 SUCCESS
5 | 0.00001198 putty.exe IOCTL_SERIAL_GET_HANDFLOW vSerial6 SUCCESS
6 | 0.00001095 putty.exe IOCTL_SERIAL_GET_BAUD_RATE vSerial6 SUCCESS
7 | 0.00001095 putty.exe IOCTL_SERIAL_GET_LINE_CONTROL vSerial6 SUCCESS
8 | 0.00000992 putty.exe IOCTL_SERIAL_GET_CHARS vSerial6 SUCCESS
9 | 0.00001198 putty.exe IOCTL_SERIAL_GET_HANDFLOW vSerial6 SUCCESS
10 | 0.00000992 putty.exe IOCTL_SERIAL_SET_BAUD_RATE vSerial6 SUCCESS Rate: 9600
11 | 0.00001027 putty.exe IOCTL_SERIAL_SET_DTR vSerial6 SUCCESS
12 | 0.00001095 putty.exe IOCTL_SERIAL_SET_LINE_CONTROL vSerial6 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
13 | 0.00000992 putty.exe IOCTL_SERIAL_SET_CHAR vSerial6 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
14 | 0.00007323 putty.exe IOCTL_SERIAL_SET_HANDFLOW vSerial6 SUCCESS Shake:9 Replace:80 XonLimit:2048 XoffLimit:512
15 | 0.00001061 putty.exe IOCTL_SERIAL_SET_TIMEOUTS vSerial6 SUCCESS RI:1 RM:0 RC:0 WM:0 WC:0
16 | 29.29227667 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
17 | 0.00001779 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
18 | 0.00001814 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
19 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: I
20 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
21 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
22 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
23 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
24 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: S
25 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: C
26 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: H
27 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: O
28 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: R
29 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: Z
30 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
31 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
32 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: M
33 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: A
34 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: T
35 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: T
36 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: H
37 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: I
38 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: A
39 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: S
40 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
41 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
42 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
43 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
44 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
45 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
46 | 0.00931634 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
47 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
48 | 0.00001061 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
49 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
50 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
51 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
52 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
53 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
54 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
55 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
56 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
57 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
58 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
59 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
60 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
61 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
62 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
63 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
64 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
65 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
66 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
67 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
68 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
69 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
70 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 9
71 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 2
72 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
73 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
74 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
75 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 2
76 | 0.00939231 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
77 | 0.00001027 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
78 | 0.00000924 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
79 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
80 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
81 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
82 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
83 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
84 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
85 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
86 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
87 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
88 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
89 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
90 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
91 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
92 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
93 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
94 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
95 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
96 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
97 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: X
98 | 7.56461248 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
99 | 0.00001506 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
100 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
101 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
102 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
103 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
104 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
105 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
106 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
107 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
108 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
109 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
110 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
111 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
112 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
113 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
114 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
115 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
116 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
117 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
118 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
119 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
120 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
121 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
122 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
123 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
124 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
125 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
126 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
127 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
128 | 0.00824427 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
129 | 0.00001027 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
130 | 0.00000924 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: *
131 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
132 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
133 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
134 | 7.77480708 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
135 | 0.00001506 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
136 | 0.00000924 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
137 | 0.00000890 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: I
138 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
139 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
140 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
141 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
142 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: S
143 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: C
144 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: H
145 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: O
146 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: R
147 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: Z
148 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
149 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
150 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: M
151 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: A
152 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: T
153 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: T
154 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: H
155 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: I
156 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: A
157 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: S
158 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
159 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
160 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
161 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
162 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
163 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
164 | 0.00938546 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
165 | 0.00000924 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
166 | 0.00001027 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
167 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
168 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
169 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
170 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
171 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
172 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
173 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
174 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
175 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
176 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
177 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
178 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
179 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
180 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
181 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
182 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 7
183 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
184 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
185 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: D
186 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
187 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
188 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 9
189 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 2
190 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
191 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
192 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
193 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 2
194 | 0.00939812 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 6
195 | 0.00001027 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
196 | 0.00000924 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
197 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
198 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 0
199 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
200 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 1
201 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 5
202 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
203 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
204 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
205 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
206 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
207 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
208 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
209 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: <
210 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: 4
211 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
212 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
213 | 0.00000855 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
214 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: .
215 | 0.00000821 putty.exe IRP_MJ_READ vSerial6 SUCCESS Length 1: X
216 | 20.39890644 putty.exe IRP_MJ_READ vSerial6 CANCELLED Length 1
217 | 0.00003114 putty.exe IRP_MJ_CLEANUP vSerial6 SUCCESS
218 | 0.08510186 putty.exe IRP_MJ_CLOSE vSerial6 SUCCESS
