1 | #include <avr/io.h>
2 | #include <avr/delay.h>
3 | #include <avr/pgmspace.h>
4 |
5 | #define LCD_PORT PORTA
6 | #define LCD_DDR DDRA
7 | #define LCD_DB4 PA0
8 | #define LCD_DB5 PA1
9 | #define LCD_DB6 PA2
10 | #define LCD_DB7 PA3
11 | #define LCD_PIN_RS PA4
12 | #define LCD_PIN_E PA5
13 |
14 | #define CMD_EMS (1<<2)
15 | #define EMS_CURSOR_BACKWARD 0
16 | #define EMS_CURSOR_FORWARD (1<<1)
17 | #define EMS_NODISPLAYSHIFT 0
18 | #define EMS_DISPLAYSHIFT 1
19 |
20 | #define CMD_CLD 1
21 |
22 | #define CMD_RTH 2
23 |
24 | #define CMD_SHIFT (1<<4)
25 | #define SHIFT_CURSOR 0
26 | #define SHIFT_DISPLAY (1<<3)
27 | #define SHIFT_LEFT 0
28 | #define SHIFT_RIGHT (1<<2)
29 |
30 | #define CMD_CONFIG (1<<5)
31 | #define CONFIG_8BIT (1<<4)
32 | #define CONFIG_4BIT 0
33 | #define CONFIG_2LINE (1<<3)
34 | #define CONFIG_1LINE 0
35 | #define CONFIG_5X10 (1<<2)
36 | #define CONFIG_5X7 0
37 |
38 | #define CMD_DISPLAY (1<<3)
39 | #define DISPLAY_ON (1<<2)
40 | #define DISPLAY_OFF 0
41 | #define DISPLAY_CURSOR (1<<1)
42 | #define DISPLAY_NOCURSOR 0
43 | #define DISPLAY_BLINKING 1
44 | #define DISPLAY_NOBLINKING 0
45 |
46 | #define CMD_CURSORADDR (1<<7)
47 |
48 | #define POWERUP_TIME 40
49 |
50 |
51 | void enable()
52 | {
53 | LCD_PORT |= (1<<LCD_PIN_E);
54 | LCD_PORT &= ~(1<<LCD_PIN_E);
55 | }
56 |
57 | void sendNibble(uint8_t nibble)
58 | {
59 | LCD_PORT &= 0xF0;
60 | LCD_PORT |= nibble;
61 | enable();
62 | }
63 |
64 | void wd4(uint8_t data)
65 | {
66 | uint8_t nibble = (data >> 4); // high nibble speichern
67 | LCD_PORT |= (1<<LCD_PIN_RS); // Datenregister auswählen
68 | sendNibble(nibble);
69 | nibble = (data&0x0F); // low nibble speichern
70 | sendNibble(nibble);
71 | _delay_us(46);
72 | }
73 |
74 | void cmd4(uint8_t cmd)
75 | {
76 | uint8_t nibble = (cmd >> 4); // high nibble speichern
77 | LCD_PORT &= ~(1<<LCD_PIN_RS); // Steuerregister auswählen
78 | sendNibble(nibble);
79 | nibble = (cmd&0x0F); // low nibble speichern
80 | sendNibble(nibble);
81 | _delay_us(42);
82 | }
83 |
84 | void cldLCD162C()
85 | {
86 | cmd4(CMD_CLD);
87 | _delay_ms(2);
88 | }
89 |
90 | void rthLCD162C()
91 | {
92 | cmd4(CMD_RTH);
93 | _delay_ms(2);
94 | }
95 |
96 | void initLCD162C()
97 | {
98 |
99 | LCD_PORT = 0x00;
100 | LCD_DDR |= ((1<<LCD_DB4)|(1<<LCD_DB5)|(1<<LCD_DB6)|(1<<LCD_DB7)|(1<<LCD_PIN_E)|(1<<LCD_PIN_RS));
101 | _delay_ms(POWERUP_TIME);
102 | /* 4-bit Modus konfigurieren ------Function-Set 1*/
103 | LCD_PORT |= (1<<LCD_DB5);
104 | LCD_PORT &= ~(1<<LCD_DB4);
105 |
106 | _delay_ms(40);
107 | /* 4-bit Modus konfigurieren ------Function-Set 2*/
108 | LCD_PORT |= (1<<LCD_DB5);
109 | LCD_PORT &= ~(1<<LCD_DB4);
110 |
111 | _delay_ms(5);
112 | /* 4-bit Modus konfigurieren ------Function-Set 3*/
113 | LCD_PORT |= (1<<LCD_DB5);
114 | LCD_PORT &= ~(1<<LCD_DB4);
115 |
116 | /* 4-Bit Modus starten ... */
117 | LCD_PORT |= (1<<LCD_PIN_E);
118 | LCD_PORT &= ~(1<<LCD_PIN_E);
119 | _delay_ms(5);
120 |
121 | cmd4(CMD_CONFIG | CONFIG_2LINE);
122 | cmd4(CMD_DISPLAY | DISPLAY_OFF);
123 | cldLCD162C();
124 | cmd4(CMD_EMS | EMS_CURSOR_FORWARD);
125 | cmd4(CMD_DISPLAY | DISPLAY_ON);
126 | }
127 |
128 |
129 | void gotoXY(uint8_t x,uint8_t y)
130 | {
131 | cmd4(CMD_CURSORADDR | (y*0x40) | x);
132 | }
133 |
134 | void writeString(const char* str)
135 | {
136 | while(*str)writeChar(*str++);
137 | }
138 |
139 | void writeStringP(const char* str)
140 | {
141 | while(pgm_read_byte(str) != 0x00)writeChar(pgm_read_byte(str++));
142 | }
143 |
144 | void writeChar(char c)
145 | {
146 | wd4(c);
147 | }
148 |
149 | #include <string.h>
150 |
151 | void writeInteger(int i)
152 | {
153 | char buffer[12];
154 | itoa(i,buffer,10);
155 | writeString(buffer);
156 | }
157 |
158 | int main()
159 | {
160 | initLCD162C();
161 | writeStringP(PSTR("Hello World"));
162 | while(1){}
163 | }
