1 | //INIT NOR
2 | void FSMC_NOR_Init(void)
3 | {
4 | FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
5 | FSMC_NORSRAMTimingInitTypeDef p;
6 | GPIO_InitTypeDef GPIO_InitStructure;
7 |
8 | // Enable FSMC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks //
9 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
10 |
11 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
12 | RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG |
13 | RCC_APB2Periph_AFIO, ENABLE);
14 |
15 | /*-- GPIO Configuration ------------------------------------------------------*/
16 | /* NOR Data lines configuration */
17 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
18 | GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
19 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
20 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
21 | GPIO_Init(GPIOD, &GPIO_InitStructure);
22 |
23 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
24 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 |
25 | GPIO_Pin_14 | GPIO_Pin_15;
26 | GPIO_Init(GPIOE, &GPIO_InitStructure);
27 |
28 | /* NOR Address lines configuration */
29 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
30 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
31 | GPIO_Pin_14 | GPIO_Pin_15;
32 | GPIO_Init(GPIOF, &GPIO_InitStructure);
33 |
34 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 |
35 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
36 | GPIO_Init(GPIOG, &GPIO_InitStructure);
37 |
38 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
39 | GPIO_Init(GPIOD, &GPIO_InitStructure);
40 |
41 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
42 | GPIO_Init(GPIOE, &GPIO_InitStructure);
43 |
44 | /* NOE and NWE configuration */
45 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
46 | GPIO_Init(GPIOD, &GPIO_InitStructure);
47 |
48 | /* NE2 configuration */
49 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
50 | GPIO_Init(GPIOG, &GPIO_InitStructure);
51 |
52 |
53 |
54 | /*-- FSMC Configuration ----------------------------------------------------*/
55 | p.FSMC_AddressSetupTime = 0x05;
56 | p.FSMC_AddressHoldTime = 0x00;
57 | p.FSMC_DataSetupTime = 0x07;
58 | p.FSMC_BusTurnAroundDuration = 0x00;
59 | p.FSMC_CLKDivision = 0x00;
60 | p.FSMC_DataLatency = 0x00;
61 | p.FSMC_AccessMode = FSMC_AccessMode_B;
62 |
63 | FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;
64 | FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
65 | FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
66 | FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
67 | FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
68 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
69 | FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
70 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
71 | FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
72 | FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
73 | FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
74 | FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
75 | FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
76 | FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
77 | FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
78 |
79 | FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
80 |
81 | /* Enable FSMC Bank1_NOR Bank */
82 | FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM2, ENABLE);
83 | }
84 |
85 |
86 | //INIT TFT SSD1963
87 | void LCD_CtrlLinesConfig(void)
88 | {
89 | FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
90 | FSMC_NORSRAMTimingInitTypeDef p;
91 |
92 | GPIO_InitTypeDef GPIO_InitStructure;
93 |
94 | // Enable FSMC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks //
95 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
96 |
97 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
98 | RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG |
99 | RCC_APB2Periph_AFIO, ENABLE);
100 |
101 | // Set PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14),
102 | // PD.10(D15), PD.14(D0), PD.15(D1) as alternate
103 | // function push pull //
104 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
105 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
106 | GPIO_Pin_15;
107 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
108 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
109 | GPIO_Init(GPIOD, &GPIO_InitStructure);
110 |
111 | //Set PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7), PE.11(D8), PE.12(D9), PE.13(D10),
112 | // PE.14(D11), PE.15(D12) as alternate function push pull //
113 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
114 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
115 | GPIO_Pin_15;
116 | GPIO_Init(GPIOE, &GPIO_InitStructure);
117 |
118 | GPIO_WriteBit(GPIOE, GPIO_Pin_6, Bit_SET);
119 | //Set PF.00(A0 (RS)) as alternate function push pull //
120 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
121 | GPIO_Init(GPIOF, &GPIO_InitStructure);
122 |
123 | /// Set PG.12(NE4 (LCD/CS)) as alternate function push pull - CE3(LCD /CS) //
124 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
125 | GPIO_Init(GPIOG, &GPIO_InitStructure);
126 |
127 | //LCD Backlight PG8
128 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
129 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
130 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
131 | GPIO_Init(GPIOG, &GPIO_InitStructure);
132 | //LCD Backlight ON
133 | GPIO_SetBits(GPIOG, GPIO_Pin_8 );
134 |
135 |
136 |
137 | /*-- FSMC Configuration ------------------------------------------------------*/
138 | p.FSMC_AddressSetupTime = 1;
139 | p.FSMC_AddressHoldTime = 1;
140 | p.FSMC_DataSetupTime = 3;
141 | p.FSMC_BusTurnAroundDuration = 0;
142 | p.FSMC_CLKDivision = 1;
143 | p.FSMC_DataLatency = 0;
144 | p.FSMC_AccessMode = FSMC_AccessMode_A;
145 | /* FSMC_Bank1_NORSRAM4 configuration */
146 |
147 |
148 | FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4; //
149 | FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // ¹Ø±Õ×ÜÏ߸´ÓÃ
150 | FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM; //fsmc´¢´æģʽ
151 | FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b; // Êý¾Ý¿í¶È
152 | FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable; // ¹Ø±ÕÍ»·¢·ÃÎÊģʽ
153 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; // µÈ´ýÐźÅΪµÍµçƽ
154 | FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; // ¹Ø±Õ»·ÈÆģʽ
155 | FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; //
156 | FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; // д²Ù×÷ʹÄÜ
157 | FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; // ¹Ø±ÕµÈ´ýÐźÅ
158 | FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // ¹Ø±ÕÀ©Õ¹·½Ê½
159 | FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable; // ¹Ø±ÕÒì²½µÈ´ý
160 | FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; // ¹Ø±ÕÍ»·¢Ð´
161 | FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p; //
162 | FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p; //
163 |
164 | FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
165 |
166 | /* Enable FSMC Bank1_SRAM Bank */
167 | FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
168 |
169 |
170 | }
