1 | /*
2 | * _2_Punktregler_Temp_SMT_160_30.c
3 | *
4 | * Created: 19.09.2013 10:48:00
5 | * Author: Administrator
6 | */
7 |
8 |
9 | #include <avr/io.h>
10 | #include <avr/interrupt.h>
11 | #include "icp.h"
12 |
13 | /* Atmega8 Portdefinitionen */
14 | #define ICP_PIN PINB /* ICP1 GPIO Wert */
15 | #define ICP_PORT PORTB /* ICP1 GPIO Port */
16 | #define ICP_DDR DDRB /* ICP1 GPIO DDR */
17 | #define ICP_BIT PB0 /* ICP1 GPIO Pin */
18 | /*Timerdefinitionen*/
19 | #define ICP_OCR OCR1A /* ICP1 Ausgabe Vergleichsregister */
20 | #define ICP_OC_IE OCIE1A /* ICP1 Timer Ausgabe Vergleich EIN */
21 | #define ICP_OC_IF OCF1A /* ICP1 Timer Ausgabe Vergleichs Flag */
22 | #define ICP_IE TICIE1 /* ICP1 Unterbrechung EIN */
23 | #define ICP_IF ICF1 /* ICP1 Unterbrechungs Flag */
24 | #define ICP_CTL_A TCCR1A /* ICP1 Timer Kontrollreg */
25 | #define ICP_CTL TCCR1B /* ICP1 Unterbrechungs Kontrollreg */
26 | #define ICP_SENSE ICES1 /* ICP1 Unterbrechung bei (steigend/fallend) */
27 | #define ICP_PRESCALE ((0 << CS12) | (0 << CS11) | (1 << CS10)) /* Vorteiler /1 */
28 |
29 | #define ICP_START_SENSE (1 << ICP_SENSE) /* starte mit steigender Flanke */
30 | /*Demodulationsvaraiblen*/
31 | typedef unsigned int icp_timer_t; /* von der selben Bitlänge wie TCNT1 */
32 | icp_timer_t icp_start_time, icp_stop_time;
33 | icp_timer_t icp_period;
34 |
35 | /*speichert demodulierte Abtatswerte*/
36 | icp_sample_t icp_rx_q[ICP_RX_QSIZE];
37 |
38 | void icp_init(void)
39 | {
40 | /*
41 | * Nothing interesting to set in TCCR1A
42 | */
43 | ICP_CTL_A = 0;
44 |
45 | /*
46 | * Setting the OCR (timeout) to 0 allows the full TCNT range for
47 | * the initial period.
48 | */
49 | ICP_OCR = 0;
50 |
51 | /*
52 | * Set the interrupt sense and the prescaler
53 | */
54 | ICP_CTL = ICP_START_SENSE | ICP_PRESCALE;
55 |
56 | /*
57 | * Enable both the Input Capture and the Output Capture interrupts.
58 | * The latter is used for timeout (0% and 100%) checking.
59 | */
60 | TIMSK |= (1 << ICP_IE) | (1 << ICP_OC_IE);
61 |
62 | return;
63 | }
64 |
65 | /**
66 | * icp_rx_tail, icp_rx_head
67 | *
68 | * Queue state variables for icp_rx_q.
69 | *
70 | * The rx_head and rx_tail indices need to be wide enough to
71 | * accomodate [0:ICP_RX_QSIZE). Since QSIZE should generally
72 | * not be very large, these are hard-coded as single bytes,
73 | * which gets around certain atomicity concerns.
74 | */
75 | unsigned char icp_rx_tail; /* icp_rx_q insertion index */
76 | #if !ICP_ANALOG /* ICP_DIGITAL */
77 | unsigned char icp_rx_head; /* icp_rx_q retrieval index */
78 | #endif
79 |
80 |
81 | /**
82 | * icp_enq()
83 | *
84 | * Stores a new sample into the Rx queue.
85 | */
86 | #if __GCC__
87 | __inline__
88 | #else /* assume IAR */
89 | #pragma inline /* for next function */
90 | #endif
91 | static void icp_enq(icp_sample_t sample)
92 | {
93 | unsigned char t;
94 |
95 | t = icp_rx_tail;
96 | #if ICP_ANALOG
97 | icp_total += sample - icp_rx_q[t];
98 | #endif
99 | icp_rx_q[t] = sample;
100 | if (++t >= ICP_RX_QSIZE)
101 | t = 0;
102 | #if !ICP_ANALOG
103 | if (t != icp_rx_head) /* digital: Check for Rx overrun */
104 | #endif
105 | icp_rx_tail = t;
106 | return;
107 | }
108 |
109 | /**
110 | * icp_duty_compute()
111 | *
112 | * This function computes the value of (ICP_SCALE*pulsewidth)/period.
113 | * It is effectively a divide function, but uses a successive-approximation
114 | * (moral equivalent of long division) method which:
115 | * 1) Doesn't require 32-bit arithmetic (the numerator is 24+ bits nominal).
116 | * 2) For an 8-bit result, only needs 8 loops (instead of 16 for general 16/16).
117 | * 3) Compiles nicely from C.
118 | * We get away with this because we know that pulsewidth <= period, so
119 | * no more than log2(ICP_SCALE) bits are relevant.
120 | */
121 | #if __GCC__
122 | __inline__
123 | #else /* assume IAR */
124 | #pragma inline /* for next function */
125 | #endif
126 | static icp_sample_t icp_duty_compute(icp_timer_t pulsewidth, icp_timer_t period)
127 | {
128 | icp_sample_t r, mask;
129 |
130 | mask = ICP_SCALE >> 1;
131 | r = 0;
132 | do
133 | {
134 | period >>= 1;
135 | if (pulsewidth >= period)
136 | {
137 | r |= mask;
138 | pulsewidth -= period;
139 | }
140 | mask >>= 1;
141 | } while (pulsewidth != 0 && mask != 0);
142 | return(r);
143 | }
144 |
145 |
146 | ISR(TIMER1_CAPT_vect)
147 | {
148 | icp_timer_t icr, delta;
149 | unsigned char tccr1b;
150 |
151 | /*
152 | * Capture the ICR and then reverse the sense of the capture.
153 | * These must be done in this order, since as soon as the
154 | * sense is reversed it is possible for ICR to be updated again.
155 | */
156 | icr = ICR1; /* capture timestamp */
157 |
158 | do
159 | {
160 | tccr1b = ICP_CTL;
161 | ICP_CTL = tccr1b ^ (1 << ICP_SENSE); /* reverse sense */
162 |
163 | /*
164 | * If we were waiting for a start edge, then this is the
165 | * end/beginning of a period.
166 | */
167 | if ((tccr1b & (1 << ICP_SENSE)) == ICP_START_SENSE)
168 | {
169 | /*
170 | * Beginning of pulse: Compute length of preceding period,
171 | * and thence the duty cycle of the preceding pulse.
172 | */
173 | icp_period = icr - icp_start_time; /* Length of previous period */
174 | delta = icp_stop_time - icp_start_time; /* Length of previous pulse */
175 | icp_start_time = icr; /* Start of new pulse/period */
176 |
177 | /*
178 | * Update the timeout based on the new period. (The new period
179 | * is probably the same as the old, give or take clock drift.)
180 | * We add 1 to make fairly sure that, in case of competition,
181 | * the PWM edge takes precedence over the timeout.
182 | */
183 | ICP_OCR = icr + icp_period + 1; /* Move timeout window */
184 | TIFR = (1 << ICP_OC_IF); /* Clear in case of race */
185 |
186 | /*
187 | * Compute the duty cycle, and store the new reading.
188 | */
189 | icp_enq(icp_duty_compute(delta,icp_period));
190 |
191 | /*
192 | * Check for a race condition where a (very) short pulse
193 | * ended before we could reverse the sense above.
194 | * If the ICP pin is still high (as expected) OR the IF is
195 | * set (the falling edge has happened, but we caught it),
196 | * then we won the race, so we're done for now.
197 | */
198 | if ((ICP_PIN & (1 << ICP_BIT)) || (TIFR & (1 << ICP_IF)))
199 | break;
200 | }
201 | else
202 | {
203 | /*
204 | * Falling edge detected, so this is the end of the pulse.
205 | * The time is simply recorded here; the final computation
206 | * will take place at the beginning of the next pulse.
207 | */
208 | icp_stop_time = icr; /* Capture falling-edge time */
209 |
210 | /*
211 | * If the ICP pin is still low (as expected) OR the IF is
212 | * set (the transition was caught anyway) we won the race,
213 | * so we're done for now.
214 | */
215 | if ((!(ICP_PIN & (1 << ICP_BIT))) || (TIFR & (1 << ICP_IF)))
216 | break;
217 | }
218 | /*
219 | * If we got here, we lost the race with a very short/long pulse.
220 | * We now loop, pretending (as it were) that we caught the transition.
221 | * The Same ICR value is used, so the effect is that we declare
222 | * the duty cycle to be 0% or 100% as appropriate.
223 | */
224 | } while (1);
225 |
226 | return;
227 | }
228 |
229 |
230 | int main(void)
231 | {
232 |
233 | while(1)
234 | {
235 | //(Hier steht noch nichts!)
236 |
237 | }
238 | }
