1 | void getECUData(can_mb_conf_t *p_sc_mailbox_rx, can_mb_conf_t *p_sc_mailbox_tx) {
2 |
3 | /* Note: The CAN transceiver should be configured before initializing the CAN module. */
4 | can_reset_all_mailbox(CAN0);
5 | reset_mailbox_conf(p_sc_mailbox_rx);
6 |
7 | /* Init CAN0 Mailbox 1 to Reception Mailbox. */
8 | p_sc_mailbox_rx->ul_mb_idx = TEST1_CAN_COMM_MB_IDX + 1; //mailbox 1
9 | p_sc_mailbox_rx->uc_obj_type = CAN_MB_RX_MODE;
10 | p_sc_mailbox_rx->ul_id_msk = CAN_MAM_MIDvA_Msk | CAN_MAM_MIDvB_Msk; //CAN 2.0A + B
11 | if (!eepromData[EEPROM_CAN_11_29_BIT_ID]){
12 | p_sc_mailbox_rx->ul_id = CAN_MID_MIDvA(0x7E8); //get 7E8 from engine control module
13 | p_sc_mailbox_rx->uc_id_ver = 0; // 0/1: standard/extended frame
14 | }
15 | else {
16 | p_sc_mailbox_rx->ul_id = CAN_MID_MIDvB(0x7E8); //get 7E8 from engine control module
17 | p_sc_mailbox_rx->uc_id_ver = 1; // 0/1: standard/extended frame
18 | }
19 | can_mailbox_init(CAN0, p_sc_mailbox_rx);
20 |
21 |
22 | // RELEVANTE SENDEROUTINE AB HIER --------------------------------
23 |
24 |
25 | /* Init CAN0 Mailbox 0 to Transmit Mailbox. */
26 | p_sc_mailbox_tx->ul_mb_idx = TEST1_CAN_COMM_MB_IDX; //mailbox 0
27 | p_sc_mailbox_tx->uc_obj_type = CAN_MB_TX_MODE;
28 | p_sc_mailbox_tx->uc_tx_prio = TEST1_CAN0_TX_PRIO;
29 | p_sc_mailbox_tx->ul_id_msk = CAN_MAM_MIDvA_Msk | CAN_MAM_MIDvB_Msk; //CAN 2.0A + B
30 | can_mailbox_init(CAN0, p_sc_mailbox_tx);
31 |
32 | /* Write transmit information into mailbox. */
33 | if (!eepromData[EEPROM_CAN_11_29_BIT_ID]){
34 | p_sc_mailbox_tx->ul_id = CAN_MID_MIDvA(0x7DF); // engine control module
35 | p_sc_mailbox_tx->uc_id_ver = 0; // 0/1: standard/extended frame
36 | }
37 | else {
38 | p_sc_mailbox_tx->ul_id = CAN_MID_MIDvB(0x7DF); // engine control module
39 | p_sc_mailbox_tx->uc_id_ver = 1; // 0/1: standard/extended frame
40 | printf ("DEBUG: in getECUData(); 29bit frame mode\r\n");
41 | }
42 | //p_sc_mailbox_tx->ul_datal = ...; set by caller
43 | //p_sc_mailbox_tx->ul_datah = ...;
44 | p_sc_mailbox_tx->uc_length = MAX_CAN_FRAME_DATA_LEN; // 8bytes
45 | can_mailbox_write(CAN0, p_sc_mailbox_tx);
46 | can_enable_interrupt(CAN0, CAN_IER_MB1);
47 |
48 | /* Send out the information in the mailbox. */
49 | can_global_send_transfer_cmd(CAN0, CAN_TCR_MB0);
50 |
51 |
52 | // RELEVANTE SENDEROUTINE BIS HIER --------------------------------
53 |
54 |
55 | }
