Raspberry Pi mit NET IO App
Gast #3339764
ich habe mir die NET IO App heruntergeladen
(http://netio.davideickhoff.de) um mein Raspberry damit von meinem
Smartphone zu steuern. Nun ist das GUI für das Smartphone fertig und
schickt seine Daten auch erfolgreich zum Raspberry. Leider bin ich ein
totaler Anfänger im Bereich Python Programmierung und ich finde mein
Fehler einfach nicht...
#!/usr/bin/python
# Echo server program
import socket
import RPi.GPIO as GPIO
#Setup IO's
# Raspberry Pi Pins
GPIO.setmode(GPIO.BCM)
#Variablen Deklarierung
UP = 10
DOWN = 8
LEFT = 5
RIGHT = 3
DRIVE = 7
#GPIOS Deklarierung
GPIO.setup(UP, GPIO.OUT)
GPIO.setup(DOWN, GPIO.OUT)
GPIO.setup(LEFT, GPIO.OUT)
GPIO.setup(RIGHT, GPIO.OUT)
23
GPIO.setup(DRIVE, GPIO.OUT)
24
25
#Setup Socket
26
HOST = ''                 # Symbolic name meaning the local host
27
PORT = 54321              # Arbitrary non-privileged port
28
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
29
s.bind((HOST, PORT))
30
s.listen(1)
31
conn, addr = s.accept()
32
print 'Connected by', addr
33
34
#Loop
35
36
while 1:
37
data = conn.recv(1024)
38
print 'New Receive', data
39
#Haupt- if Schleife
40
if not data: break
41
print 'Received Data:', data
42
43
# Oben Remote
44
45
if data == 'UP on\n':
46
conn.send('on')
47
GPIO.output(UP, GPIO.HIGH)
48
print 'received on'
49
50
if data == 'UP off\n':
51
conn.send('off')
52
GPIO.output(UP, GPIO.LOW)
53
print 'received off'
54
55
#Unten Remote
56
57
if data == 'DOWN on\n':
58
conn.send('on')
59
GPIO.output(DOWN, GPIO.HIGH)
60
print 'received on'
61
62
if data == 'DOWN off\n':
63
conn.send('off')
64
GPIO.output(DOWN, GPIO.LOW)
65
66
67
#Links Remote
68
69
if data == 'LEFT on\n':
70
conn.send('on')
71
GPIO.output(LEFT, GPIO.HIGH)
72
print 'received on'
73
74
if data == 'LEFT off\n':
75
conn.send('off')
76
GPIO.output(LEFT, GPIO.LOW)
77
78
79
#Rechts Remote
80
81
if data == 'RIGHT on\n':
82
conn.send('on')
83
GPIO.output(RIGHT, GPIO.HIGH)
84
print 'received on'
85
86
if data == 'RIGHT off\n':
87
conn.send('off')
88
GPIO.output(RIGHT, GPIO.LOW)
89
90
91
#Drive on/off Remote
92
93
if data == 'DRIVE on\n':
94
conn.send('on')
95
GPIO.output(DRIVE, GPIO.HIGH)
96
print 'received on'
97
98
if data == 'DRIVE off\n':
99
conn.send('off')
100
GPIO.output(DRIVE, GPIO.LOW)
101
102
103
# end if
104
    else:
105
        conn.send('unknown command')
106
        print 'Unknown command:', data
107
    # continue with while 1
108
conn.close()
Da ich den Anfang und das Ende aus der DEMO-datei entnommen habe kann es
daran vermutlich nicht liegen, das script meckert ja erst immer bei den
IF-Bedingungen. Kann mir ja eventuell jemand weiterhelfen ?
#3339782
Hast du die Einrückungen wirklich so gesetzt?
In Python wird nämlich statt über Klammern über Einrückungen
strukturiert.
Also sollte das z.B. so aussehen:
while 1:
#Haupt- if Schleife
    if not data:
        break
Gast #3340118
Also habs gerade nochmal ausprobiert, es funktioniert immernoch nicht
Hier der Code nochmal
#!/usr/bin/python
import socket
#Setup IO's
# Raspberry Pi Pins
UP = 10
DOWN = 8
LEFT = 5
RIGHT = 3
DRIVE = 7
#GPIOS Deklarierung
23
24
25
#Setup Socket
26
27
28
29
30
s.listen(1)
31
32
33
34
#Loop
35
36
while 1:
37
38
39
#Haupt- if Schleife
40
  if not data: break
41
42
43
# Oben Remote
44
45
46
    conn.send('on')
47
48
    print 'received on'
49
50
51
    conn.send('off')
52
53
54
55
#Unten Remote
56
57
58
    conn.send('on')
59
60
    print 'received on'
61
62
63
    conn.send('off')
64
65
66
67
#Links Remote
68
69
70
    conn.send('on')
71
72
    print 'received on'
73
74
75
    conn.send('off')
76
77
78
79
#Rechts Remote
80
81
82
    conn.send('on')
83
84
    print 'received on'
85
86
87
    conn.send('off')
88
89
90
91
92
93
94
    conn.send('on')
95
96
    print 'received on'
97
98
99
    conn.send('off')
100
101
102
103
# end if
104
    else:
105
106
107
108
conn.close()
Es kommt der Fehler "Indentationerror: unexpected indent"
#3340165
Probier mal das angehaengte File aus.
Dann vergleiche mal dein File und das angehaengte und denke darueber
nach.
Und bitte erst dann weiterfragen.
Weil wenn man ueber eine Treppe gehen will und einen Tip bekommt wie man
eine Stufe ueberwindet, dann sollte man sich den Tip zu Herzen nehmen
und nich gleich bei der zweiten Stufe wieder fragen.
Da kann es dann durchaus vorkommen, dass man keinen Tip mehr
bekommt.....
Gruss.
Edit:
Ooops, irgendwie ist das File 2x reingerutscht.
