1 | #include <RCSwitch.h>
2 |
3 | #include <SPI.h>
4 | #include <Ethernet.h>
5 |
6 | // MAC address from Ethernet shield sticker under board
7 | byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
8 | IPAddress ip(192, 168, 1, 20); // IP address, may need to change depending on network
9 | EthernetServer server(80); // create a server at port 80
10 | RCSwitch mySwitch = RCSwitch();
11 | String HTTP_req; // stores the HTTP request
12 | void setup()
13 | {
14 | Ethernet.begin(mac, ip); // initialize Ethernet device
15 | server.begin(); // start to listen for clients
16 | Serial.begin(9600); // for diagnostics
17 | Serial.print("server is at ");
18 | Serial.println(Ethernet.localIP());
19 | mySwitch.enableTransmit(5);
20 | }
21 |
22 | void loop()
23 | {
24 | EthernetClient client = server.available(); // try to get client
25 |
26 | if (client) { // got client?
27 | boolean currentLineIsBlank = true;
28 | while (client.connected()) {
29 | if (client.available()) { // client data available to read
30 | char c = client.read(); // read 1 byte (character) from client
31 | HTTP_req += c; // save the HTTP request 1 char at a time
32 | // last line of client request is blank and ends with \n
33 | // respond to client only after last line received
34 | if (c == '\n' && currentLineIsBlank) {
35 | // send a standard http response header
36 | client.println("HTTP/1.1 200 OK");
37 | client.println("Content-Type: text/html");
38 | client.println("Connection: close");
39 | client.println();
40 | // send web page
41 | client.println("<!DOCTYPE html>");
42 | client.println("<html>");
43 | client.println("<head>");
44 | client.println("<title>Arduino Homecontrol</title>");
45 | client.println("</head>");
46 | client.println("<body>");
47 | client.println("<h1>SWITCH</h1>");
48 | client.println("<p>Click to switch on and off.</p>");
49 | client.println("<form method=\"get\">");
50 | ProcessCheckbox(client,0);
51 | client.println("</form>");
52 | client.println("<form method=\"get\">");
53 | ProcessCheckbox(client,1);
54 | client.println("</form>");
55 | client.println("</body>");
56 | client.println("</html>");
57 | //Serial.print(HTTP_req);
58 | HTTP_req = ""; // finished with request, empty string
59 | break;
60 | }
61 | // every line of text received from the client ends with \r\n
62 | if (c == '\n') {
63 | // last character on line of received text
64 | // starting new line with next character read
65 | currentLineIsBlank = true;
66 | }
67 | else if (c != '\r') {
68 | // a text character was received from client
69 | currentLineIsBlank = false;
70 | }
71 | } // end if (client.available())
72 | } // end while (client.connected())
73 | delay(1); // give the web browser time to receive the data
74 | client.stop(); // close the connection
75 | } // end if (client)
76 |
77 | }
78 |
79 | int stat[]={0,0};
80 | // switch LED and send back HTML for LED checkbox
81 | void ProcessCheckbox(EthernetClient cl,int num){
82 |
83 | int sender=0;
84 | String box="s";
85 | box+=num;
86 | box+="=111";
87 | if (HTTP_req.indexOf(box) > -1&&HTTP_req.indexOf(box) <7) {
88 | if(stat[num]){
89 | stat[num]=0;
90 | }else{
91 | stat[num]=1;
92 | }
93 |
94 | }
95 | if (stat[num]) { // switch LED on
96 |
97 | if(num==0){
98 | mySwitch.send(21,24);
99 | }else{
100 | mySwitch.send(16405,24);
101 | }
102 |
103 | // checkbox is checked
104 | cl.print("<input type=\"checkbox\" name=\"s");
105 | cl.print(num);
106 | cl.print("\" value=\"111\" \onclick=\"submit();\" checked>Switch");
107 | cl.println(num+1);
108 | }
109 | else { // switch LED off
110 |
111 | if(num==0){
112 | mySwitch.send(20,24);
113 | }else{
114 | mySwitch.send(16404,24);
115 | }
116 |
117 | // checkbox is unchecked
118 | cl.print("<input type=\"checkbox\" name=\"s");
119 | cl.print(num);
120 | cl.print("\" value=\"111\" \onclick=\"submit();\">Switch");
121 | cl.println(num+1);
122 | }
123 | }
