Hey there,
I am currently writing a call macro in NASM (elf64), which can be used
like:
dcall FUNCTION, param1, param2, param3, ...
The parameters are handled differently, depending on their type. Numbers
become immediates, strings need to be placed in the .data section, and
are
then referenced by its address (label).
1 | %macro dcall 1-*
2 | %define _j %1
3 | %assign __pnum 1
4 | %assign __stck 0
5 | %rep %0-1
6 | %ifstr %2
7 | section .data
8 | %%str: db %2, 0h
9 | section .text
10 | %if __pnum = 1
11 | mov rdi, %%str
12 | %elif __pnum = 2
13 | mov rsi, %%str
14 | %elif __pnum = 3
15 | mov rdx, %%str
16 | %elif __pnum = 4
17 | mov rcx, %%str
18 | %elif __pnum = 5
19 | mov r8, %%str
20 | %elif __pnum = 6
21 | mov r9, %%str
22 | %else
23 | push %%str
24 | %assign __stck __stck+8
25 | %endif
26 | %else
27 | %if __pnum = 1
28 | mov rdi, %2
29 | %elif __pnum = 2
30 | mov rsi, %2
31 | %elif __pnum = 3
32 | mov rdx, %2
33 | %elif __pnum = 4
34 | mov rcx, %2
35 | %elif __pnum = 5
36 | mov r8, %2
37 | %elif __pnum = 6
38 | mov r9, %2
39 | %else
40 | push %2
41 | %assign __stck __stck+8
42 | %endif
43 | %endif
44 | %assign __pnum __pnum+1
45 | %rotate 1
46 | %endrep
47 | xor rax, rax
48 | call _j
49 | %if __stck != 0
50 | add rsp, __stck
51 | %endif
52 | %endmacro
This works fine, unless there is more than one string parameter. In that
case, the local %%str label is not unique any more. Does anyone know how
to deal with this? Is there a way using macro contexts?
