1 | /*
2 | * sfuntmpl_basic.c: Basic 'C' template for a level 2 S-function.
3 | *
4 | * Copyright 1990-2013 The MathWorks, Inc.
5 | */
6 |
7 |
8 | /*
9 | * You must specify the S_FUNCTION_NAME as the name of your S-function
10 | * (i.e. replace sfuntmpl_basic with the name of your S-function).
11 | */
12 |
13 | #define S_FUNCTION_NAME odometrie
14 | #define S_FUNCTION_LEVEL 2
15 |
16 | /*
17 | * Need to include simstruc.h for the definition of the SimStruct and
18 | * its associated macro definitions.
19 | */
20 | #include "simstruc.h"
21 |
22 | #include <sys/types.h>
23 | #include <sys/stat.h>
24 | #include <fcntl.h>
25 | //#include <termios.h>
26 | #include <stdio.h>
27 | #include <stdlib.h>
28 | #include <string.h>
29 | //#include <unistd.h>
30 | #include <math.h>
31 |
32 |
33 |
34 | static void mdlInitializeSizes(SimStruct *S)
35 | {
36 | int_T nInputPorts = 0; /* number of input ports */
37 | int_T nOutputPorts = 1; /* number of output ports */
38 | int_T needsInput = 0; /* direct feed through */
39 |
40 | int_T inputPortIdx = 0;
41 | int_T outputPortIdx = 0;
42 |
43 | FILE *fmouse;
44 | char b[3];
45 |
46 | ssSetNumSFcnParams(S, 2); /* Number of expected parameters */
47 | if (ssGetNumSFcnParams(S) != ssGetSFcnParamsCount(S))
48 | return;
49 | }
50 |
51 |
52 | ssSetNumContStates( S, 0); /* number of continuous states */
53 | ssSetNumDiscStates( S, 0); /* number of discrete states */
54 |
55 |
56 | if (!ssSetNumInputPorts(S, nInputPorts)) return;
57 |
58 | if(!ssSetInputPortDimensionInfo(S, inputPortIdx, DYNAMIC_DIMENSION)) return;
59 |
60 | ssSetInputPortDirectFeedThrough(S, inputPortIdx, needsInput);
61 |
62 |
63 | if (!ssSetNumOutputPorts(S, nOutputPorts)) return;
64 |
65 | if(!ssSetOutputPortDimensionInfo(S,outputPortIdx,DYNAMIC_DIMENSION)) return;
66 |
67 |
68 | ssSetNumSampleTimes( S, 1); /* number of sample times */
69 |
70 | /*
71 | * Set size of the work vectors.
72 | */
73 | ssSetNumRWork( S, 0); /* number of real work vector elements */
74 | ssSetNumIWork( S, 0); /* number of integer work vector elements*/
75 | ssSetNumPWork( S, 0); /* number of pointer work vector elements*/
76 | ssSetNumModes( S, 0); /* number of mode work vector elements */
77 | ssSetNumNonsampledZCs( S, 0); /* number of nonsampled zero crossings */
78 |
79 | ssSetSimStateCompliance(S, USE_DEFAULT_SIM_STATE);
80 |
81 | ssSetOptions( S, 0); /* general options (SS_OPTION_xx) */
82 |
83 | } /* end mdlInitializeSizes */
84 |
85 |
86 |
87 | static void mdlInitializeSampleTimes(SimStruct *S)
88 | {
89 | ssSetSampleTime(S, 0, CONTINUOUS_SAMPLE_TIME);
90 | ssSetOffsetTime(S, 0, 0.0);
91 |
92 | }
93 |
94 |
95 |
96 | #define MDL_INITIALIZE_CONDITIONS /* Change to #undef to remove function */
97 | #if defined(MDL_INITIALIZE_CONDITIONS)
98 |
99 | static void mdlInitializeConditions(SimStruct *S)
100 | {
101 | }
102 | #endif /* MDL_INITIALIZE_CONDITIONS */
103 |
104 |
105 |
106 | #define MDL_START /* Change to #undef to remove function */
107 | #if defined(MDL_START)
108 |
109 | static void mdlStart(SimStruct *S)
110 | {
111 | FILE *fmouse;
112 | char b[3];
113 | }
114 | #endif /* MDL_START */
115 |
116 |
117 |
118 |
119 | static void mdlOutputs(SimStruct *S, int_T tid)
120 | {
121 | b[1] = u[0];
122 | }
123 |
124 |
125 |
126 | #define MDL_UPDATE /* Change to #undef to remove function */
127 | #if defined(MDL_UPDATE)
128 |
129 | static void mdlUpdate(SimStruct *S, int_T tid)
130 | {
131 | fread(b,sizeof(char),3,fmouse);
132 | }
133 | #endif /* MDL_UPDATE */
134 |
135 |
136 |
137 | #define MDL_DERIVATIVES /* Change to #undef to remove function */
138 | #if defined(MDL_DERIVATIVES)
139 | static void mdlDerivatives(SimStruct *S)
140 | {
141 | }
142 | #endif /* MDL_DERIVATIVES */
143 |
144 |
145 |
146 | static void mdlTerminate(SimStruct *S)
147 | {
148 | }
149 |
150 |
151 | /*=============================*
152 | * Required S-function trailer *
153 | *=============================*/
154 |
155 | #ifdef MATLAB_MEX_FILE /* Is this file being compiled as a MEX-file? */
156 | #include "simulink.c" /* MEX-file interface mechanism */
157 | #else
158 | #include "cg_sfun.h" /* Code generation registration function */
159 | #endif
