von
nlup (Gast)
Hallo ich hab mich an diese Anleitung gehalten
http://www.mikrocontroller.net/articles/STM8S-Discovery
aber, wenn ich den Programm Code bei mir einfüge bekomme ich drei
Errors. 1 | #include "stm8s.h" // (1)
| 2 |
| 3 | main() // (2)
| 4 | {
| 5 | GPIO_DeInit(GPIOD); // (3)
| 6 | GPIO_Init(GPIOD, GPIO_PIN_0,GPIO_MODE_OUT_PP_LOW_SLOW); // (4)
| 7 |
| 8 | while (1) // (5)
| 9 | {
| 10 | u16 i; // (6)
| 11 |
| 12 | for(i = 0; i < 60000; i++) // (7)
| 13 | {
| 14 | nop(); // (8)
| 15 | }
| 16 |
| 17 | GPIO_WriteReverse(GPIOD, GPIO_PIN_0); // (9)
| 18 | } // (10)
| 19 | }
1 | Compiling main.c...
| 2 | cxstm8 -istm8s_lib\inc +debug -pxp -no -l +mods0 -pp -i"C:\Program Files\COSMIC\CXSTM8_32K\Hstm8" -clDebug\ -coDebug\ main.c
| 3 | #error cpstm8 stm8s_lib\inc\stm8s_gpio.h:62(0) missing enumeration member
| 4 | main.c:
| 5 | The command: "cxstm8 -istm8s_lib\inc +debug -pxp -no -l +mods0 -pp
| 6 | -i"C:\Program Files\COSMIC\CXSTM8_32K\Hstm8" -clDebug\ -coDebug\
| 7 | main.c " has failed, the returned value is: 1
| 8 | exit code=1.
| 9 |
| 10 | main.o - 3 error(s), 0 warning(s)
von
nlup (Gast)
Hallo hat keiner eine Idee ? Ich komm da leider immer noch nicht weiter.
poste mal von deinem File "stm8s_gpio.h"
die Zeilen 45 bis 65
das müsste so aussehen :
1 | typedef enum
| 2 | {
| 3 | GPIO_MODE_IN_FL_NO_IT = (u8)0b00000000, /*!< Input floating, no external interrupt */
| 4 | GPIO_MODE_IN_PU_NO_IT = (u8)0b01000000, /*!< Input pull-up, no external interrupt */
| 5 | GPIO_MODE_IN_FL_IT = (u8)0b00100000, /*!< Input floating, external interrupt */
| 6 | GPIO_MODE_IN_PU_IT = (u8)0b01100000, /*!< Input pull-up, external interrupt */
| 7 | GPIO_MODE_OUT_OD_LOW_FAST = (u8)0b10100000, /*!< Output open-drain, low level, 10MHz */
| 8 | GPIO_MODE_OUT_PP_LOW_FAST = (u8)0b11100000, /*!< Output push-pull, low level, 10MHz */
| 9 | GPIO_MODE_OUT_OD_LOW_SLOW = (u8)0b10000000, /*!< Output open-drain, low level, 2MHz */
| 10 | GPIO_MODE_OUT_PP_LOW_SLOW = (u8)0b11000000, /*!< Output push-pull, low level, 2MHz */
| 11 | GPIO_MODE_OUT_OD_HIZ_FAST = (u8)0b10110000, /*!< Output open-drain, high-impedance level,10MHz */
| 12 | GPIO_MODE_OUT_PP_HIGH_FAST = (u8)0b11110000, /*!< Output push-pull, high level, 10MHz */
| 13 | GPIO_MODE_OUT_OD_HIZ_SLOW = (u8)0b10010000, /*!< Output open-drain, high-impedance level, 2MHz */
| 14 | GPIO_MODE_OUT_PP_HIGH_SLOW = (u8)0b11010000 /*!< Output push-pull, high level, 2MHz */
| 15 | }GPIO_Mode_TypeDef;
vermutlich hat das File einen Fehler in der letzten ENUM Anweisung
(wahrscheinlich ein Komma zuviel eingetragen)
1 | typedef enum
| 2 | {
| 14 | GPIO_MODE_OUT_PP_HIGH_SLOW = (u8)0b11010000, // hier ist ein Komma zuviel
| 16 |
| 17 | Gruss Uwe
von
nlup (Gast)
Tatsache da ist ein Komma zu viel.
Super ich danke dir.
