Forum: Mikrocontroller und Digitale Elektronik STM32F4 Filter function
von Martin H. (disjunction)
Ich möchte eine Function für das automatische Einstellen der Filter
erstellen. Ich habe dafür das CAN Beispiel vom Discovery Bard
modifiziert.
Eine Variante habe ich für 32 Bit Filter angefangen. Variante 2 soll
auch für 16 Bit Filter funktioniern.
void CAN_wrFilter (uint32_t ctrl, uint32_t id, uint32_t mask, uint8_t format)  {
   CAN_TypeDef *pCAN = (ctrl == 1) ? CAN1 : CAN2;
   uint32_t      CAN_msgId     = 0;
   uint32_t      CAN_msgMask   = 0;
  if ((mask != 0) && (CAN_filterRegisterIdx != 0)) {
    CAN_filterIdx[ctrl-1]++;
  }                                                 /* increase filter index  */
  if (CAN_filterIdx[ctrl-1] > 13) {                 /* check if Filter Memory is full*/
    return;
                                            /* Setup identifier information  IDE BIT */
  if (format == STANDARD_FORMAT)  {         /*   Standard ID                 */
      CAN_msgId   |= (uint32_t)(id << 21) | CAN_ID_STD;
      CAN_msgMask  = (uint32_t)(mask << 21);
  }  else  {                                /*   Extended ID                 */
      CAN_msgId   |= (uint32_t)(id <<  3) | CAN_ID_EXT;
      CAN_msgMask  = (uint32_t)(mask << 3);
  pCAN->FMR  |=   CAN_FMR_FINIT;                    /* set  InitMode for filter banks */
24
  pCAN->FA1R &=  ~(1UL << CAN_filterIdx[ctrl-1]);   /* deactivate filter              */
25
26
  pCAN->FS1R |=  (uint32_t)(1 << CAN_filterIdx[ctrl-1]);     /* set 32-bit scale configuration    */
27
28
29
  if  (mask == 0)  {                                          /* FBMx Bit  Identifier List mode     */
30
    pCAN->FM1R |= (uint32_t)(1 << CAN_filterIdx[ctrl-1]);     /* set to 32-bit Identifier List mode */
31
    if (CAN_filterRegisterIdx = 0)
32
      pCAN->sFilterRegister[CAN_filterIdx[ctrl-1]].FR1 = CAN_msgId;   /*  32-bit identifier   */
33
    else
34
      pCAN->sFilterRegister[CAN_filterIdx[ctrl-1]].FR2 = CAN_msgId;    /*  32-bit identifier   */
35
  }  else {
36
    pCAN->FM1R &= ~(uint32_t)(1 << CAN_filterIdx[ctrl-1]);    /* set to 32-bit Mask mode */
37
38
39
    else
40
      pCAN->sFilterRegister[CAN_filterIdx[ctrl-1]].FR2 = CAN_msgMask;    /*  32-bit identifier   */
41
    CAN_filterRegisterIdx++;
42
43
44
45
46
47
48
  pCAN->FFA1R &= ~(uint32_t)(1 << CAN_filterIdx[ctrl-1]);   /* assign filter to FIFO 0  */
49
  pCAN->FA1R  |=  (uint32_t)(1 << CAN_filterIdx[ctrl-1]);   /* activate filter          */
50
51
  pCAN->FMR &= ~CAN_FMR_FINIT;              /* reset initMode for filterBanks*/
52
53
[/c]
von Uwe Bonnes (Gast)
Fuer Ethernut unter nut/arch/cm3/dev/stm/stm32_can.c habe ich ein
CanAddFilter() Funktion geschreiben. Vielleicht hilfts weiter...
