1 | uint32_t HDP = 479;
2 | uint32_t HT = 531; //horiz. total period (display + non-display) in pixel clocks
3 | uint32_t HPS = 43; //byte of the non-display period between the start of the horiz. sync (LLINE) signal and first
4 | //display data = "hor. back porch + hor. pulse width?"
5 | uint32_t LPS = 8; //horizontal sync pulse (LLINE) start location in pixel clocks = "front porch?"
6 | uint32_t HPW = 10; //horizontal sync pulse width (= (HPW + 1) pixels )
7 | uint32_t VDP = 271;
8 | uint32_t VT = 288;
9 | uint32_t VPS = 12; //Vertical Sync Pulse Width = (VPW + 1) lines
10 | uint32_t FPS = 4; //vertical sync pulse (LFRAME) start location in lines.
11 | uint32_t VPW = 10;
12 |
13 |
14 | void Lcd_Init(void)
15 | {
16 | gpio_set_pin_high(LCD_CS); // LCD_CS = 1;
17 | gpio_set_pin_high(LCD_RD);
18 | gpio_set_pin_high(LCD_WR);
19 |
20 | gpio_set_pin_high(LCD_RES);
21 | mdelay(100);
22 | gpio_set_pin_low(LCD_RES);
23 | mdelay(5);
24 | gpio_set_pin_high(LCD_RES);
25 | mdelay(5);
26 | gpio_set_pin_high(LCD_CS);
27 | //gpio_set_pin_high(LCD_RD);
28 | //gpio_set_pin_high(LCD_WR);
29 | mdelay(5);
30 |
31 | gpio_set_pin_low(LCD_CS);
32 |
33 | LCD_WR_REG(0x00E2); //PLL multiplier, set PLL clock to 120M
34 | // LCD_WR_DATA(0x002d); //N=0x36 for 6.5M, 0x23 for 10M crystal
35 | LCD_WR_DATA(0x0023); //N=0x36 for 6.5M, 0x23 for 10M crystal
36 | LCD_WR_DATA(0x0002);
37 | LCD_WR_DATA(0x0004);
38 | mdelay(1);
39 |
40 | LCD_WR_REG(0x00E0);
41 | LCD_WR_DATA(0x0001); // 03
42 | mdelay(10);
43 |
44 |
45 | LCD_WR_REG(0x00E0);
46 | LCD_WR_DATA(0x0003); // 03
47 | mdelay(10);
48 |
49 | LCD_WR_REG(0x0001); // software reset
50 | mdelay(100);
51 |
52 | LCD_WR_REG(0x00E6); //PLL setting for PCLK, depends on resolution
53 | LCD_WR_DATA(0x0000);
54 | LCD_WR_DATA(0x00ff);
55 | LCD_WR_DATA(0x00be);
56 |
57 | LCD_WR_REG(0x00B0); //LCD SPECIFICATION
58 | LCD_WR_DATA(0x0020); //24bit to panel
59 | LCD_WR_DATA(0x0000);
60 | LCD_WR_DATA((HDP>>8)&0X00FF); //Set HDP
61 | LCD_WR_DATA(HDP&0X00FF);
62 | LCD_WR_DATA((VDP>>8)&0X00FF); //Set VDP
63 | LCD_WR_DATA(VDP&0X00FF);
64 | LCD_WR_DATA(0x0000);
65 | mdelay(5);
66 |
67 | LCD_WR_REG(0x00B4); //HSYNC ///531[d] = 213[h]
68 | LCD_WR_DATA((HT>>8) & 0x00FF); //Set HT 2
69 | LCD_WR_DATA(HT & 0x00FF);
70 | LCD_WR_DATA((HPS>>8) & 0x00FF); //Set HPS
71 | LCD_WR_DATA(HPS&0X00FF);
72 | LCD_WR_DATA(HPW); //Set HPW
73 | LCD_WR_DATA((LPS>>8)&0X00FF); //SetLPS
74 | LCD_WR_DATA(LPS&0X00FF);
75 | LCD_WR_DATA(0x0000);
76 |
77 | LCD_WR_REG(0x00B6); //VSYNC
78 | LCD_WR_DATA((VT>>8)&0X00FF); //Set VT
79 | LCD_WR_DATA(VT&0X00FF);
80 | LCD_WR_DATA((VPS>>8)&0X00FF); //Set VPS
81 | LCD_WR_DATA(VPS&0X00FF);
82 | LCD_WR_DATA(VPW); //Set VPW
83 | LCD_WR_DATA((FPS>>8)&0X00FF); //Set FPS
84 | LCD_WR_DATA(FPS&0X00FF);
85 |
86 |
87 | LCD_WR_REG(0x0036); //rotation
88 | LCD_WR_DATA(0x0000);
89 |
90 | LCD_WR_REG(0x3A); //Set Pixel Format
91 | LCD_WR_DATA(0x50);
92 |
93 |
94 | LCD_WR_REG(0x00F0); //pixel data interface
95 | LCD_WR_DATA(0x0003); // width: 16-bit (565 format)
96 |
97 | mdelay(5);
98 |
99 | LCD_WR_REG(0x0029); //display on
100 |
101 | LCD_WR_REG(0x00BE); //set PWM for B/L
102 | LCD_WR_DATA(0x0006);
103 | LCD_WR_DATA(0x00f0);
104 | LCD_WR_DATA(0x0001);
105 | LCD_WR_DATA(0x00f0);
106 | LCD_WR_DATA(0x0000);
107 | LCD_WR_DATA(0x0000);
108 |
109 | LCD_WR_REG(0x00d0);
110 | LCD_WR_DATA(0x000d);
111 |
112 | //----------LCD RESET---GPIO0-------------------//
113 | LCD_WR_REG(0x00B8);
114 | LCD_WR_DATA(0x0000); //GPIO3=input, GPIO[2:0]=output
115 | LCD_WR_DATA(0x0001); //GPIO0 normal
116 |
117 | LCD_WR_REG(0x00BA);
118 | LCD_WR_DATA(0x0000);
119 | }
