ich versuche die C-Funktion xTaskCreate() von FreeRTOS innerhalb meines
C++ Codes zu verwenden, allerdings komme ich dabei auf keinen grünen
Zweig.
1 | [...]
2 |
3 | /**
4 | * task. h
5 | *<pre>
6 | portBASE_TYPE xTaskCreate(
7 | pdTASK_CODE pvTaskCode,
8 | const char * const pcName,
9 | unsigned short usStackDepth,
10 | void *pvParameters,
11 | unsigned portBASE_TYPE uxPriority,
12 | xTaskHandle *pvCreatedTask
13 | );</pre>
14 | *
15 | * Create a new task and add it to the list of tasks that are ready to run.
16 | *
17 | **/
18 | #define xTaskCreate( pvTaskCode, pcName, usStackDepth, pvParameters, uxPriority, pxCreatedTask ) xTaskGenericCreate( ( pvTaskCode ), ( pcName ), ( usStackDepth ), ( pvParameters ), ( uxPriority ), ( pxCreatedTask ), ( NULL ), ( NULL )
19 | [...]
CPP-Header- und CPP-Source-Datei:
1 |
2 | /*
3 | CPP Header: "prl_task.hh"
4 | */
5 |
6 | #ifndef PRL_TASK_HH_
7 | #define PRL_TASK_HH_
8 |
9 | #include <stdio.h>
10 | #include <stdlib.h>
11 |
12 | #include <FreeRTOS.h>
13 | #include <task.h>
14 |
15 | #ifdef __cplusplus
16 |
17 |
18 | class CTask {
19 |
20 | public:
21 | CTask();
22 | ~CTask();
23 | void runTask1();
24 | void runTask2();
25 | };
26 |
27 | #endif
28 |
29 | #ifdef __cplusplus
30 | extern "C" {
31 | #endif
32 |
33 | /*
34 | * Wrapper Funktionen
35 | */
36 |
37 | void tskWrpT1(void* param);
38 | void tskWrpT2(void* param);
39 |
40 | #ifdef __cplusplus
41 | }
42 | #endif
43 | #endif /* PRL_TASK_HH_ */
1 | /*
2 | * prl_task.cc
3 | *
4 | */
5 |
6 | #include <prl_task.hh>
7 | #include <board_func.hh>
8 |
9 | void vTask1() {
10 |
11 | DO();
12 | }
13 |
14 |
15 | CTask::CTask() {
16 | }
17 |
18 | CTask::~CTask() {
19 | }
20 |
21 | void CTask::runTask1() {
22 |
23 | xTaskCreate(vTask1,"tsk1",1000,NULL,1,NULL);
24 | }
25 |
26 | void CTask::runTask2() {
27 | }
28 |
29 |
30 | void tskWrpT1(void* parm) {
31 |
32 | (static_cast<CTask*>(parm))->runTask1();
33 | }
34 |
35 | void tskWrpT2(void* parm) {
36 |
37 | (static_cast<CTask*>(parm))->runTask2();
38 | }
Rufe ich runTask1() auf und versuche mit xTaskCreate() einen Task zu
erzeugen, erhalte ich beim Kompilieren folgende Fehlermeldung:
1 | Function 'xTaskGenericCreate' could not be resolved
Ich habe bereits verschiedenste (Import-)Varianten ausprobiert, z.B. die
Header-Datei task.h in einen Bindungsblock auszulagern:
1 | extern "C" {
2 | #include <task.h>
3 | }
Hat jmd. noch eine Idee wie man da weiter vorgehen könnte?
- Florian
