1 | /*************************************************************************
2 | Title: example program for the Interrupt controlled UART library
3 | Author: Peter Fleury <pfleury@gmx.ch> http://jump.to/fleury
4 | File: $Id: test_uart.c,v 1.5 2012/09/14 17:59:08 peter Exp $
5 | Software: AVR-GCC 3.4, AVRlibc 1.4
6 | Hardware: any AVR with built-in UART, tested on AT90S8515 at 4 Mhz
7 |
8 | DESCRIPTION:
9 | This example shows how to use the UART library uart.c
10 |
11 | *************************************************************************/
12 | #include <stdlib.h>
13 | #include <avr/io.h>
14 | #include <avr/interrupt.h>
15 | #include <avr/pgmspace.h>
16 | #include <util/delay.h>
17 |
18 | #include "uart.h"
19 |
20 |
21 | /* define CPU frequency in Mhz here if not defined in Makefile */
22 | #ifndef F_CPU
23 | #define F_CPU 4000000UL
24 | #endif
25 |
26 | /* 9600 baud */
27 | #define UART_BAUD_RATE 9600
28 |
29 |
30 | int main(void)
31 | {
32 | unsigned int c;
33 | char buffer[7];
34 | int num=134;
35 |
36 | lcd_init(); // lcd init
37 | vWillkommen(); // Begrüssungstext
38 | _delay_ms(2000); // warte, damit Anzeige nicht gleich weg ist
39 | DDRA = 0xFF; // PORTA Ausgang
40 | PORTA = 0xFF; // Alle auf EIN
41 |
42 |
43 | /*
44 | * Initialize UART library, pass baudrate and AVR cpu clock
45 | * with the macro
46 | * UART_BAUD_SELECT() (normal speed mode )
47 | * or
48 | * UART_BAUD_SELECT_DOUBLE_SPEED() ( double speed mode)
49 | */
50 | uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU) );
51 |
52 | /*
53 | * now enable interrupt, since UART library is interrupt controlled
54 | */
55 | sei();
56 |
57 | /*
58 | * Transmit string to UART
59 | * The string is buffered by the uart library in a circular buffer
60 | * and one character at a time is transmitted to the UART using interrupts.
61 | * uart_puts() blocks if it can not write the whole string to the circular
62 | * buffer
63 | */
64 | uart_puts("String stored in SRAM\n");
65 |
66 | /*
67 | * Transmit string from program memory to UART
68 | */
69 | uart_puts_P("String stored in FLASH\n");
70 |
71 |
72 | /*
73 | * Use standard avr-libc functions to convert numbers into string
74 | * before transmitting via UART
75 | */
76 | itoa( num, buffer, 10); // convert interger into string (decimal format)
77 | uart_puts(buffer); // and transmit string to UART
78 |
79 |
80 | /*
81 | * Transmit single character to UART
82 | */
83 | uart_putc('\r');
84 |
85 | for(;;)
86 | {
87 | /*
88 | * Get received character from ringbuffer
89 | * uart_getc() returns in the lower byte the received character and
90 | * in the higher byte (bitmask) the last receive error
91 | * UART_NO_DATA is returned when no data is available.
92 | *
93 | */
94 | c = uart_getc();
95 | if ( c & UART_NO_DATA )
96 | {
97 | /*
98 | * no data available from UART
99 | */
100 | // hier etwas mit c machen z.B. auf PORT ausgeben
101 |
102 | }
103 | else
104 | {
105 | /*
106 | * new data available from UART
107 | * check for Frame or Overrun error
108 | */
109 | if ( c & UART_FRAME_ERROR )
110 | {
111 | /* Framing Error detected, i.e no stop bit detected */
112 | uart_puts_P("UART Frame Error: ");
113 | }
114 | if ( c & UART_OVERRUN_ERROR )
115 | {
116 | /*
117 | * Overrun, a character already present in the UART UDR register was
118 | * not read by the interrupt handler before the next character arrived,
119 | * one or more received characters have been dropped
120 | */
121 | uart_puts_P("UART Overrun Error: ");
122 | }
123 | if ( c & UART_BUFFER_OVERFLOW )
124 | {
125 | /*
126 | * We are not reading the receive buffer fast enough,
127 | * one or more received character have been dropped
128 | */
129 | uart_puts_P("Buffer overflow error: ");
130 |
131 |
132 | }
133 | /*
134 | * send received character back
135 | */
136 | uart_putc( (unsigned char)c );
137 | //+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
138 | // ab hier mein Teil der Programmierung
139 | //+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
140 | ID_Werte(&c); //Daten des ID Tag's auf dem LCD ausgeben *-*-*-*-*-*-*-*-*-*-*-*-*-*
141 |
142 | /* void ID_Werte(char *wert)
143 | {
144 | lcd_clear();
145 | // itoa(WERT,Value,10); // umwandeln einer dez.-Zahl (WERT zB 11) in ASCII-Zeichen 11 (LCD kann nur ASCII-Zeichen ausgeben!!!)
146 | // itoa(-12,Value,10); // umwandeln der Zahl -12 in ASCII -12 (LCD kann nur ASCII-Zeichen ausgeben!!!)
147 | lcd_pos(2,0);
148 | lcd_text("ID-Wert:");
149 | lcd_pos(3,10);
150 | lcd_text(wert);
151 | }
152 | */
153 | //+++++++++++++++++++++++++++++ ENDE meiner Programmierung +++++++++++++++++++++++++++++++++
154 | }
155 | }
156 |
157 | }
