PIC24FJ Flash
Gast #3394760
ich nochmal hab die Seite gefunde.
http://www.mikroe.com/download/eng/documents/compilers/mikroc/pro/dspic/help/flash_memory_library.htm
Probier grad erstmal das Flash zu löschen aber Controller stürzt ab.
Hier der Code der aufgerufen wird address ist im moment auf 0x10000
gesetzt.
Wer kann mir da helfen.
oid FLASH_Write(unsigned long address, unsigned int *data_)
unsigned int iArr[64] = {'m', 'i', 'k', 'r', 'o', 'E', 'l', 'e', 'k',
't', 'r', 'o', 'n', 'i', 'k', 'a'};
void * pv1;
pv1 = iArr;
FLASH_Write(address, pv1);
void FLASH_Erase(unsigned long address)
    unsigned long flash_address;
    flash_address=address;
    int i=0;
  for (i = 0; i < 4; i++)
       __delay_ms(40);
    FLASH_Erase(flash_address+i*4);
    __delay_ms(100);
Gast #3398413
Fehlermeldung in der Zeile : dst = (( long )data[i * 3 + 2] << 16) |
isr_Timer1.c:413:16: error: incompatible types when assigning to type
'long int[64]' from type 'long int'
was mache ich falsch.
  unsigned char iArr[16] = {'1', '1', '1', '1', '1', '1', '1', '1',
'1'};
   //char iArr=0x31;
    data=iArr;
hw_flashWriteRow(addr, ( unsigned char*) data);
    IEC3bits.INT4IE=1;        //Taster 4 Int3 sperren
    IFS3bits.INT4IF   = 0;      // Clear Output Compare interrupt flag
 // write 192 bytes to a row
    void hw_flashWriteRow(long addr1, unsigned char* data)
       int i;
      long dst[_FLASH_ROW];
       //int dst;
       for (i = 0; i < _FLASH_ROW; i++)
       //    for (i = 0; i < 192; i++)
                    ((long )data[i * 3 + 1] << 8)  |
                    (( long )data[i * 3 + 0] << 0);
       _write_flash24(addr1, dst);
        // read up to 192 bytes from a row
   void hw_flashReadRow(long addr, void* data, int bytes)
       _memcpy_p2d24(data, addr, bytes);
