1 | U-Boot 1.1.4 (Dec 4 2012 - 11:19:40)
2 |
3 | AP121 (ar9330) U-boot
4 |
5 | DRAM: 32 MB
6 | led turning on for 1s...
7 | id read 0x100000ff
8 | flash size 4194304, sector count = 64
9 | Flash: 4 MB
10 | Using default environment
11 |
12 | In: serial
13 | Out: serial
14 | Err: serial
15 | Net: ag7240_enet_initialize...
16 | No valid address in Flash. Using fixed address
17 | No valid address in Flash. Using fixed address
18 | : cfg1 0x5 cfg2 0x7114
19 | eth0: 00:03:7f:09:0b:ad
20 | ag7240_phy_setup
21 | eth0 up
22 | : cfg1 0xf cfg2 0x7214
23 | eth1: 00:03:7f:09:0b:ad
24 | athrs26_reg_init_lan
25 | ATHRS26: resetting s26
26 | ATHRS26: s26 reset done
27 | ag7240_phy_setup
28 | eth1 up
29 | eth0, eth1
30 | Autobooting in 1 seconds
31 | ## Booting image at 9f020000 ...
32 | Uncompressing Kernel Image ... OK
33 |
34 | Starting kernel ...
35 |
36 | [ 0.000000] Linux version 3.3.8 (piie@zopiie) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #3 Thu Jan 3 17:05:21 CET 2013
37 | [ 0.000000] bootconsole [early0] enabled
38 | [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
39 | [ 0.000000] SoC: Atheros AR9330 rev 1
40 | [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
41 | [ 0.000000] Determined physical RAM map:
42 | [ 0.000000] memory: 02000000 @ 00000000 (usable)
43 | [ 0.000000] Initrd not found or empty - disabling initrd
44 | [ 0.000000] Zone PFN ranges:
45 | [ 0.000000] Normal 0x00000000 -> 0x00002000
46 | [ 0.000000] Movable zone start PFN for each node
47 | [ 0.000000] Early memory PFN ranges
48 | [ 0.000000] 0: 0x00000000 -> 0x00002000
49 | [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
50 | [ 0.000000] Kernel command line: board=TL-WR703N console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
51 | [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
52 | [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
53 | [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
54 | [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
55 | [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
56 | [ 0.000000] Writing ErrCtl register=00000000
57 | [ 0.000000] Readback ErrCtl register=00000000
58 | [ 0.000000] Memory: 29156k/32768k available (2084k kernel code, 3612k reserved, 397k data, 208k init, 0k highmem)
59 | [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
60 | [ 0.000000] NR_IRQS:51
61 | [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
62 | [ 0.080000] pid_max: default: 32768 minimum: 301
63 | [ 0.080000] Mount-cache hash table entries: 512
64 | [ 0.090000] NET: Registered protocol family 16
65 | [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
66 | [ 0.100000] MIPS: machine is TP-LINK TL-WR703N v1
67 | [ 0.350000] bio: create slab <bio-0> at 0
68 | [ 0.360000] Switching to clocksource MIPS
69 | [ 0.360000] NET: Registered protocol family 2
70 | [ 0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
71 | [ 0.370000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
72 | [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
73 | [ 0.380000] TCP: Hash tables configured (established 1024 bind 1024)
74 | [ 0.390000] TCP reno registered
75 | [ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
76 | [ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
77 | [ 0.400000] NET: Registered protocol family 1
78 | [ 0.430000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
79 | [ 0.430000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
80 | [ 0.440000] msgmni has been set to 56
81 | [ 0.440000] io scheduler noop registered
82 | [ 0.450000] io scheduler deadline registered (default)
83 | [ 0.450000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
84 | [ 0.460000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
85 | [ 0.460000] console [ttyATH0] enabled, bootconsole disabled
86 | [ 0.460000] console [ttyATH0] enabled, bootconsole disabled
87 | [ 0.480000] m25p80 spi0.0: found en25q32b, expected m25p80
88 | [ 0.480000] m25p80 spi0.0: en25q32b (4096 Kbytes)
89 | [ 0.490000] 5 tp-link partitions found on MTD device spi0.0
90 | [ 0.490000] Creating 5 MTD partitions on "spi0.0":
91 | [ 0.500000] 0x000000000000-0x000000020000 : "u-boot"
92 | [ 0.510000] 0x000000020000-0x0000000fe3b0 : "kernel"
93 | [ 0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
94 | [ 0.520000] 0x0000000fe3b0-0x0000003f0000 : "rootfs"
95 | [ 0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
96 | [ 0.540000] mtd: partition "rootfs" set to be root filesystem
97 | [ 0.550000] mtd: partition "rootfs_data" created automatically, ofs=370000, len=80000
98 | [ 0.550000] 0x000000370000-0x0000003f0000 : "rootfs_data"
99 | [ 0.560000] 0x0000003f0000-0x000000400000 : "art"
100 | [ 0.570000] 0x000000020000-0x0000003f0000 : "firmware"
101 | [ 0.590000] ag71xx_mdio: probed
102 | [ 0.590000] eth0: Atheros AG71xx at 0xb9000000, irq 4
103 | [ 1.150000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
104 | [ 1.160000] TCP cubic registered
105 | [ 1.160000] NET: Registered protocol family 17
106 | [ 1.160000] 8021q: 802.1Q VLAN Support v1.8
107 | [ 1.170000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
108 | [ 1.180000] Freeing unused kernel memory: 208k freed
109 | - preinit -
110 | Press the [f] key and hit [enter] to enter failsafe mode
111 | - regular preinit -
112 | [ 6.560000] JFFS2 notice: (404) jffs2_build_xattr_subsystem: complete building xattr subsystem, 18 of xdatum (0 unchecked, 17 orphan) and 25 of xref (0 dead, 17 orphan) found.
113 | switching to jffs2
114 | - init -
115 |
116 | Please press Enter to activate this console. [ 7.660000] Compat-drivers backport release: compat-drivers-2012-09-04-2-gddac993
117 | [ 7.670000] Backport based on wireless-testing.git master-2012-09-07
118 | [ 7.680000] compat.git: wireless-testing.git
119 | [ 7.710000] cfg80211: Calling CRDA to update world regulatory domain
120 | [ 7.720000] cfg80211: World regulatory domain updated:
121 | [ 7.720000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
122 | [ 7.730000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
123 | [ 7.740000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
124 | [ 7.740000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
125 | [ 7.750000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
126 | [ 7.760000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
127 | [ 8.210000] usbcore: registered new interface driver usbfs
128 | [ 8.220000] usbcore: registered new interface driver hub
129 | [ 8.220000] usbcore: registered new device driver usb
130 | [ 8.880000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
131 | [ 8.890000] cfg80211: Calling CRDA for country: US
132 | [ 8.890000] cfg80211: Regulatory domain changed to country: US
133 | [ 8.900000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
134 | [ 8.910000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
135 | [ 8.910000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
136 | [ 8.920000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
137 | [ 8.930000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
138 | [ 8.940000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
139 | [ 8.940000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
140 | [ 9.550000] ip_tables: (C) 2000-2006 Netfilter Core Team
141 | [ 9.680000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
142 | [ 9.680000] ehci-platform ehci-platform: Generic Platform EHCI Controller
143 | [ 9.690000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
144 | [ 9.730000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
145 | [ 9.750000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
146 | [ 9.750000] hub 1-0:1.0: USB hub found
147 | [ 9.750000] hub 1-0:1.0: 1 port detected
148 | [ 9.780000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
149 | [ 10.020000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
150 | [ 10.130000] usb 1-1: new high-speed USB device number 2 using ehci-platform
151 | [ 10.260000] usbcore: registered new interface driver snd-usb-audio
152 | [ 13.330000] device eth0 entered promiscuous mode
