1 | const int idelay = 1000; //for delay
2 |
3 | unsigned long int* RCGCUART; //address of Rcgcuart
4 | unsigned long int* RCGCGPIO; //..
5 | unsigned long int* GPIOAFSEL; //..
6 | unsigned long int* GPIOPCTL; //..
7 | unsigned long int* UARTCTL; //..
8 | unsigned long int* UARTIBRD; //..
9 | unsigned long int* UARTFBRD; //..
10 | unsigned long int* UARTLCRH; //..
11 | unsigned long int* PPUART; //..
12 |
13 | //1.Enable UART via RCGCUART Register page 333
14 | //Base address 0x400F.E000 is a System Control Register as seen on page 97
15 | //Offset address 0x618 Adress for the RCGCUART Register
16 | //Addition gives the adresse: 0x400F.E618
17 | //to set the UART4 the fifth Bit must be set.
18 | RCGCUART = 0x400FE618;
19 | //*RCGCUART &= 0xEF; // Disable UART4
20 | *RCGCUART |= 0x10; //Enable UART4
21 | delay_ms(idelay);
22 |
23 | //2.Enable the clock to the appropiate GPIO module via RCGCGPIO page 328
24 | //The Base address is 0x400F.E000
25 | //The offset address is 0x608
26 | //That gives: 0x400F.E608
27 | //PORTC is the third Bit so : 0x4 = 0b100
28 | RCGCGPIO = 0x400FE608;
29 | *RCGCGPIO |= 0x4;
30 | delay_ms(idelay);
31 |
32 | //3.Setting the GPIO AFSEL for the appropiate PINs
33 | //GPIO PORTC APB Base is on 0x4000.6000
34 | //Offset is 0x420 -> that gives in total 0x4000.6420
35 | //PORTC4/5 Uart4 is on Pin 36/35
36 | GPIOAFSEL = 0x40006420;
37 | *GPIOAFSEL |= 0x30;
38 | delay_ms(idelay);
39 |
40 | //4.Configure Current level and slew rate control
41 | //2mA default
42 | //Slew rate default no slew rate control
43 |
44 | //5.Configure PMCn fields in the GPIOPCTL register to asign the UART Signals to the appropiate pin
45 | //Base of the GPIOPCTL register is 0x4000.6000 for PORTC APB
46 | //The offset is 0x52C
47 | //That gives 0x4000652C
48 | //Write the appropiate value for UART4 into the Pin4 and Pin5 fields. Should be 0x2;
49 | GPIOPCTL = 0x4000652C;
50 | *GPIOPCTL |= 0x00110000;
51 | delay_ms(idelay);
52 |
53 | //Configuration of the UART:
54 | //1.Disable UART
55 | //Disabling by resetting UARTEN in the UARTCTL register
56 | //Base address is 0x4001.0000
57 | //The offset address is 0x030
58 | //UARTEN is the first Bit
59 | UARTCTL = 0x40010030;
60 | *UARTCTL &= 0xFFFFFFFE;
61 | *UARTCTL |= 0x300;
62 | delay_ms(idelay);
63 |
64 | //2.BAUDRATE
65 | //BRD = 16000000 / (16 * 115200) = 8,6805°
66 | //UARTFBRD = integer(0,6805 * 64 + 0.5) = 44
67 | //UARTIBRD base is on 0x4001.0000
68 | //and offset is 0x024
69 | //UARTFBRD base is on 0x4001.0000
70 | //and offset is 0x028
71 | UARTIBRD = 0x40010024;
72 | *UARTIBRD |= 0x8;
73 | UARTFBRD = 0x40010028;
74 | *UARTFBRD |= 0x2C;
75 | delay_ms(idelay);
76 |
77 | //3.data length, parity and stop bit
78 | //This is set in the UARTLCRH register
79 | //The base address is 0x4001.0000
80 | //The offset address is 0x02C
81 | // Bit 5 and 6 are the data length. 0x3 is 8 bits.
82 | // no parity and 1 stop bit default
83 | UARTLCRH = 0x4001002C;
84 | *UARTLCRH |= 0x60; //0b01100000
85 | delay_ms(idelay);
86 |
87 | //4.Enable the UART4 again
88 | UARTCTL = 0x40010030;
89 | *UARTCTL |= 0x00000001;
90 | delay_ms(idelay);
91 |
92 | //Transmit on UARTDR register
93 | //Base address for UART4 0x4001.0000
94 | //offset address is 0x00
95 | unsigned long int* UARTDR = 0x40010000;
96 | *UARTDR |= 0x41; //Letter A
