1 | void Config_Timer_TIM2(TIM_TimeBaseInitTypeDef *TIM_TimeBaseStructure, NVIC_InitTypeDef *NVIC_InitStructure)
2 | {
3 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
4 |
5 |
6 | /* Enable the Timer2 Interrupt */
7 | NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
8 |
9 | NVIC_InitStructure->NVIC_IRQChannel = TIM2_IRQn; // configure the Timer2 interrupts
10 | NVIC_InitStructure->NVIC_IRQChannelPreemptionPriority = 0x0F; // sets the priority group of the TIMER2 interrupts
11 | NVIC_InitStructure->NVIC_IRQChannelSubPriority = 0; // set the subpriority inside the group
12 | NVIC_InitStructure->NVIC_IRQChannelCmd = ENABLE; // TIMER2 interrupts are globally enabled
13 | NVIC_Init(NVIC_InitStructure);
14 |
15 | /* Configure Timer which is every 1 ms active*/
16 | TIM_DeInit(TIM2);
17 | TIM_TimeBaseStructInit(TIM_TimeBaseStructure);
18 |
19 | /* Time base configuration */
20 | TIM_TimeBaseStructure->TIM_Prescaler = 360 - 1; // 72 MHz / 360 = 200 khz
21 | TIM_TimeBaseStructure->TIM_Period = 200 - 1; // (1/200khz) * 200 = 1 ms;
22 | TIM_TimeBaseStructure->TIM_ClockDivision = TIM_CKD_DIV1;
23 | TIM_TimeBaseStructure->TIM_CounterMode = TIM_CounterMode_Up;
24 | TIM_TimeBaseInit(TIM2, TIM_TimeBaseStructure);
25 |
26 | //TIM_PrescalerConfig(TIM2, 360-1 , TIM_PSCReloadMode_Immediate);
27 |
28 | /* Enable TIM2 Update Interrupt */
29 | TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
30 |
31 | /* Enable TIM2 */
32 | TIM_Cmd(TIM2,ENABLE);
33 | }
34 |
35 | void Config_Timer_TIM3(TIM_TimeBaseInitTypeDef *TIM_TimeBaseStructure, NVIC_InitTypeDef *NVIC_InitStructure)
36 | {
37 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
38 |
39 | /* Enable the Timer3 Interrupt */
40 | NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
41 |
42 | NVIC_InitStructure->NVIC_IRQChannel = TIM3_IRQn; // configure the Timer2 interrupts
43 | NVIC_InitStructure->NVIC_IRQChannelPreemptionPriority = 0 ; // sets the priority group of the TIMER2 interrupts
44 | NVIC_InitStructure->NVIC_IRQChannelSubPriority = 0; // set the subpriority inside the group
45 | NVIC_InitStructure->NVIC_IRQChannelCmd = ENABLE; // TIMER3 interrupts are globally enabled
46 | NVIC_Init(NVIC_InitStructure);
47 |
48 | /* Configure Timer which is every 5 ms active*/
49 | TIM_DeInit(TIM3);
50 | TIM_TimeBaseStructInit(TIM_TimeBaseStructure);
51 |
52 | /* Time base configuration */
53 | TIM_TimeBaseStructure->TIM_Prescaler = 1800 - 1; // 72 MHz / 1800 = 40 khz
54 | TIM_TimeBaseStructure->TIM_Period = 200 - 1; // (1/400khz) * 200 = 5 ms;
55 | TIM_TimeBaseStructure->TIM_ClockDivision = TIM_CKD_DIV1;
56 | TIM_TimeBaseStructure->TIM_CounterMode = TIM_CounterMode_Up;
57 | TIM_TimeBaseInit(TIM3, TIM_TimeBaseStructure);
58 |
59 | /* Enable TIM2 Update Interrupt */
60 | TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
61 |
62 |
63 |
64 | void TIM2_IRQHandler(void)
65 | {
66 |
67 | Display_Adc_Value(Line7,Black,Line3,Green,ADC1);
68 | Display_Adc_Value(Line8,Black,Line5,Blue,ADC2);
69 |
70 | TIM_ClearITPendingBit(TIM2, TIM_IT_Update); //Update Interrupt
71 | }
72 |
73 | void TIM3_IRQHandler(void)
74 | {
75 |
76 | UARTSend("CV", 1);
77 | // if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
78 | // {
79 | //
80 | // }
81 | TIM_ClearITPendingBit(TIM3, TIM_IT_Update); //Update Interrupt
82 | }
