1 | /****************************************************************************
2 | Title : HD44780U LCD library
3 | Author: Peter Fleury <pfleury@gmx.ch> http://jump.to/fleury
4 | File: $Id: LCD.c,v 1.14.2.1 2006/01/29 12:16:41 peter Exp $
5 | Software: AVR-GCC 3.3
6 | Target: any AVR device, memory mapped mode only for AT90S4414/8515/Mega
7 |
8 | DESCRIPTION
9 | Basic routines for interfacing a HD44780U-based text LCD display
10 |
11 | Originally based on Volker Oth's LCD library,
12 | changed LCD_init(), added additional constants for LCD_command(),
13 | added 4-bit I/O mode, improved and optimized code.
14 |
15 | Library can be operated in memory mapped mode (LCD_IO_MODE=0) or in
16 | 4-bit IO port mode (LCD_IO_MODE=1). 8-bit IO port mode not supported.
17 |
18 | Memory mapped mode compatible with Kanda STK200, but supports also
19 | generation of R/W signal through A8 address line.
20 |
21 | USAGE
22 | See the C include LCD.h file for a description of each function
23 |
24 | *****************************************************************************/
25 | #include <inttypes.h>
26 | #include <avr/io.h>
27 | #include <avr/pgmspace.h>
28 | #include <stdlib.h>
29 |
30 | #include "LCD.h"
31 |
32 | #define Header "LCD V2.2 07.2013"
33 |
34 | #define false 0
35 |
36 | /*
37 | ** constants/macros
38 | */
39 | #define DDR(x) (*(&x - 1)) /* address of data direction register of port x */
40 | #if defined(__AVR_ATmega64__) || defined(__AVR_ATmega128__)
41 | /* on ATmega64/128 PINF is on port 0x00 and not 0x60 */
42 | #define PIN(x) ( &PORTF==&(x) ? _SFR_IO8(0x00) : (*(&x - 2)) )
43 | #else
44 | #define PIN(x) (*(&x - 2)) /* address of input register of port x */
45 | #endif
46 |
47 |
48 | #if LCD_IO_MODE
49 | #define LCD_e_delay() __asm__ __volatile__( "rjmp 1f\n 1:" );
50 | #define LCD_e_high() LCD_E_PORT |= _BV(LCD_E_PIN);
51 | #define LCD_e_low() LCD_E_PORT &= ~_BV(LCD_E_PIN);
52 | #define LCD_e_toggle() toggle_e()
53 | #define LCD_rw_high() LCD_RW_PORT |= _BV(LCD_RW_PIN)
54 | #define LCD_rw_low() LCD_RW_PORT &= ~_BV(LCD_RW_PIN)
55 | #define LCD_rs_high() LCD_RS_PORT |= _BV(LCD_RS_PIN)
56 | #define LCD_rs_low() LCD_RS_PORT &= ~_BV(LCD_RS_PIN)
57 | #endif
58 |
59 | #if LCD_IO_MODE
60 | #if LCD_LINES==1
61 | #define LCD_FUNCTION_DEFAULT LCD_FUNCTION_4BIT_1LINE
62 | #else
63 | #define LCD_FUNCTION_DEFAULT LCD_FUNCTION_4BIT_2LINES
64 | #endif
65 | #else
66 | #if LCD_LINES==1
67 | #define LCD_FUNCTION_DEFAULT LCD_FUNCTION_8BIT_1LINE
68 | #else
69 | #define LCD_FUNCTION_DEFAULT LCD_FUNCTION_8BIT_2LINES
70 | #endif
71 | #endif
72 |
73 | #if LCD_CONTROLLER_KS0073
74 | #if LCD_LINES==4
75 |
76 | #define KS0073_EXTENDED_FUNCTION_REGISTER_ON 0x24 /* |0|010|0100 4-bit mode extension-bit RE = 1 */
77 | #define KS0073_EXTENDED_FUNCTION_REGISTER_OFF 0x20 /* |0|000|1001 4 lines mode */
78 | #define KS0073_4LINES_MODE 0x09 /* |0|001|0000 4-bit mode, extension-bit RE = 0 */
79 |
80 | #endif
81 | #endif
82 |
83 | /*
84 | ** function prototypes
85 | */
86 | #if LCD_IO_MODE
87 | static void toggle_e(void);
88 | #endif
89 |
90 | /*
91 | ** local functions
92 | */
93 |
94 | /*************************************************************************
95 | delay loop for small accurate delays: 16-bit counter, 4 cycles/loop
96 | *************************************************************************/
97 | static inline void _delayFourCycles(unsigned int __count)
98 | {
99 | if ( __count == 0 )
100 | __asm__ __volatile__( "rjmp 1f\n 1:" ); // 2 cycles
101 | else
102 | __asm__ __volatile__ (
103 | "1: sbiw %0,1" "\n\t"
104 | "brne 1b" // 4 cycles/loop
105 | : "=w" (__count)
106 | : "0" (__count)
107 | );
108 | }
109 |
110 |
111 | /*************************************************************************
112 | delay for a minimum of <us> microseconds
113 | the number of loops is calculated at compile-time from MCU clock frequency
114 | *************************************************************************/
115 | #define delay(us) _delayFourCycles( ( ( 1*(XTAL/4000) )*us)/1000 )
116 |
117 |
118 | #if LCD_IO_MODE
119 | /* toggle Enable Pin to initiate write */
120 | static void toggle_e(void)
121 | {
122 | LCD_e_high();
123 | LCD_e_delay();
124 | LCD_e_low();
125 | }
126 | #endif
127 |
128 |
129 | /*************************************************************************
130 | Low-level function to write byte to LCD controller
131 | Input: data byte to write to LCD
132 | rs 1: write data
133 | 0: write instruction
134 | Returns: none
135 | *************************************************************************/
136 | #if LCD_IO_MODE
137 | static void LCD_write(uint8_t data,uint8_t rs)
138 | {
139 | unsigned char dataBits ;
140 |
141 |
142 | if (rs) { /* write data (RS=1, RW=0) */
143 | LCD_rs_high();
144 | } else { /* write instruction (RS=0, RW=0) */
145 | LCD_rs_low();
146 | }
147 | LCD_rw_low();
148 |
149 | if ( ( &LCD_DATA0_PORT == &LCD_DATA1_PORT) && ( &LCD_DATA1_PORT == &LCD_DATA2_PORT ) && ( &LCD_DATA2_PORT == &LCD_DATA3_PORT )
150 | && (LCD_DATA0_PIN == 0) && (LCD_DATA1_PIN == 1) && (LCD_DATA2_PIN == 2) && (LCD_DATA3_PIN == 3) )
151 | {
152 | /* configure data pins as output */
153 | DDR(LCD_DATA0_PORT) |= 0x0F;
154 |
155 | /* output high nibble first */
156 | dataBits = LCD_DATA0_PORT & 0xF0;
157 | LCD_DATA0_PORT = dataBits |((data>>4)&0x0F);
158 | LCD_e_toggle();
159 |
160 | /* output low nibble */
161 | LCD_DATA0_PORT = dataBits | (data&0x0F);
162 | LCD_e_toggle();
163 |
164 | /* all data pins high (inactive) */
165 | LCD_DATA0_PORT = dataBits | 0x0F;
166 | }
167 | else
168 | {
169 | /* configure data pins as output */
170 | DDR(LCD_DATA0_PORT) |= _BV(LCD_DATA0_PIN);
171 | DDR(LCD_DATA1_PORT) |= _BV(LCD_DATA1_PIN);
172 | DDR(LCD_DATA2_PORT) |= _BV(LCD_DATA2_PIN);
173 | DDR(LCD_DATA3_PORT) |= _BV(LCD_DATA3_PIN);
174 |
175 | /* output high nibble first */
176 | LCD_DATA3_PORT &= ~_BV(LCD_DATA3_PIN);
177 | LCD_DATA2_PORT &= ~_BV(LCD_DATA2_PIN);
178 | LCD_DATA1_PORT &= ~_BV(LCD_DATA1_PIN);
179 | LCD_DATA0_PORT &= ~_BV(LCD_DATA0_PIN);
180 | if(data & 0x80) LCD_DATA3_PORT |= _BV(LCD_DATA3_PIN);
181 | if(data & 0x40) LCD_DATA2_PORT |= _BV(LCD_DATA2_PIN);
182 | if(data & 0x20) LCD_DATA1_PORT |= _BV(LCD_DATA1_PIN);
183 | if(data & 0x10) LCD_DATA0_PORT |= _BV(LCD_DATA0_PIN);
184 | LCD_e_toggle();
185 |
186 | /* output low nibble */
187 | LCD_DATA3_PORT &= ~_BV(LCD_DATA3_PIN);
188 | LCD_DATA2_PORT &= ~_BV(LCD_DATA2_PIN);
189 | LCD_DATA1_PORT &= ~_BV(LCD_DATA1_PIN);
190 | LCD_DATA0_PORT &= ~_BV(LCD_DATA0_PIN);
191 | if(data & 0x08) LCD_DATA3_PORT |= _BV(LCD_DATA3_PIN);
192 | if(data & 0x04) LCD_DATA2_PORT |= _BV(LCD_DATA2_PIN);
193 | if(data & 0x02) LCD_DATA1_PORT |= _BV(LCD_DATA1_PIN);
194 | if(data & 0x01) LCD_DATA0_PORT |= _BV(LCD_DATA0_PIN);
195 | LCD_e_toggle();
196 |
197 | /* all data pins high (inactive) */
198 | LCD_DATA0_PORT |= _BV(LCD_DATA0_PIN);
199 | LCD_DATA1_PORT |= _BV(LCD_DATA1_PIN);
200 | LCD_DATA2_PORT |= _BV(LCD_DATA2_PIN);
201 | LCD_DATA3_PORT |= _BV(LCD_DATA3_PIN);
202 | }
203 | }
204 | #else
205 | #define LCD_write(d,rs) if (rs) *(volatile uint8_t*)(LCD_IO_DATA) = d; else *(volatile uint8_t*)(LCD_IO_FUNCTION) = d;
206 | /* rs==0 -> write instruction to LCD_IO_FUNCTION */
207 | /* rs==1 -> write data to LCD_IO_DATA */
208 | #endif
209 |
210 |
211 | /*************************************************************************
212 | Low-level function to read byte from LCD controller
213 | Input: rs 1: read data
214 | 0: read busy flag / address counter
215 | Returns: byte read from LCD controller
216 | *************************************************************************/
217 | #if LCD_IO_MODE
218 | static uint8_t LCD_read(uint8_t rs)
219 | {
220 | uint8_t data;
221 |
222 |
223 | if (rs)
224 | LCD_rs_high(); /* RS=1: read data */
225 | else
226 | LCD_rs_low(); /* RS=0: read busy flag */
227 | LCD_rw_high(); /* RW=1 read mode */
228 |
229 | if ( ( &LCD_DATA0_PORT == &LCD_DATA1_PORT) && ( &LCD_DATA1_PORT == &LCD_DATA2_PORT ) && ( &LCD_DATA2_PORT == &LCD_DATA3_PORT )
230 | && ( LCD_DATA0_PIN == 0 )&& (LCD_DATA1_PIN == 1) && (LCD_DATA2_PIN == 2) && (LCD_DATA3_PIN == 3) )
231 | {
232 | DDR(LCD_DATA0_PORT) &= 0xF0; /* configure data pins as input */
233 |
234 | LCD_e_high();
235 | LCD_e_delay();
236 | data = PIN(LCD_DATA0_PORT) << 4; /* read high nibble first */
237 | LCD_e_low();
238 |
239 | LCD_e_delay(); /* Enable 500ns low */
240 |
241 | LCD_e_high();
242 | LCD_e_delay();
243 | data |= PIN(LCD_DATA0_PORT)&0x0F; /* read low nibble */
244 | LCD_e_low();
245 | }
246 | else
247 | {
248 | /* configure data pins as input */
249 | DDR(LCD_DATA0_PORT) &= ~_BV(LCD_DATA0_PIN);
250 | DDR(LCD_DATA1_PORT) &= ~_BV(LCD_DATA1_PIN);
251 | DDR(LCD_DATA2_PORT) &= ~_BV(LCD_DATA2_PIN);
252 | DDR(LCD_DATA3_PORT) &= ~_BV(LCD_DATA3_PIN);
253 |
254 | /* read high nibble first */
255 | LCD_e_high();
256 | LCD_e_delay();
257 | data = 0;
258 | if ( PIN(LCD_DATA0_PORT) & _BV(LCD_DATA0_PIN) ) data |= 0x10;
259 | if ( PIN(LCD_DATA1_PORT) & _BV(LCD_DATA1_PIN) ) data |= 0x20;
260 | if ( PIN(LCD_DATA2_PORT) & _BV(LCD_DATA2_PIN) ) data |= 0x40;
261 | if ( PIN(LCD_DATA3_PORT) & _BV(LCD_DATA3_PIN) ) data |= 0x80;
262 | LCD_e_low();
263 |
264 | LCD_e_delay(); /* Enable 500ns low */
265 |
266 | /* read low nibble */
267 | LCD_e_high();
268 | LCD_e_delay();
269 | if ( PIN(LCD_DATA0_PORT) & _BV(LCD_DATA0_PIN) ) data |= 0x01;
270 | if ( PIN(LCD_DATA1_PORT) & _BV(LCD_DATA1_PIN) ) data |= 0x02;
271 | if ( PIN(LCD_DATA2_PORT) & _BV(LCD_DATA2_PIN) ) data |= 0x04;
272 | if ( PIN(LCD_DATA3_PORT) & _BV(LCD_DATA3_PIN) ) data |= 0x08;
273 | LCD_e_low();
274 | }
275 | return data;
276 | }
277 | #else
278 | #define LCD_read(rs) (rs) ? *(volatile uint8_t*)(LCD_IO_DATA+LCD_IO_READ) : *(volatile uint8_t*)(LCD_IO_FUNCTION+LCD_IO_READ)
279 | /* rs==0 -> read instruction from LCD_IO_FUNCTION */
280 | /* rs==1 -> read data from LCD_IO_DATA */
281 | #endif
282 |
283 |
284 | /*************************************************************************
285 | loops while LCD is busy, returns address counter
286 | *************************************************************************/
287 | static uint8_t LCD_waitbusy(void)
288 |
289 | {
290 | register uint8_t c;
291 |
292 | /* wait until busy flag is cleared */
293 | while ( (c=LCD_read(0)) & (1<<LCD_BUSY)) {}
294 |
295 | /* the address counter is updated 4us after the busy flag is cleared */
296 | delay(2); // 2
297 |
298 | /* now read the address counter */
299 | return (LCD_read(0)); // return address counter
300 |
301 | }/* LCD_waitbusy */
302 |
303 |
304 | /*************************************************************************
305 | Move cursor to the start of next line or to the first line if the cursor
306 | is already on the last line.
307 | *************************************************************************/
308 | static inline void LCD_newline(uint8_t pos)
309 | {
310 | register uint8_t addressCounter;
311 | int y;
312 |
313 | addressCounter = 0;
314 |
315 |
316 | #if LCD_LINES==1
317 | LCD_write((1<<LCD_DDRAM)+addressCounter,0);
318 | #endif
319 | #if LCD_LINES==2
320 | if (pos < (LCD_START_LINE2) )
321 | addressCounter = LCD_START_LINE2;
322 | else
323 | addressCounter = LCD_START_LINE1;
324 | LCD_write((1<<LCD_DDRAM)+addressCounter,0);
325 | #endif
326 | #if LCD_LINES==4
327 | #if KS0073_4LINES_MODE
328 | if (pos < LCD_START_LINE2 )
329 | addressCounter = LCD_START_LINE2;
330 | else if ( (pos >= LCD_START_LINE2) && (pos < LCD_START_LINE3) )
331 | addressCounter = LCD_START_LINE3;
332 | else if ( (pos >= LCD_START_LINE3) && (pos < LCD_START_LINE4) )
333 | addressCounter = LCD_START_LINE4;
334 | else
335 | addressCounter = LCD_START_LINE1;
336 | LCD_write((1<<LCD_DDRAM)+addressCounter,0);
337 |
338 | #else
339 | if ((pos >= LCD_START_LINE1) && (pos < (LCD_START_LINE1+LCD_DISP_LENGTH))) y=1;
340 | else if ((pos >= LCD_START_LINE2) && (pos < (LCD_START_LINE2+LCD_DISP_LENGTH))) y=2;
341 | else if ((pos >= LCD_START_LINE3) && (pos < (LCD_START_LINE3+LCD_DISP_LENGTH))) y=3;
342 | else if ((pos >= LCD_START_LINE4) && (pos < (LCD_START_LINE4+LCD_DISP_LENGTH))) y=4;
343 |
344 | LCD_gotoxy(0,y);
345 | #endif
346 | #endif
347 |
348 |
349 | }/* LCD_newline */
350 |
351 |
352 | /*
353 | ** PUBLIC FUNCTIONS
354 | */
355 |
356 | /*************************************************************************
357 | Send LCD controller instruction command
358 | Input: instruction to send to LCD controller, see HD44780 data sheet
359 | Returns: none
360 | *************************************************************************/
361 | void LCD_command(uint8_t cmd)
362 | {
363 | LCD_waitbusy();
364 | LCD_write(cmd,0);
365 | }
366 |
367 |
368 | /*************************************************************************
369 | Send data byte to LCD controller
370 | Input: data to send to LCD controller, see HD44780 data sheet
371 | Returns: none
372 | *************************************************************************/
373 | void LCD_data(uint8_t data)
374 | {
375 | LCD_waitbusy();
376 | LCD_write(data,1);
377 | }
378 |
379 |
380 |
381 | /*************************************************************************
382 | Set cursor to specified position
383 | Input: x horizontal position (0: left most position)
384 | y vertical position (0: first line)
385 | Returns: none
386 | *************************************************************************/
387 | void LCD_gotoxy(uint8_t x, uint8_t y)
388 | {
389 | #if LCD_LINES==1
390 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE1+x);
391 | #endif
392 | #if LCD_LINES==2
393 | if ( y==0 )
394 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE1+x);
395 | else
396 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE2+x);
397 | #endif
398 | #if LCD_LINES==4
399 | if ( y==0 )
400 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE1+x);
401 | else if ( y==1)
402 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE2+x);
403 | else if ( y==2)
404 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE3+x);
405 | else if ( y==3)
406 | LCD_command((1<<LCD_DDRAM)+LCD_START_LINE4+x);
407 | #endif
408 |
409 | }/* LCD_gotoxy */
410 |
411 |
412 | /*************************************************************************
413 | *************************************************************************/
414 | int LCD_getxy(void)
415 | {
416 | return LCD_waitbusy();
417 | }
418 |
419 |
420 | /*************************************************************************
421 | Clear display and set cursor to home position
422 | *************************************************************************/
423 | void LCD_clrscr(void)
424 | {
425 | LCD_command(1<<LCD_CLR);
426 | }
427 |
428 |
429 | /*************************************************************************
430 | Set cursor to home position
431 | *************************************************************************/
432 | void LCD_home(void)
433 | {
434 | LCD_command(1<<LCD_HOME);
435 | }
436 |
437 |
438 | /*************************************************************************
439 | Display character at current cursor position
440 | Input: character to be displayed
441 | Returns: none
442 | *************************************************************************/
443 | void LCD_putc(char c) {
444 | uint8_t pos;
445 |
446 |
447 | pos = LCD_waitbusy(); // read busy-flag and address counter
448 | switch (c) {
449 | case '\r': {
450 | LCD_newline(pos);
451 | break;
452 | }
453 | default: {
454 | LCD_write(c, 1);
455 | pos = LCD_waitbusy();
456 |
457 | #if LCD_WRAP_LINES==1
458 | #if LCD_LINES==1
459 | if ( pos == LCD_START_LINE1+LCD_DISP_LENGTH ) {
460 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE1,0);
461 | }
462 | #elif LCD_LINES==2
463 | if ( pos == LCD_START_LINE1+LCD_DISP_LENGTH ) {
464 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE2,0);
465 | }else if ( pos == LCD_START_LINE2+LCD_DISP_LENGTH ){
466 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE1,0);
467 | }
468 | #elif LCD_LINES==4
469 | if ( pos == LCD_START_LINE1+LCD_DISP_LENGTH ) {
470 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE2,0);
471 | }else if ( pos == LCD_START_LINE2+LCD_DISP_LENGTH ) {
472 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE3,0);
473 | }else if ( pos == LCD_START_LINE3+LCD_DISP_LENGTH ) {
474 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE4,0);
475 | }else if ( pos == LCD_START_LINE4+LCD_DISP_LENGTH ) {
476 | LCD_write((1<<LCD_DDRAM)+LCD_START_LINE1,0);
477 | }
478 | #endif
479 | #endif
480 | break;
481 | }
482 | }
483 |
484 | }/* LCD_putc */
485 |
486 |
487 | /*************************************************************************
488 | Display string without auto linefeed
489 | Input: string to be displayed
490 | Returns: none
491 | *************************************************************************/
492 | void LCD_puts(const char *s)
493 | /* print string on LCD (no auto linefeed) */
494 | {
495 | register char c;
496 |
497 | while ( (c = *s++) ) {
498 | LCD_putc(c);
499 | }
500 |
501 | }/* LCD_puts */
502 |
503 |
504 | /*************************************************************************
505 | Display string from program memory without auto linefeed
506 | Input: string from program memory be be displayed
507 | Returns: none
508 | *************************************************************************/
509 | void LCD_puts_p(const char *progmem_s)
510 | /* print string from program memory on LCD (no auto linefeed) */
511 | {
512 | register char c;
513 |
514 | while ( (c = pgm_read_byte(progmem_s++)) ) {
515 | LCD_putc(c);
516 | }
517 |
518 | }/* LCD_puts_p */
519 |
520 |
521 |
522 | void LCD_puti_alt(uint8_t inpv) {
523 | int rest;
524 | LCD_putc((int)inpv/100 | '0');
525 | rest = inpv % 100;
526 | LCD_putc((int)rest/10 | '0');
527 | rest = rest % 10;
528 | LCD_putc((int)rest | '0');
529 | }
530 |
531 |
532 | //---------------------------------------------------------------
533 | void LCD_puti(int zahl, int sges) {
534 | //Senden der Integerzahl (16-Bit) als Zeichenkette formatiert mit sges Stellen
535 | //als Zeichenkette (-32768 .. 32767)
536 | char buffer[16];
537 | uint8_t l=0,n;
538 | char *z=buffer;
539 | itoa(zahl,buffer,10);
540 | while(*z!=0){l++; z++;} //Bufferlänge l
541 | for(n=l;n<sges;n++) LCD_putc('0');
542 | LCD_puts(buffer);
543 | }
544 |
545 |
546 | //---------------------------------------------------------------
547 | void LCD_putl(long zahl, int sges) {
548 | //Senden der Longzahl (32-Bit) als Zeichenkette formatiert mit sges Stellen
549 | //als Zeichenkette (-2147483648 .. 2147483647)
550 | char buffer[16];
551 | uint8_t l=0,n;
552 | char *z=buffer;
553 | ltoa(zahl,buffer,10);
554 | while(*z!=0){l++; z++;} //Bufferlänge l
555 | for(n=l;n<sges;n++) LCD_putc('0');
556 | LCD_puts(buffer);
557 | }
558 |
559 |
560 |
561 | //---------------------------------------------------------------
562 | void LCD_putif(int zahl, int sges, int floats) {
563 | //Senden der Integerzahl zahl als Zeichenkette formatiert mit sges Stellen
564 | //als Zeichenkette setzt Dezimalpunkt for die n(float) letzte Stelle!
565 | char buffer[16];
566 | int i,j=0;
567 | uint8_t l=0,n;
568 | char *z=buffer;
569 |
570 | itoa(zahl,buffer,10);
571 | i=0;
572 | if (buffer[0] == '-') {LCD_putc('-'); ++z; i++;}
573 | else LCD_putc(' ');
574 |
575 | while(*z!=0){l++; z++;}//Bufferlänge l
576 | for(n=l;n<sges;n++) {
577 | LCD_putc('0');
578 | ++j;
579 | if (j==(sges-floats)) LCD_putc(',');
580 | }
581 | while (buffer[i] != 0) {
582 | LCD_putc(buffer[i]);
583 | ++j;
584 | if (j==(sges-floats)) LCD_putc(',');
585 | ++i;
586 | }
587 | }
588 |
589 |
590 | //---------------------------------------------------------------
591 | void LCD_putlf(long zahl, int sges, int floats) {
592 | //Senden der Integerzahl zahl als Zeichenkette formatiert mit sges Stellen
593 | //als Zeichenkette setzt Dezimalpunkt for die n(float) letzte Stelle!
594 | char buffer[16];
595 | int i,j=0;
596 | uint8_t l=0,n;
597 | char *z=buffer;
598 |
599 | ltoa(zahl,buffer,10);
600 | i=0;
601 | if (buffer[0] == '-') {LCD_putc('-'); ++z; i++;}
602 | else LCD_putc(' ');
603 |
604 | while(*z!=0){l++; z++;}//Bufferlänge l
605 | for(n=l;n<sges;n++) {
606 | LCD_putc('0');
607 | ++j;
608 | if (j==(sges-floats)) LCD_putc(',');
609 | }
610 | while (buffer[i] != 0) {
611 | LCD_putc(buffer[i]);
612 | ++j;
613 | if (j==(sges-floats)) LCD_putc(',');
614 | ++i;
615 | }
616 | }
617 |
618 |
619 |
620 |
621 | /*************************************************************************
622 | Initialize display and select type of cursor
623 | Input: dispAttr LCD_DISP_OFF display off
624 | LCD_DISP_ON display on, cursor off
625 | LCD_DISP_ON_CURSOR display on, cursor on
626 | LCD_DISP_CURSOR_BLINK display on, cursor on flashing
627 | Returns: none
628 | *************************************************************************/
629 | void LCD_init(uint8_t dispAttr, char *Title)
630 | {
631 | #if LCD_IO_MODE
632 | /*
633 | * Initialize LCD to 4 bit I/O mode
634 | */
635 |
636 | if ( ( &LCD_DATA0_PORT == &LCD_DATA1_PORT) && ( &LCD_DATA1_PORT == &LCD_DATA2_PORT ) && ( &LCD_DATA2_PORT == &LCD_DATA3_PORT )
637 | && ( &LCD_RS_PORT == &LCD_DATA0_PORT) && ( &LCD_RW_PORT == &LCD_DATA0_PORT) && (&LCD_E_PORT == &LCD_DATA0_PORT)
638 | && (LCD_DATA0_PIN == 0 ) && (LCD_DATA1_PIN == 1) && (LCD_DATA2_PIN == 2) && (LCD_DATA3_PIN == 3)
639 | && (LCD_RS_PIN == 4 ) && (LCD_RW_PIN == 5) && (LCD_E_PIN == 6 ) )
640 | {
641 | /* configure all port bits as output (all LCD lines on same port) */
642 | DDR(LCD_DATA0_PORT) |= 0x7F;
643 | }
644 | else if ( ( &LCD_DATA0_PORT == &LCD_DATA1_PORT) && ( &LCD_DATA1_PORT == &LCD_DATA2_PORT ) && ( &LCD_DATA2_PORT == &LCD_DATA3_PORT )
645 | && (LCD_DATA0_PIN == 0 ) && (LCD_DATA1_PIN == 1) && (LCD_DATA2_PIN == 2) && (LCD_DATA3_PIN == 3) )
646 | {
647 | /* configure all port bits as output (all LCD data lines on same port, but control lines on different ports) */
648 | DDR(LCD_DATA0_PORT) |= 0x0F;
649 | DDR(LCD_RS_PORT) |= _BV(LCD_RS_PIN);
650 | DDR(LCD_RW_PORT) |= _BV(LCD_RW_PIN);
651 | DDR(LCD_E_PORT) |= _BV(LCD_E_PIN);
652 | }
653 | else
654 | {
655 | /* configure all port bits as output (LCD data and control lines on different ports */
656 | DDR(LCD_RS_PORT) |= _BV(LCD_RS_PIN);
657 | DDR(LCD_RW_PORT) |= _BV(LCD_RW_PIN);
658 | DDR(LCD_E_PORT) |= _BV(LCD_E_PIN);
659 | DDR(LCD_DATA0_PORT) |= _BV(LCD_DATA0_PIN);
660 | DDR(LCD_DATA1_PORT) |= _BV(LCD_DATA1_PIN);
661 | DDR(LCD_DATA2_PORT) |= _BV(LCD_DATA2_PIN);
662 | DDR(LCD_DATA3_PORT) |= _BV(LCD_DATA3_PIN);
663 | }
664 | delay(16000); /* wait 16ms == 16000 or more after power-on */
665 |
666 | /* initial write to LCD is 8bit */
667 | LCD_DATA1_PORT |= _BV(LCD_DATA1_PIN); // _BV(LCD_FUNCTION)>>4;
668 | LCD_DATA0_PORT |= _BV(LCD_DATA0_PIN); // _BV(LCD_FUNCTION_8BIT)>>4;
669 | LCD_e_toggle();
670 | delay(4992); /* ??? 4992 delay, busy flag can't be checked here */
671 |
672 | /* repeat last command */
673 | LCD_e_toggle();
674 | delay(64); /* delay, busy flag can't be checked here */
675 |
676 | /* repeat last command a third time */
677 | LCD_e_toggle();
678 | delay(64); /* delay, busy flag can't be checked here */
679 |
680 | /* now configure for 4bit mode */
681 | LCD_DATA0_PORT &= ~_BV(LCD_DATA0_PIN); // LCD_FUNCTION_4BIT_1LINE>>4
682 | LCD_e_toggle();
683 | delay(64); /* some displays need this additional delay */
684 |
685 | /* from now the LCD only accepts 4 bit I/O, we can use LCD_command() */
686 | #else
687 | /*
688 | * Initialize LCD to 8 bit memory mapped mode
689 | */
690 |
691 | /* enable external SRAM (memory mapped LCD) and one wait state */
692 | MCUCR = _BV(SRE) | _BV(SRW);
693 |
694 | /* reset LCD */
695 | delay(16000); /* wait 16ms after power-on */
696 | LCD_write(LCD_FUNCTION_8BIT_1LINE,0); /* function set: 8bit interface */
697 | delay(4992); /* wait 5ms */
698 | LCD_write(LCD_FUNCTION_8BIT_1LINE,0); /* function set: 8bit interface */
699 | delay(64); /* wait 64us */
700 | LCD_write(LCD_FUNCTION_8BIT_1LINE,0); /* function set: 8bit interface */
701 | delay(64); /* wait 64us */
702 | #endif
703 |
704 | #if KS0073_4LINES_MODE
705 | /* Display with KS0073 controller requires special commands for enabling 4 line mode */
706 | LCD_command(KS0073_EXTENDED_FUNCTION_REGISTER_ON);
707 | LCD_command(KS0073_4LINES_MODE);
708 | LCD_command(KS0073_EXTENDED_FUNCTION_REGISTER_OFF);
709 | #else
710 | LCD_command(LCD_FUNCTION_DEFAULT); /* function set: display lines */
711 | #endif
712 | LCD_command(LCD_DISP_OFF); /* display off */
713 | LCD_clrscr(); /* display clear */
714 | LCD_command(LCD_MODE_DEFAULT); /* set entry mode */
715 | LCD_command(dispAttr); /* display/cursor control */
716 |
717 | if (*Title == 0) LCD_puts(Header);
718 | else LCD_puts(Title);
719 |
720 | }/* LCD_init */
721 |
722 | //--------------------------------------------------------------
723 | void LCD_putui_hex(unsigned int zahl, int sges){
724 | //Senden der nur-positiven Integerzahl zahl als Zeichenkette formatiert mit sges Stellen
725 | // das Ausgabeformat ist hex (TSC)
726 | char buffer[17];
727 | uint8_t l=0,n;
728 | char *z=buffer;
729 | utoa(zahl,buffer,16);
730 | while(*z!=0){l++; z++;}//Bufferlänge l
731 | for(n=l;n<sges;n++) LCD_putc(' ');
732 | LCD_puts(buffer);
733 | }
734 | //--------------------------------------------------------------
735 | void LCD_putui_bin(unsigned int zahl, int sges){
736 | //Senden der Integerzahl zahl als Zeichenkette formatiert mit sges Stellen
737 | // Das Ausgabeformat ist binär. Leerstellen werden mit 0 aufgefüllt.
738 | char buffer[17];
739 | uint8_t l=0,n;
740 | char *z=buffer;
741 | utoa(zahl,buffer,2);
742 | while(*z!=0){l++; z++;}//Bufferlänge l
743 | for(n=l;n<sges;n++) LCD_putc('0');
744 | LCD_puts(buffer);
745 | }
746 | //--------------------------------------------------------------
747 |
748 | void LCD_putb(uint8_t a){
749 | //Senden einer 8-Bit-Zahl binär(TSC)
750 | LCD_putui_bin(a,8);
751 | }
752 |
753 | //--------------------------------------------------------------
754 |
755 | void LCD_clear_char(uint8_t x, uint8_t y, uint8_t n){
756 | uint8_t i;
757 | //Loescht ab Pos(x,y) n Zeichen und setzt Pos. auf (x,y)
758 | LCD_gotoxy(x,y);
759 | for(i=0; i<n; ++i) LCD_putc(' ');
760 | LCD_gotoxy(x,y);
761 | }
762 |
763 | //--------------------------------------------------------------
764 |
765 | void LCD_Info(char *header, char *autor){
766 | static unsigned char old = false;
767 | if (old == false) {
768 | old = !false;
769 | LCD_clrscr();
770 | if(*header == 0) LCD_puts(Header);
771 | else LCD_puts(header);
772 | LCD_gotoxy(0,1);
773 | if(*autor == 0) LCD_puts(" Zielinski");
774 | else LCD_puts(autor);
775 | }
776 | }
