1 | #include <clock.h>
2 |
3 | #ifndef CONF_CLOCKS_H_INCLUDED
4 | # define CONF_CLOCKS_H_INCLUDED
5 |
6 | /* System clock bus configuration */
7 | # define CONF_CLOCK_CPU_CLOCK_FAILURE_DETECT true
8 | # define CONF_CLOCK_FLASH_WAIT_STATES 0
9 | # define CONF_CLOCK_CPU_DIVIDER SYSTEM_MAIN_CLOCK_DIV_1
10 | # define CONF_CLOCK_APBA_DIVIDER SYSTEM_MAIN_CLOCK_DIV_1
11 | # define CONF_CLOCK_APBB_DIVIDER SYSTEM_MAIN_CLOCK_DIV_1
12 |
13 |
14 | /* SYSTEM_CLOCK_SOURCE_OSC8M configuration - Internal 8MHz oscillator */
15 | # define CONF_CLOCK_OSC8M_PRESCALER SYSTEM_OSC8M_DIV_1
16 | # define CONF_CLOCK_OSC8M_ON_DEMAND true
17 | # define CONF_CLOCK_OSC8M_RUN_IN_STANDBY false
18 |
19 | /* SYSTEM_CLOCK_SOURCE_XOSC configuration - External clock/oscillator */
20 | # define CONF_CLOCK_XOSC_ENABLE false
21 | # define CONF_CLOCK_XOSC_EXTERNAL_CRYSTAL SYSTEM_CLOCK_EXTERNAL_CRYSTAL
22 | # define CONF_CLOCK_XOSC_EXTERNAL_FREQUENCY 12000000UL
23 | # define CONF_CLOCK_XOSC_STARTUP_TIME SYSTEM_XOSC_STARTUP_32768
24 | # define CONF_CLOCK_XOSC_AUTO_GAIN_CONTROL true
25 | # define CONF_CLOCK_XOSC_ON_DEMAND true
26 | # define CONF_CLOCK_XOSC_RUN_IN_STANDBY false
27 |
28 | /* SYSTEM_CLOCK_SOURCE_XOSC32K configuration - External 32KHz crystal/clock oscillator */
29 | # define CONF_CLOCK_XOSC32K_ENABLE true
30 | # define CONF_CLOCK_XOSC32K_EXTERNAL_CRYSTAL SYSTEM_CLOCK_EXTERNAL_CRYSTAL
31 | # define CONF_CLOCK_XOSC32K_STARTUP_TIME SYSTEM_XOSC32K_STARTUP_65536
32 | # define CONF_CLOCK_XOSC32K_AUTO_AMPLITUDE_CONTROL false
33 | # define CONF_CLOCK_XOSC32K_ENABLE_1KHZ_OUPUT false
34 | # define CONF_CLOCK_XOSC32K_ENABLE_32KHZ_OUTPUT true
35 | # define CONF_CLOCK_XOSC32K_ON_DEMAND true
36 | # define CONF_CLOCK_XOSC32K_RUN_IN_STANDBY false
37 |
38 | /* SYSTEM_CLOCK_SOURCE_OSC32K configuration - Internal 32KHz oscillator */
39 | # define CONF_CLOCK_OSC32K_ENABLE false
40 | # define CONF_CLOCK_OSC32K_STARTUP_TIME SYSTEM_OSC32K_STARTUP_128
41 | # define CONF_CLOCK_OSC32K_ENABLE_1KHZ_OUTPUT true
42 | # define CONF_CLOCK_OSC32K_ENABLE_32KHZ_OUTPUT true
43 | # define CONF_CLOCK_OSC32K_ON_DEMAND true
44 | # define CONF_CLOCK_OSC32K_RUN_IN_STANDBY false
45 |
46 | /* SYSTEM_CLOCK_SOURCE_DFLL configuration - Digital Frequency Locked Loop */
47 | # define CONF_CLOCK_DFLL_ENABLE true
48 | # define CONF_CLOCK_DFLL_LOOP_MODE SYSTEM_CLOCK_DFLL_LOOP_MODE_CLOSED
49 | # define CONF_CLOCK_DFLL_ON_DEMAND false
50 | # define CONF_CLOCK_DFLL_RUN_IN_STANDBY false
51 |
52 | /* DFLL open loop mode configuration */
53 | # define CONF_CLOCK_DFLL_COARSE_VALUE (0x1f / 4)
54 | # define CONF_CLOCK_DFLL_FINE_VALUE (0xff / 4)
55 |
56 | /* DFLL closed loop mode configuration */
57 | # define CONF_CLOCK_DFLL_SOURCE_GCLK_GENERATOR GCLK_GENERATOR_0
58 | # define CONF_CLOCK_DFLL_MULTIPLY_FACTOR 2
59 | # define CONF_CLOCK_DFLL_QUICK_LOCK true
60 | # define CONF_CLOCK_DFLL_TRACK_AFTER_FINE_LOCK true
61 | # define CONF_CLOCK_DFLL_KEEP_LOCK_ON_WAKEUP true
62 | # define CONF_CLOCK_DFLL_ENABLE_CHILL_CYCLE true
63 | # define CONF_CLOCK_DFLL_MAX_COARSE_STEP_SIZE (0x1f / 4)
64 | # define CONF_CLOCK_DFLL_MAX_FINE_STEP_SIZE (0xff / 4)
65 |
66 |
67 | /* Set this to true to configure the GCLK when running clocks_init. If set to
68 | * false, none of the GCLK generators will be configured in clocks_init(). */
69 | # define CONF_CLOCK_CONFIGURE_GCLK true
70 |
71 | /* Configure GCLK generator 0 (Main Clock) */
72 | # define CONF_CLOCK_GCLK_0_ENABLE true
73 | # define CONF_CLOCK_GCLK_0_RUN_IN_STANDBY false
74 | # define CONF_CLOCK_GCLK_0_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
75 | # define CONF_CLOCK_GCLK_0_PRESCALER 1
76 | # define CONF_CLOCK_GCLK_0_OUTPUT_ENABLE true
77 |
78 | /* Configure GCLK generator 1 */
79 | # define CONF_CLOCK_GCLK_1_ENABLE true
80 | # define CONF_CLOCK_GCLK_1_RUN_IN_STANDBY false
81 | # define CONF_CLOCK_GCLK_1_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_DFLL
82 | # define CONF_CLOCK_GCLK_1_PRESCALER 1
83 | # define CONF_CLOCK_GCLK_1_OUTPUT_ENABLE true
84 |
85 | /* Configure GCLK generator 2 (RTC) */
86 | # define CONF_CLOCK_GCLK_2_ENABLE false
87 | # define CONF_CLOCK_GCLK_2_RUN_IN_STANDBY false
88 | # define CONF_CLOCK_GCLK_2_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC32K
89 | # define CONF_CLOCK_GCLK_2_PRESCALER 32
90 | # define CONF_CLOCK_GCLK_2_OUTPUT_ENABLE false
91 |
92 | /* Configure GCLK generator 3 */
93 | # define CONF_CLOCK_GCLK_3_ENABLE false
94 | # define CONF_CLOCK_GCLK_3_RUN_IN_STANDBY false
95 | # define CONF_CLOCK_GCLK_3_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
96 | # define CONF_CLOCK_GCLK_3_PRESCALER 1
97 | # define CONF_CLOCK_GCLK_3_OUTPUT_ENABLE false
98 |
99 | /* Configure GCLK generator 4 */
100 | # define CONF_CLOCK_GCLK_4_ENABLE false
101 | # define CONF_CLOCK_GCLK_4_RUN_IN_STANDBY false
102 | # define CONF_CLOCK_GCLK_4_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
103 | # define CONF_CLOCK_GCLK_4_PRESCALER 1
104 | # define CONF_CLOCK_GCLK_4_OUTPUT_ENABLE false
105 |
106 | /* Configure GCLK generator 5 */
107 | # define CONF_CLOCK_GCLK_5_ENABLE false
108 | # define CONF_CLOCK_GCLK_5_RUN_IN_STANDBY false
109 | # define CONF_CLOCK_GCLK_5_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
110 | # define CONF_CLOCK_GCLK_5_PRESCALER 1
111 | # define CONF_CLOCK_GCLK_5_OUTPUT_ENABLE false
112 |
113 | /* Configure GCLK generator 6 */
114 | # define CONF_CLOCK_GCLK_6_ENABLE false
115 | # define CONF_CLOCK_GCLK_6_RUN_IN_STANDBY false
116 | # define CONF_CLOCK_GCLK_6_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
117 | # define CONF_CLOCK_GCLK_6_PRESCALER 1
118 | # define CONF_CLOCK_GCLK_6_OUTPUT_ENABLE false
119 |
120 | /* Configure GCLK generator 7 */
121 | # define CONF_CLOCK_GCLK_7_ENABLE false
122 | # define CONF_CLOCK_GCLK_7_RUN_IN_STANDBY false
123 | # define CONF_CLOCK_GCLK_7_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
124 | # define CONF_CLOCK_GCLK_7_PRESCALER 1
125 | # define CONF_CLOCK_GCLK_7_OUTPUT_ENABLE false
126 |
127 | #endif /* CONF_CLOCKS_H_INCLUDED */
