1 | // includes
2 | #include <stddef.h>
3 | #include <stdlib.h>
4 | #include "stm32l1xx.h"
5 | #include "halfSinus.h"
6 |
7 | // defines
8 | #define VREF 2920 // VREF+ (mV), nearly VDD
9 |
10 | // variables
11 | volatile uint16_t amplitude;
12 |
13 | // function prototypes
14 | void DAC_Voltage(uint8_t channel, uint16_t mV);
15 | uint16_t ADC_Voltage(uint8_t channel);
16 | void InitPeriph();
17 | void Delay(uint32_t c) {
18 | while(c--);
19 | }
20 |
21 | // main program
22 | int main() {
23 |
24 | SystemInit();
25 |
26 | //PWR_VoltageScalingConfig(PWR_VoltageScaling_Range1); // selects best performance; also set in SystemInit()
27 |
28 | // we can't use HSE because no quarz soldered in place
29 | /*RCC_HSEConfig(RCC_HSE_ON);
30 | while(!RCC_GetFlagStatus(RCC_FLAG_HSERDY));
31 | RCC_PLLConfig(RCC_PLLSource_HSE, RCC_PLLMul_12, RCC_PLLDiv_3);
32 | RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
33 | while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL);*/
34 |
35 | // use HSI instead
36 | RCC_HSICmd(ENABLE);
37 | while(!RCC_GetFlagStatus(RCC_FLAG_HSIRDY));
38 | // HSI can't be used as source for PLL for some reason
39 | RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
40 | while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_HSI);
41 |
42 | RCC_ClocksTypeDef clock;
43 | RCC_GetClocksFreq(&clock); // get current clockspeed -> 16MHz it says
44 |
45 | InitPeriph();
46 |
47 | amplitude = 2000;
48 |
49 | while(1) {
50 | // just play around with ADC: light up green LED when swiping on touchpad
51 | if (ADC_Voltage(14) > 1100) {
52 | GPIO_WriteBit(GPIOB, GPIO_Pin_7, Bit_SET);
53 | } else {
54 | GPIO_WriteBit(GPIOB, GPIO_Pin_7, Bit_RESET);
55 | }
56 | Delay(1000);
57 | DAC_Voltage(2, ADC_Voltage(2)); // digitalize input voltage and output on other pin, useful for calibrating VREF
58 | GPIO_ToggleBits(GPIOB, GPIO_Pin_6);
59 | }
60 | }
61 |
62 | // timer interrupt handler
63 | void TIM4_IRQHandler() {
64 | static uint8_t i = 0;
65 |
66 | if (TIM_GetITStatus(TIM4, TIM_IT_Update)) { // period overflow
67 | // clear interrupt trigger
68 | TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
69 |
70 | TIM3->CCR3 = halfSin[i]*511/4095;
71 | //TIM9->CCR1 = halfSin[i]*511/4095;
72 | DAC_SetChannel1Data(DAC_Align_12b_R, halfSin[i]*amplitude/VREF);
73 | if ((i+=2) >= 99) i = 0;
74 | }
75 | }
76 |
77 |
78 | // functions
79 | void DAC_Voltage(uint8_t channel, uint16_t mV) {
80 | if (channel == 1) DAC_SetChannel1Data(DAC_Align_12b_R, mV*4059/VREF);
81 | if (channel == 2) DAC_SetChannel2Data(DAC_Align_12b_R, mV*4059/VREF);
82 | }
83 |
84 | uint16_t ADC_Voltage(uint8_t channel) {
85 | ADC_RegularChannelConfig(ADC1, channel, 1, ADC_SampleTime_4Cycles);
86 | ADC_SoftwareStartConv(ADC1);
87 | while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
88 | return ADC_GetConversionValue(ADC1)*VREF/4059;
89 | }
90 |
91 | void InitPeriph() {
92 | // turn on clock for LEDs
93 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
94 | // initialize LEDs on board
95 | GPIO_InitTypeDef gpioInitStruct;
96 | gpioInitStruct.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_6; // green led: PB7 , blue led: PB6
97 | gpioInitStruct.GPIO_Mode = GPIO_Mode_OUT;
98 | gpioInitStruct.GPIO_OType = GPIO_OType_PP;
99 | gpioInitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
100 | gpioInitStruct.GPIO_Speed = GPIO_Speed_2MHz;
101 | GPIO_Init(GPIOB, &gpioInitStruct);
102 |
103 | // turn on clock for DAC
104 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
105 | // initialize DAC
106 | DAC_InitTypeDef dacInitStruct;
107 | dacInitStruct.DAC_Trigger = DAC_Trigger_None;
108 | dacInitStruct.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
109 | dacInitStruct.DAC_WaveGeneration = DAC_WaveGeneration_None;
110 | // initialize both DAC channels with structure settings above
111 | DAC_Init(DAC_Channel_1, &dacInitStruct);
112 | DAC_Init(DAC_Channel_2, &dacInitStruct);
113 | // enable both DAC channels
114 | DAC_Cmd(DAC_Channel_1, ENABLE);
115 | DAC_Cmd(DAC_Channel_2, ENABLE);
116 |
117 | // turn on clock for ADC1
118 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
119 | /* turn on highspeed internal clock
120 | RCC_HSICmd(ENABLE);
121 | while(!RCC_GetFlagStatus(RCC_FLAG_HSIRDY)); // wait until done
122 | // initialize common (ADC analog clock prescaler) - wtf is this?
123 | ADC_CommonInitTypeDef adcCommonInitStruct;
124 | adcCommonInitStruct.ADC_Prescaler = ADC_Prescaler_Div1;
125 | ADC_CommonInit(&adcCommonInitStruct);*/
126 | // initialize ADC
127 | ADC_InitTypeDef adcInitStruct;
128 | adcInitStruct.ADC_ScanConvMode = DISABLE;
129 | adcInitStruct.ADC_ContinuousConvMode = DISABLE;
130 | adcInitStruct.ADC_ExternalTrigConv = ADC_ExternalTrigConvEdge_None;
131 | adcInitStruct.ADC_DataAlign = ADC_DataAlign_Right;
132 | adcInitStruct.ADC_NbrOfConversion = 1;
133 | ADC_Init(ADC1, &adcInitStruct);
134 | // enable ADC1
135 | ADC_Cmd(ADC1, ENABLE);
136 | while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS));
137 |
138 | // turn on clock for timer4
139 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
140 | // initialize timer
141 | TIM_TimeBaseInitTypeDef timInitStruct;
142 | timInitStruct.TIM_Prescaler = 1;
143 | timInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
144 | timInitStruct.TIM_Period = 200;
145 | timInitStruct.TIM_ClockDivision = 0;
146 | TIM_TimeBaseInit(TIM4, &timInitStruct);
147 | // initialize interrupts
148 | NVIC_InitTypeDef intInitStruct;
149 | intInitStruct.NVIC_IRQChannel = TIM4_IRQn;
150 | intInitStruct.NVIC_IRQChannelCmd = ENABLE;
151 | intInitStruct.NVIC_IRQChannelPreemptionPriority = 0x0F;
152 | intInitStruct.NVIC_IRQChannelSubPriority = 0x0F;
153 | NVIC_Init(&intInitStruct);
154 | // enable timer interrupt
155 | TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
156 | TIM_Cmd(TIM4, ENABLE);
157 |
158 | // turn on clock for timer3
159 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
160 | // initialize timer
161 | timInitStruct.TIM_Prescaler = 1;
162 | timInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
163 | timInitStruct.TIM_Period = 511;
164 | timInitStruct.TIM_ClockDivision = 0;
165 | TIM_TimeBaseInit(TIM3, &timInitStruct);
166 | // initialize pwm
167 | TIM_OCInitTypeDef ocInitStruct;
168 | ocInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
169 | ocInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
170 | ocInitStruct.TIM_OutputState = TIM_OutputState_Enable;
171 | ocInitStruct.TIM_Pulse = 0;
172 | TIM_OC3Init(TIM3, &ocInitStruct);
173 | TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
174 | TIM_Cmd(TIM3, ENABLE);
175 | // configure pwm pin
176 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
177 | gpioInitStruct.GPIO_Pin = GPIO_Pin_8;
178 | gpioInitStruct.GPIO_Mode = GPIO_Mode_AF;
179 | gpioInitStruct.GPIO_OType = GPIO_OType_PP;
180 | gpioInitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
181 | gpioInitStruct.GPIO_Speed = GPIO_Speed_2MHz;
182 | GPIO_Init(GPIOC, &gpioInitStruct);
183 | GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM3);
184 |
185 | /* turn on clock for timer9
186 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM9, ENABLE);
187 | // initialize timer
188 | timInitStruct.TIM_Prescaler = 1;
189 | timInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
190 | timInitStruct.TIM_Period = 511;
191 | timInitStruct.TIM_ClockDivision = 0;
192 | TIM_TimeBaseInit(TIM9, &timInitStruct);
193 | // initialize pwm
194 | TIM_OCInitTypeDef ocInitStruct;
195 | ocInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
196 | ocInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
197 | ocInitStruct.TIM_OutputState = TIM_OutputState_Enable;
198 | ocInitStruct.TIM_Pulse = 0;
199 | TIM_OC1Init(TIM9, &ocInitStruct);
200 | TIM_OC1PreloadConfig(TIM9, TIM_OCPreload_Enable);
201 | TIM_Cmd(TIM9, ENABLE);
202 | // configure pwm pin
203 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
204 | gpioInitStruct.GPIO_Pin = GPIO_Pin_13;
205 | gpioInitStruct.GPIO_Mode = GPIO_Mode_AF;
206 | gpioInitStruct.GPIO_OType = GPIO_OType_PP;
207 | gpioInitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
208 | gpioInitStruct.GPIO_Speed = GPIO_Speed_40MHz;
209 | GPIO_Init(GPIOB, &gpioInitStruct);
210 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_TIM9);*/
211 | }
