1 | //Enable Peripheral Clock of USART3
2 | AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_US3;
3 |
4 | //-----> Pin-configuration
5 | //Disable interrupts
6 | AT91C_BASE_PIOB->PIO_IDR = (AT91C_PB9_RXD3 | AT91C_PB8_TXD3);
7 |
8 | //Select Peripheral Function A
9 | AT91C_BASE_PIOB->PIO_ABSR &= ~(AT91C_PB9_RXD3 | AT91C_PB8_TXD3);
10 |
11 | //Disable PIO controll
12 | AT91C_BASE_PIOB->PIO_PDR = (AT91C_PB9_RXD3 | AT91C_PB8_TXD3);
13 |
14 | //-----> Modul-configuration of USART3
15 | // Reset and disable receiver & transmitter
16 | AT91C_BASE_US3->US_CR = AT91C_US_RSTRX | AT91C_US_RSTTX | AT91C_US_RXDIS | AT91C_US_TXDIS;
17 |
18 | //Configure mode
19 | AT91C_BASE_US3->US_MR = (AT91C_US_USMODE_NORMAL //Normal Mode
20 | | AT91C_US_CLKS_CLOCK //Use MCLK
21 | | AT91C_US_CHRL_8_BITS //Character Length 8bit
22 | | AT91C_US_PAR_NONE //No Parity
23 | | AT91C_US_NBSTOP_1_BIT //1 Stop bit
24 | | AT91C_US_CHMODE_NORMAL); //Channel Mode normal
25 |
26 | //Configure baudrate
27 | //Asynchronous, no oversampling
28 | AT91C_BASE_US3->US_BRGR = (133333333 / 9600) / 16;
29 |
30 |
31 | //-----> AIC-Configuration
32 | //Disable the interrupt
33 | AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_US3;
34 |
35 | //Configure mode and handler
36 | AT91C_BASE_AIC->AIC_SMR[AT91C_ID_US3] = 0;
37 | AT91C_BASE_AIC->AIC_SVR[AT91C_ID_US3] = (unsigned int) USART3_IrqHandler;
38 |
39 | //Clear interrupt
40 | AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_US3;
41 |
42 | //Enable interrupt
43 | AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_US3;
44 |
45 | //Enable Transmitter & Receiver
46 | AT91C_BASE_US3->US_CR = (AT91C_US_TXEN | AT91C_US_RXEN);
47 |
48 | //Receive Buffer setup
49 | volatile unsigned char rcv[2];
50 | //Receive Pointer Register
51 | AT91C_BASE_US3->US_RPR = (unsigned int) rcv;
52 | //Receive Count Register
53 | AT91C_BASE_US3->US_RCR = 2;
54 | //Transfer Control Register
55 | AT91C_BASE_US3->US_PTCR = AT91C_PDC_RXTEN;
56 |
57 | //Enable RXBUFF interrupt
58 | AT91C_BASE_US3->US_IER = AT91C_US_RXBUFF;
59 |
60 |
61 |
62 | //Transmit Buffer setup
63 | volatile unsigned char snd[12];
64 | snd[0] = 1;
65 | snd[1] = 2;
66 | snd[2] = 3;
67 | snd[3] = 4;
68 | snd[4] = 5;
69 | snd[5] = 6;
70 | snd[6] = 7;
71 | snd[7] = 8;
72 | snd[8] = 9;
73 | AT91C_BASE_US3->US_TPR = (unsigned int) snd;
74 | AT91C_BASE_US3->US_TCR = 9;
75 | AT91C_BASE_US3->US_PTCR = AT91C_PDC_TXTEN;
76 |
77 |
78 | volatile unsigned int status = 0;
79 | do
80 | {
81 | status = AT91C_BASE_US3->US_CSR;
82 | }while(!(status & 0x1));
