PIC32MX150 The target device is not ready for debugging.
Gast #3452329
Target detected
Device ID Revision = A1
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1ffff
boot config memory
configuration memory
Programming...
Programming/Verify complete
The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding
Ehm und welches Bit ist hier gemeint?
Ich habe die config von einem PIC32MX795 übernommen
    #pragma config DEBUG = ON               // Hab ich vorher nie gebraucht aber jetzt geht es damit auch nicht.
    #pragma config FPLLODIV = DIV_1         // PLL Output Divider
    #pragma config FPBDIV   = DIV_1         // Peripheral Clock divisor
    #pragma config FPLLMUL  = MUL_20        // PLL Multiplier
    #pragma config FPLLIDIV = DIV_2         // PLL Input Divider
// Watchdog
    #pragma config FWDTEN   = OFF           // Watchdog Timer
    #pragma config WDTPS    = PS1           // Watchdog Timer Postscale
// other
    #pragma config FCKSM    = CSDCMD        // Clock Switching & Fail Safe Clock Monitor
    #pragma config OSCIOFNC = OFF           // CLKO Enable
    #pragma config POSCMOD  = XT            // Primary Oscillator
    #pragma config IESO     = OFF           // Internal/External Switch-over
    #pragma config FSOSCEN  = OFF           // Secondary Oscillator Enable (KLO was off)
    #pragma config FNOSC    = PRIPLL        // Oscillator Selection
// PGC
//    #pragma config ICESEL   = ICS_PGx2      // ICE/ICD Comm Channel Select
23
24
// Code Protect
25
    #pragma config CP       = OFF           // Code Protect
26
    #pragma config BWP      = OFF           // Boot Flash Write Protect
27
    #pragma config PWP      = OFF           // Program Flash Write Protect
28
#endif
