What is the best way to switch the output of a pin between PWM ON and PWM OFF (Pin state high)? Basically what I want to get is: High(10ms) -- PWM(20ms) -- High(50ms)... The time tells the Duration of the pins state. I have the PWM working as it should but just do not know how to switch it ON and OFF. This is the way I initialized the timer: TIM_TimeBaseStructure.TIM_Period = TIM_ARR; TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); The channel: TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = TIM_CCR; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; Is it the right way to use something like: TIM4->CCR4=0; or TIM_SetCompare1(TIM4,0); But this was not working for me. Thanks for your ideas.
1. put an external pull-up resistor on your pwm-output pin. 2. use (systick) timer for a at least msecs-based timer functions 3. switch by software between pwm-out mode and dio input mode at your desired msecs interval. 4. have fun
If I understand correctly what you are trying to achieve, it's as simple as setting the PWM value to 100% duty cycle (on), then to 50% duty cycle (or whatever PWM value you want) and so on.
