1 | #include <stdio.h>
2 | #include <stdlib.h>
3 | #include <p24FJ128GB108.h>
4 | #include <spi.h>
5 | #include <xc.h>
6 |
7 | // CONFIG3
8 | #pragma config WPFP = WPFP511 // Write Protection Flash Page Segment Boundary (Highest Page (same as page 85))
9 | #pragma config WPDIS = WPDIS // Segment Write Protection Disable bit (Segmented code protection disabled)
10 | #pragma config WPCFG = WPCFGDIS // Configuration Word Code Page Protection Select bit (Last page(at the top of program memory) and Flash configuration words are not protected)
11 | #pragma config WPEND = WPENDMEM // Segment Write Protection End Page Select bit (Write Protect from WPFP to the last page of memory)
12 |
13 | // CONFIG2
14 | #pragma config POSCMOD = HS // Primary Oscillator Select (HS oscillator mode selected)
15 | #pragma config DISUVREG = OFF // Internal USB 3.3V Regulator Disable bit (Regulator is disabled)
16 | #pragma config IOL1WAY = OFF // IOLOCK One-Way Set Enable bit (Unlimited Writes To RP Registers)
17 | #pragma config OSCIOFNC = OFF // Primary Oscillator Output Function (OSCO functions as CLKO (FOSC/2))
18 | #pragma config FCKSM = CSDCMD // Clock Switching and Monitor (Both Clock Switching and Fail-safe Clock Monitor are disabled)
19 | #pragma config FNOSC = PRI // Oscillator Select (Primary oscillator (XT, HS, EC))
20 | #pragma config PLL_96MHZ = ON // 96MHz PLL Disable (Enabled)
21 | #pragma config PLLDIV = DIV2 // USB 96 MHz PLL Prescaler Select bits (Oscillator input divided by 2 (8MHz input))
22 | #pragma config IESO = OFF // Internal External Switch Over Mode (IESO mode (Two-speed start-up)disabled)
23 |
24 | // CONFIG1
25 | #pragma config WDTPS = PS32768 // Watchdog Timer Postscaler (1:32,768)
26 | #pragma config FWPSA = PR128 // WDT Prescaler (Prescaler ratio of 1:128)
27 | #pragma config WINDIS = OFF // Watchdog Timer Window (Standard Watchdog Timer enabled,(Windowed-mode is disabled))
28 | #pragma config FWDTEN = OFF // Watchdog Timer Enable (Watchdog Timer is disabled)
29 | #pragma config ICS = PGx1 // Comm Channel Select (Emulator functions are shared with PGEC1/PGED1)
30 | #pragma config GWRP = OFF // General Code Segment Write Protect (Writes to program memory are allowed)
31 | #pragma config GCP = OFF // General Code Segment Code Protect (Code protection is disabled)
32 | #pragma config JTAGEN = OFF // JTAG Port Enable (JTAG port is disabled
33 |
34 | void wait()
35 | {
36 | int del;
37 | for(del = 500; del>= 0; del--);
38 | }
39 |
40 | void INITCSMCP3201PIN(void)
41 | {
42 | TRISBbits.TRISB4 = 0;
43 | LATBbits.LATB4 = 1;
44 | }
45 |
46 |
47 | void INIT_SPI1(void)
48 | {
49 | IFS0bits.SPI1IF = 0;
50 | IEC0bits.SPI1IE = 0;
51 | IPC2bits.SPI1IP = 0;
52 |
53 | // SPI1CON1 setting
54 | SPI1CON1bits.DISSCK = 0; // Internal SPI clock enable
55 | SPI1CON1bits.DISSDO = 0; // SDO pin is controlled by the module
56 | SPI1CON1bits.MODE16 = 1; // 16 bits wide
57 | SPI1CON1bits.SMP = 0; // input data sampled at the middle of data ouput time
58 | SPI1CON1bits.CKE = 0; // from idle clock to active clock
59 | SPI1CON1bits.SSEN = 0; // SSx pin not used by the module
60 | SPI1CON1bits.CKP = 0; // idle state clock is low level
61 | SPI1CON1bits.MSTEN=1; // master mode
62 | SPI1CON1bits.SPRE = 7; // secondary prescal 1:1
63 | SPI1CON1bits.PPRE = 3; // primary prescale 1:1
64 |
65 | // SPI1CON2 setting
66 | SPI1CON2bits.FRMEN = 1; // framed SPI support enable
67 | SPI1CON2bits.SPIFSD = 0; // frame sync pulse output Master
68 | SPI1CON2bits.SPIFPOL = 0; // framesync pulse is active low
69 | SPI1CON2bits.SPIFE = 0, // framesync pulse precedes first bit clock
70 | SPI1CON2bits.SPIBEN = 0; // enhanced buffer disable
71 |
72 | // SPI1STAT setting
73 | SPI1STATbits.SPIEN = 0; //inititally disable
74 | SPI1STATbits.SPISIDL = 0; //continue module operation in idle mode
75 | SPI1STATbits.SPIROV = 0; //no overflow has occured
76 | }
77 |
78 | unsigned int RECEIVED_SPI1(void)
79 | {
80 | LATBbits.LATB4 = 0;
81 | unsigned int mrdata=0;
82 | mrdata = SPI1BUF;
83 | while (SPI2STATbits.SPIRBF);
84 | LATBbits.LATB4 = 1;
85 | return mrdata;
86 | }
87 |
88 | unsigned int wert;
89 |
90 |
91 | int main(void) {
92 |
93 | INITCSMCP3201PIN();
94 | INIT_SPI1();
95 |
96 | SPI1BUF=0;
97 | SPI1STATbits.SPIEN = 1;
98 |
99 | while(1)
100 | {
101 | wait();
102 | wert = RECEIVED_SPI1();
103 | wait();
104 | }
105 | return 0;
106 |
107 | }
